Beta Asuswrt-Merlin 388.2 Beta is now available for Wifi 6 models
Just had something really odd happen, I have an olde NAS plugged directly into LAN1.
The NAS went offline, when I looked at it, the LAN port was going Up/Down every 5 seconds.
I wasn't sure if the NAS was at fault or what, so I swapped it into LAN2 and now that port started going Up/Down every 5 seconds.
Tried swapping back but both ports now kept going up/down.
Was cured by a reboot (of the router).
Very odd.
Hi, right now i lose the internet connection with this log, i dont know what happened.
Mar 27 22:24:07 awsiot[734927]: awsiot start
Mar 27 22:24:07 wlceventd: wlceventd_proc_event(530): eth7: Auth 68:72:C3:81:A3:C8, status: Successful (0), rssi:0
Mar 27 22:24:07 wlceventd: wlceventd_proc_event(559): eth7: Assoc 68:72:C3:81:A3:C8, status: Successful (0), rssi:-71
Mar 27 22:24:07 hostapd: eth7: STA 68:72:c3:81:a3:c8 IEEE 802.11: associated
Mar 27 22:24:07 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Mar 27 22:24:10 pppd[15740]: No response to 10 echo-requests
Mar 27 22:24:10 pppd[15740]: Serial link appears to be disconnected.
Mar 27 22:24:10 pppd[15740]: Connect time 2665.5 minutes.
Mar 27 22:24:10 pppd[15740]: Sent 4078992426 bytes, received 20428737 bytes.
Mar 27 22:24:10 lldpd[1380]: removal request for address of 87.235.0.10%28, but no knowledge of it
Mar 27 22:24:10 wsdd2[16209]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Mar 27 22:24:11 WAN_Connection: Fail to connect with some issues.
Mar 27 22:24:11 hostapd: eth7: STA 68:72:c3:81:a3:c8 IEEE 802.11: disassociated
Mar 27 22:24:11 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 68:72:C3:81:A3:C8, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-70
Mar 27 22:24:11 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 68:72:C3:81:A3:C8, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Mar 27 22:24:13 dnsmasq-dhcp[16184]: DHCPDISCOVER(br0) 82:7d:eb:81:3c:c3
Mar 27 22:24:13 dnsmasq-dhcp[16184]: DHCPOFFER(br0) 192.168.50.216 82:7d:eb:81:3c:c3
Mar 27 22:24:14 dnsmasq-dhcp[16184]: DHCPREQUEST(br0) 192.168.50.216 82:7d:eb:81:3c:c3
Mar 27 22:24:14 dnsmasq-dhcp[16184]: DHCPACK(br0) 192.168.50.216 82:7d:eb:81:3c:c3
Mar 27 22:24:15 dnsmasq-dhcp[16184]: DHCPDISCOVER(br0) 68:72:c3:81:a3:c8
Mar 27 22:24:15 dnsmasq-dhcp[16184]: DHCPOFFER(br0) 192.168.50.229 68:72:c3:81:a3:c8
Mar 27 22:24:15 dnsmasq-dhcp[16184]: DHCPREQUEST(br0) 192.168.50.229 68:72:c3:81:a3:c8
Mar 27 22:24:15 dnsmasq-dhcp[16184]: DHCPACK(br0) 192.168.50.229 68:72:c3:81:a3:c8 Samsung
Mar 27 22:24:17 pppd[15740]: Connection terminated.
