[Beta] AB-Solution 3.x
I restarted skynet and it didn't help. I disabled skynet. This is the update run.
running update-hosts.add 3.10.2 in verbose mode
 using temporary pgl.yoyo.org file to lower memory usage while updating
 preparing temporay whitelist
 updated /jffs/shared-AB-whitelist, for other scripts to use
 refreshing Skynet to whitelist domains in shared-AB-whitelist
 including /jffs/shared-Skynet-whitelist in AB-Solution
 including /jffs/shared-Skynet2-whitelist in AB-Solution
 downloading Medium hosts files, using 192.168.x.x as blocking IP
 getting hosts file 1, preprocessing file:
 http://www.ab-solution.info/hostslist/winhelp2002_mvps_org.txt
-                                                    [   <=>        ] 121.61K   197KB/s    in 0.6s
 processing file 1 done
 getting hosts file 2, preprocessing file:
 http://www.ab-solution.info/hostslist/someonewhocares_org.txt
-                                                    [   <=>        ]  90.85K   147KB/s    in 0.6s
 processing file 2 done
 getting hosts file 3, preprocessing file:
 http://www.ab-solution.info/hostslist/pgl_yoyo_org.txt
-                                                100%[=========================================================================================================>]  15.68K   102KB/s    in 0.2s
 processing file 3 done
 getting hosts file 4, preprocessing file:
 http://www.ab-solution.info/hostslist/hosts-file_net_ad_servers.txt
-                                                    [       <=>        ] 240.90K   158KB/s    in 1.5s
 processing file 4 done
 getting hosts file 5, preprocessing file:
 http://www.ab-solution.info/hostslist/malwaredomainlist_com.txt
-                                                    [ <=>        ]       0  --.-KB/s    in 0s
 file 5 download failed or file is not hosts file, using backup file
 file preprocessing took 13 seconds
 sorting, removing whitelist entries
 this will take about 9 seconds...
 your RT-AC3100 did this in 4 seconds
 updating blocking file took 17 seconds
 69143 domains are now blocked
Just a minute, my auto-downloader must have timed out.
I'll upload the malware hosts file manually.
This www.malwaredomainlist.com has a long response time lately.
Fixed, uploaded valid latest file.
For Skynet users, v5.6.0 has been released which works hand in hand with the current Beta and the new "Plus" content @thelonelycoder added. Let us know how it goes.
Thank you for the update testing now with ab-solution blocking files 8 which gives 10 hosts files. I must say it kicked up my ram usage but still do not need a swap file.
Still have great access. Nothing I need blocked. I have not rebooted yet will that change things?
Over all memory on my router has increase by 5% not anything to get excited about and definitely doesn't need a swap.
Over all memory usage at 43% on my AC3100.
After changing the AB blocking file type, updating the blocking list will be enough on that end. For Skynet running banmalware will clean out the redundant entries. No hard reboot should be needed.
In our testing I found the extra lists added a temporary 50MB memory increase, which was later reduced to 20MB once caches were cleared. Realistically the only device that should need a SWAP file is the AC86U which was already a requirement for Skynet beforehand anyway, but having one in place as a backup measure never hurts.
Installed 3.10.2 beta with shooter40sw+. So far so good.
The RAM usage is about 82% in my AC though. Hopefully after clearing cache it will get reduced.
Also on shooter40sw+ (the + indicates the additional hosts selected) on my AC1900P on 380.69_alpha1 shows 33%, about 83 MB with Skynet installed.
This is after the regular caches flush, set in Tools/Other Settings under "Memory Management: Regularly flush caches (default: Yes)".
I have a swap file on that device, regardless of memory usage for development reasons.
I just found out that you have a new Beta 3.10.2 available. Didn't know this since the title of this thread still says 3.9.x
Will have to check it out this weekend.
I could rename it but I am not sure if this will break notifications for those that have it set up.
RMerlin says it does for some if you do.
I have the Memory Management set to Regularly flush caches too. I have stable 74% usage at 185MB. I guess the usage is almost double because I have IPV6 enabled.
@Adamm
What blocking file type are you referring to? I came across that and didn't know what to do so I kept original type, what are you recommending here?
Quick question to @thelonelycoder
 A B - S O L U T I O N        A D - B L O C K I N G
 AB-Solution 3.10.2 beta          by thelonelycoder
 RT-AC68U (armv7l) fw-380.68 @ 192.168.1.1
 518,470  blocked domains  10  hosts files in use
 124,690 t  5,309 w  155 n ads since Dec 08 16:34
beta URL  ab-solution.info/beta  Beta hosts [off]
How do I turn beta hosts to on? Or is that a feature of 382.1_2?
