Adamm
Part of the Furniture
What blocking file type are you referring to? I came across that and didn't know what to do so I kept original type, what are you recommending here?
Under block file options you will see a new entry (8);
The blocking file type does not need to change, you need to enable additional hosts. In b select 8 to enable them.@AdammWhat blocking file type are you referring to? I came across that and didn't know what to do so I kept original type, what are you recommending here?Code:After changing the AB blocking file type, updating the blocking list will be enough on that end. For Skynet running banmalware will clean out the redundant entries. No hard reboot should be needed.
In the same menu where you enabled the beta. Enter beta again and '2. Set which hosts files to use'.Quick question to @thelonelycoder
How do I turn beta hosts to on? Or is that a feature of 382.1_2?Code:A B - S O L U T I O N A D - B L O C K I N G AB-Solution 3.10.2 beta by thelonelycoder ---------------------------------------------------- RT-AC68U (armv7l) fw-380.68 @ 192.168.1.1 ---------------------------------------------------- 518,470 blocked domains 10 hosts files in use 124,690 t 5,309 w 155 n ads since Dec 08 16:34 ---------------------------------------------------- beta URL ab-solution.info/beta Beta hosts [off]
AB-Solution 3.11 is now available through the beta and release channel
Use cu to update.
Beta testers using the beta hosts files, it is best to now reset to '2. Standard (live URL)' in the beta option.
Welcome To SNBForums
