I test my N-16 .162version found if set the Wireless Timer can't auto start it, i also ask Asus tech support they also say have this problem in .162, i dont know N-66 user have this problem or not?![]()
@RMerlin
Do you continue to support custom build to RT-N16 ?
Or did you take a brake to port RT-AC66U ?
octoput
New RT-N16 release based on 3.0.0.3.178.15. As usual, this release is labelled as experimental, since I don't own an RT-N16 to test it myself.
Power settings are gone, since they don't seem to work properly on the RT-N16.
Good work on your build! Seems stable - though I haven´t tested everything!
The tx power, however, doesn´t have any effect...
Anyway - I want to share my experience with different versions of RT-N16 firmware, to see if someone else has noticed this:
ALL firmwares (ASUS, Tomato, Oleg etc) have a very weak WIFI signal.
HOWEVER - the ASUS 1.0.1.2 has a very STRONG signal!!!
I have gone back and forth between different FW´s and it´s always the same - everytime I go back to 1.0.1.2 the WIFI gets nice and strong again! What has happened since 1.0.1.2? Something can´t be right here... It´s a HUGE difference in both real world experience and with inSSIDer...
I'm testing the firmware, the only thing that I found so far wrong was the lack of showing the IP, DNS, gateway and type as the SS.
Any fix or is it normal?
https://lh4.googleusercontent.com/-JoE9CC-ooSs/UDPhpbk_HeI/AAAAAAAAAag/JBAuZlX0cd0/s720/merlin.jpg
Dual Wan is default !!!
But looks like i cannot disable ittry to apply nothing happens.
Any clue on what's on?
BTW, can you please give more detail on how to use optware for this release ? i would love to have those tools or some other addons like it running on usb drive.
it would be awsome
I am having no issues with the dual WAN feature. I disabled it as I don't have two WAN's and it disabled fine for me. No problems at all. As a matter of fact, I have been looking at USB Verizon 4G broadband adapters. This would ensure a working Internet connection for my wife so she can connect to work in the event Cox's Internet service goes down. Although I am using a RT-N66U...Guess I'll completely remove Dual WAN from the next RT-N16 build then. Too many issues related to it, and I cannot debug it since I don't have an RT-N16.
Hey Merlin,
First I would like to thank you for all the work you have done on the Asus Firmware. It works great for me (RT-N16). I am trying to write a script for accessing a transparent bridged DSL modem ahead of my router. I don't fully understand how to use the "User Shell Scripts" that you have included in the lastest firmware. Could you further explain their use and possibly include an example ? I have briefly searched the forum but could not find anything. Any help would be appreciated.
#!/bin/sh
iptables xyz
cp /mnt/sda1/firewall-start /jffs/scripts/
chmod a+rx /jffs/scripts/firewall-start
Welcome To SNBForums