Mar 27 22:24:17 pppd[15740]: Sent PADT
Mar 27 22:24:17 pppd[15740]: Modem hangup
Mar 27 22:24:19 dnsmasq-dhcp[16184]: DHCPDISCOVER(br0) 5a:62:23:1f:62:0d
Mar 27 22:24:19 dnsmasq-dhcp[16184]: DHCPOFFER(br0) 192.168.50.39 5a:62:23:1f:62:0d
Mar 27 22:24:20 dnsmasq-dhcp[16184]: DHCPREQUEST(br0) 192.168.50.39 5a:62:23:1f:62:0d
Mar 27 22:24:20 dnsmasq-dhcp[16184]: DHCPACK(br0) 192.168.50.39 5a:62:23:1f:62:0d
Mar 27 22:24:49 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind 62:EF:D8:77:65:8F, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-68
Mar 27 22:24:49 hostapd: eth6: STA 62:ef:d8:77:65:8f IEEE 802.11: disassociated
Mar 27 22:24:50 wlceventd: wlceventd_proc_event(511): eth6: Disassoc 62:EF:D8:77:65:8F, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Mar 27 22:24:50 hostapd: eth6: STA 62:ef:d8:77:65:8f IEEE 802.11: disassociated
The Wireless settings issue was fixed last night and also sent upstream. However I am unable to reproduce the dnsfilter issue so far.
No. What I mean is there are 6 separate variables:
dnsfilter_rulelist
dnsfilter_rulelist1
dnsfilter_rulelist2
dnsfilter_rulelist3
dnsfilter_rulelist4
dnsfilter_rulelist5
If your configured rules take less than 256 characters, they will be saved to dnsfilter_rulelist. If you have more entries that require more than 255 characters in total, then it will start using dnsfilter_rulelist1 to save anything past the 255 first characters. Up to a maximum of 6 * 255 characters can be used by rules, which would fill up all 6 variables then.
Maybe your settings are corrupted, one of the numbered rulelist variable contains bogus data. Try clearing them all, then reconfiguring them again from the webui:
nvram unset dnsfilter_rulelist
nvram unset dnsfilter_rulelist1
nvram unset dnsfilter_rulelist2
nvram unset dnsfilter_rulelist3
nvram unset dnsfilter_rulelist4
nvram unset dnsfilter_rulelist5
nvram commit
So just wait for the updated Advanced_Wireless_Content.asp page to be merged into the release, right? I see that is what is edited if I see correctly.
Yea the reason why I asked about this is because I wondered if you varied test servers to eliminate that as a possible variable. Also, are the speed test execution times coinciding with any of the speedtests conducted by the router. This could be another factor. Similar to trying to run two speedtest on two computers at the exact same time on the same network. This creates a variation in results during times of execution since both test runs may be competing to hold bandwidth.
Also, if possible investigate the logs in your modem specifically looking at lines that talk about the link connection between your modem and router to ensure at no point is your modem downgrading or adjusting the parameter. This could mean you are dealing with a bad connection from either one of the ethernet ports, possibly a bad ethernet cable, or bad modem firmware provisioning supplied to your modem from the ISP.
Yup to all that, no tests are run at the same time try to eliminate as many variables as possible. But odd how consistently wired devices and the AT&T gateway are in the upper 900's and symmetrical while the router is today all over the map, from the teans to the 700's and very asymetrical in terms of up/down results. Either AT&T is playing shennanigans or something really funky is going on in the AX88. My speedtest results have been all over the map today and on some sites have recieved a message about a malformed packet and then the site reloads. I'm going to replace the Ethernet cable betwwen the router and AT&T gateway, I'll be amazed if that's it but have been around the block enough times to where I often quote the General in WarGames when they go try to bring up games on WOPR...
Actually replacing both cables, router to gateway and gateway to ont...
Mar 27 22:24:10 pppd[15740]: No response to 10 echo-requests Mar 27 22:24:10 pppd[15740]: Serial link appears to be disconnected. Mar 27 22:24:10 pppd[15740]: Connect time 2665.5 minutes.
Your modem lost sync, or your ISP terminated the connection.
I'm not sure if this issue affects routers, since the fix is within AddBlockDNS(), and AFAIK DNS blocking only works on Win32.
I had an issue with the alpha firmware where if i left it unattended for a week, the router would eventually become non-functional (internet or even ssh) and then i would have to reboot it. I believe this is because I did a dirty install with adguard each time.
