Yesterday, just really too busy again today to stress test it. Tomorrow I'll see what I can break.Anyone else testing the new 3.10.1 beta except @Adamm ?
Glad you add some variety, lately everyone seems focused on the 382.x branch which I still can't test for lack of a supported device.EDIT: I also just updated to John's alpha build (3.0.0.4.374.43_29A9j9527), if that helps confirm compatibility.
Yes, absolutely. How many people could complain that they cannot update the two firmware versions?!?! You especially, not to mention the rest of us do not need to see that.Note: This version of update-hosts.add includes two additional domains to whitelist by default.
They are Microsofts OneDrive domains:
- 1drv.ms
- onedrive.live.com
Both are inexplicably contained in at least one of the hosts files. Without whitelisting them, downloads of Johns and RMerlins firmware would fail.
Let me know what you think, is this a good idea and acceptable?
The other by-default-whitelisted domains are the domains of the hosts files providers, lines 131 to 142 in update-hosts.add.
I've had this happen to me in the past. Firefox pulls a 'dangerous' files feed from google, and google decided that all .zip files on onedrive were badBoth are inexplicably contained in at least one of the hosts files. Without whitelisting them, downloads of Johns and RMerlins firmware would fail.
I remember that. Mozilla are people too.I've had this happen to me in the past. Firefox pulls a 'dangerous' files feed from google, and google decided that all .zip files on onedrive were bad. I had to rename my nvram-save utility download for a while. Took about a week to get cleared up.
A B - S O L U T I O N A D - B L O C K I N G
AB-Solution 3.10.2 beta by thelonelycoder
RT-AC3100 (armv7l) fw-382.1 @ 192.168.14.1
69,143 blocked domains 5 hosts files in use
46,784 t 2,386 w 6 n ads since Dec 07 14:15
beta URL ab-solution.info/beta Beta hosts [on]
i AB-Solution [/mnt/EXT4]
cu check for updates
un updates notify [on] [weekly]
bu backup to email [on] [monthly,Key-files,tar.gz]
a ad-blocking [on]
l logging [on]
rs router stats [on] [to email] [Mon @ 1:30]
ps pixelserv-tls [192.168.14.4] [v35.HZ12.Kk]
entware device [/mnt/EXT4]
b blocking file [Medium] [Mon @ 2:00]
u update blocking file
el edit white or black list
f follow the logfile
ac update ads counter
e exit AB-Solution sm sub menu
--------------------- Message ----------------------
Hosts file download failed or file is not hosts
file, using local backup file instead.
Run [u] to manually update.
Done updated blocking file
What do you want to do?
____________________________________________________
Welcome To SNBForums
