No need for look up table - dBm = 10 * log10(mW)
or mW = 10^(dBm/10)
personally I would start with 20mW, which allows two steps of 3dB to get to 80mW, no need for quarter dB or playing around with the odd mW.
Updated OP with 3.0.0.3.157.12 Beta 2.
The big changes in this version are the new NAT loopback code, and Dual WAN being enabled (experimentally) for the RT-N16. Please give this a good test run, especially regarding the Dual WAN feature.
UPDATE: I forgot to mention that output power control was also manually enabled for the RT-N16. I'll need feedback on whether it's working or not.
Do we just update firmware and all the settings will stick?
Or export config, restore defaults, upgrade, restore defaults, import config?
Or restore defaults, upgrade, restore defaults, input settings manually? ( please no)
Thanks![]()
You get bigger numbers in mW, and marketing folk like bigger numbers espeically hard-disk and wireless network suppliers!
Looks like the driver works internally in dB, and antennae gain is specified in dB, but due to conversions and rounding if you ask for 80mW you get 79mW, so maybe someone at Aus has tried to fix that!
I have made some progress in understanding my dual-wan issues, when internet connection broken its not the first link, so Asus router still has good connection to half-bridge modem. Maybe this is why Chinese dual-wan has ping script where a ping target out on the internet can be specified in the web gui. I don't see any messages from wanduck, is there a way to make it more verbose? If not I will have to wait for the next Asus source-code release!
If coming from a firmware that has a version of 3.0.0.3.xxx then just flash mine on top of it. There was no change related to settings storage.
OK, cool, I'm using your 3.0.0.3.157.12 Beta release.
So I'll just simply flash it with latest one, and no setting should change hopefully?
So, if you release a new fw that requires to restore defaults before and after flashing, and settings need to be re done manually, or cannot be imported from current fw, do you usually mention this in the post?
And if you don't mention anything, does that mean one can just flash on top and/or backup current config and import after flashing?
wl -i ifname txpwr1 -o -q -1
What kernel version is ASUS software based on ?
Comand: uname -a
octopus
Is it possible to include a way to allow access to intranet for specific guests?
For example if I have 3 devices connected to guest wifi, but I only want one to access intranet, maybe by a drop down box of already connected devices?
If not, possibility to add more than one guest network?
Also, is there a way to hide or disable the router showing up in the network window of windows?
About the power, I just tried setting it to 1mw, but the bars on the laptop stayed full, but its in the same room as routerI'll try again when I move it to another room, or is there a special app one can see precisely how strong the signal is to the laptop?
I still waiting ASUS_RTN16_3003162_RM13, may I ask when will be release ?![]()
I've been waiting for additional feedback regarding the power settings option, since I don't have an RT-N16 to test it myself. If I don't have any additional feedback this weekend I'll release RM13 with the code as it is.
Welcome To SNBForums