This time, i installed 388.2 beta 1 for gt-axe11000 and i did a factory reset then manually reset my settings and also enabled ip6 as someone stated in an earlier post that there was an error related to that. Hopefully my router stays up and doesn't have random "pauses' as well.
As I thought - that issue only affects Windows clients.
Windows: do not treat "setting IPv6 interface metric failed" as fatal error on "block-dns" install - this can happen if IPv6 is disabled on the interface and is not harmful in itself (GH #294)
So, it has no impact on Asuswrt-Merlin.
UGH, figured it out the hard way. Trend Micro! HW reset router and nodes, several times, methodically testing along the way. Slowly and methodically doing a speedtest with the native tool on the router. I got my symetrical +/- 940Mbps back until I enabled a Trend Micro feature. I was going to change the cables but after sleeping on it, if the PC and modem are doing great, why the cables...
Turning on Bandwidth Monitor results started to get wonky, assymetrcal and dropped 100-200Mbps on average. Then turning on AIProtection made things even worse, Speedtest results all over the map, sometimes not completing, sometimes in the single digits, dropped packets, though the AT&T gateway did not report any dropped packets :eek:. How did this happen? So early in this thread, seeing the messages on the topic, I turned on the Bandwidth monitor, just because I wanted some detail on usage. That's when the problems started. Then when I disabled/uninstalled Skynet and got back some performance, I enabled AIProtection. Digging the hole I was in even deeper. The odd piece in all of this is that I didn't notice any real changes in the way CPU was being consumed when all this mess was going on. But after I load this router back up the way it was, I'm going to run through my testing again, what I suspect is that the CPU utilization peaks are going to be lower and of shorter duration when testing without Trend Micro features.
The three good things that are coming out of this are 1) starting clean with 388.2 beta, getting rid of all the nvram variables left by prior releases and the bouncing back and forth between 388 and 386 families for WiFi stability and 2) my technique for add a AIMesh node worked flawlessly (wired and wireless). My trick is to HW reset the node before it can be discovered and added, did the process a few times through the testing I was doing. Even after it being added if I reset the router then only way to re-add them was to HW reset just before starting the discovery process (WPS method), worked every time. If doing a wired backhaul, set the router up first for wired backhaul before resetting the node(s) and launching discovery (connecting them up correctly of course, WAN on node to LAN on Routher)
The third issue was with Site Survey causing me to think I had interference with 36/160 and me moving to 40/160 after hitting rescan a few times in a row caused the 5Ghz radio to move to 149/80. Since I did a reset, the default is Auto for channel, and back on 36/160... There's someone nearby on 36/80, a bar, but 40 is wide open, so back on 40/160 I'lll go. The hitting of the rescan repeatedly (when complete) did not cause a channel change like it was doing before. After many attempts of the sequence, the channel/bandwidth did not change.
One other thing I discovered by accident as I was switching the port the cable coming from the router into the gateway uses. When I did a client discovery I found some of my WiFi clients on the list even though I have both the 2.4Ghz and 5Ghz radios disabled on it and made sure the SSID are not visible. Not at all sure how that happens, because it shouldn't with the radios off/disabled.
@aex.perez, big chunk of this thread is your speedtest troubleshooting. I really hope you have resolved the issue.
Yes, Trend Micro! The HW Reset cleared up another nuissance as well as clearing out old nvram entries. I also allowed got to test my method for adding AIMesh nodes several times.
I thought some script / module conflict was at fault or at the very least my back and forth with 388/386. Turned all of Trend Micro but didn't get fully stable until I revocked their privacy agreement.
Hello all,
I have a RT-AX58U and since i installed the version 388.2 beta 1, the static values in arp table get deleted after i turn off the device in question.
I step up a static arp entry using the command's below, editing the services-start and rebooting the device, but a few moments after turning off the device the entry in the arp no longer shows [PERM] and it changes to something like "(xxx.xxx.xx.xxx) at [ether] on br0". The IP is there but there is no mac adress defined.
I also tried to run the command "arp -i br0 -s XXX.XXX.XX.XXX XX:XX:XX:XX:XX:XX" manually, the value shows the [PERM] indicating that its a static value, but a minute after i shutdown the device, the value changes again and shows the entry in arp without mac adress.
Already tried a factory reset, formating the JFFS partition and configuring all from scratch, but it still doesn't work.
Everything is the same as in previous working version 388.1.
Can someone please confirm this issue?
Script:
vi /jffs/scripts/services-start
#!/bin/sh
chmod a+rx /jffs/scripts/services-start
Thanks all!
how is your testing coming along?
Figured it out, Trend Micro shenanigans. Even turning the features off, had to completely back out of the privacy agreement to get it back to where it was…
I thought that was one of the possibilities. In my original post where I talked about skynet, I also mentioned the trendmicro and disclaimers as possible suspects.
On an AX88U Pro, seeing a number of unexpected Fatal Signal 6 errors (SIGABRT):
potentially unexpected fatal signal 6.
CPU: 0 PID: 2422 Comm: dnsmasq Tainted: P O 4.19.183 #1
Hardware name: RTAX88U_PRO (DT)
pstate: 00070010 (nzcv q A32 LE aif)
pc : 00000000f7d7b3a4
lr : 00000000ffef1300
sp : 00000000ffef1300
x12: 0000000000000000
x11: 00000000ffef1590 x10: 00000000f7e71de0
x9 : 0000000000000002 x8 : 0000000000000001
x7 : 00000000000000af x6 : 00000000ffef1540
x5 : 00000000ffef1540 x4 : 0000000000000006
x3 : 0000000000000008 x2 : 0000000000000000
x1 : 00000000ffef1300 x0 : 0000000000000000
Two instances of dnsmasq seem to be running fine:
5956 ? S 0:10 dnsmasq --log-async
5957 ? S 0:00 dnsmasq --log-async
I am running with YazDHCP.
I had 6 of them today and 2 yesterday.
During my time setting up & tweaking some ASUS AC-class routers, I've always seen only 2 dnsmasq processes running simultaneously, and I've observed the same behavior on the RT-AX86S router (the only AX-class router I have access to ATM).
Example:
Note that I recently submitted a GitHub PR to YazDHCP with a few changes to minimize the number of dnsmasq restarts because I found a scenario where there were 3 "service restart_dnsmasq" calls being made consecutively. For more info see the PR here:
However, I never saw those 3 calls in a row cause a "fatal signal" crash, certainly not while investigating & then fixing the source of those calls. I suspect that there may be something else at play in your specific router's setup/environment.
Perhaps it would be helpful if you can provide more context around the time when one of those crashes occurs.
Just my 2 cents.
(It happen on a cold night. The winds were howling... The wife just put the kids to bed....) jk.
If anyone can figure this one out, I know you can given enough details. (just not the kind of details in these parenthesis)
Ah, but did you kiss & hug the kids good night?
How about the wife? Did you kiss & hug her as well? And for how long?
The devil is all in the details...;)
It was a cold night and the winds were indeed howling
In looking at the logs (I have scribe running so I needed to look at dmesg as well as /opt/var/log/messages.
From what I can tell - it does get triggered by my WAN (eth0) bouncing. I am trying a T-Mobile Gateway that will occasionally lose signal, take the link down then back up. Whenever the link up occurs, I do indeed see the Fatal Signal 6, dnsmasq Tainted messages.
Some additional observations:
I only see one PID reporting the Fatal Signal
I usually get a few fatals, often spaced about by around 20 seconds (+/- 5 secs)
This might be interesting - in every case, the signal occurs right after the .hostnames file is read by YazDHCP. There are 77 host names.
