Is it expected 55k/64k usage on a clean reset?
Hello RMerlin,
I've been toying with my AC87U on your latest firmware and its IPV6. I'm using native dhcp-pd ipv6 over PPP. The problem is to make it work I need to log in via SSH and add:
For IPV6 to be reachable by my clients.Code:ip -6 route add default dev ppp0 metric 256
Is it possible to add it to some kind of post PPPOE init script by so that it is done by default? This route is missing without the command and WAN IPv6 Gateway in status is empty. After adding the route it changes to: "::" and I get native ipv6 support
any chance to edit iptv vlan code?
strange, you can edit and change everything in firmware...
No he (and you) can't (closed source components) and in some case does not want to, taking into account the massive impact some changes may have in other pieces of codes (or relationship with closed source parts)....strange, you can edit and change everything in firmware...
Me too. Too many issues with scanners and sonos on this ASUS code. I've logged an official complaint with ASUS, but who knows where that will lead....I found all of these issues when I installed the official Asus firmware 4180 . . . Merlin merged in 4180 with beta 1 I believe which explains it. It seems I will be skipping this release until Asus fixes some of these bugs.
Sorry for the duplication but could someone else try it or copy here their rules (should they be using pppoe with native ipv6). With above route Windows machines start working like charm with ipv6. I'm still debugging Android's SLAAC sloppy network after enabling such ipv6.
Cheers,
Ankh
Same problem here! Btw, took me some time to figure out![]()
Would this work?Would it be possible for you to lessen the frequency of the DNS polling to dns.msftncsi.com? The following are recent stats from AB-Solution:
Router 1 (next most frequent host just over 400):
The top 10 requested hosts were:
79888 dns.msftncsi.com
Router 2 (next most frequent host just over 2000 (i.e., trendmicro)):
44918 dns.msftncsi.com
Would this work?
nvram set dns_probe_content=0.0.0.0
nvram set dns_probe_host=""
nvram commit
reboot
Verstuurd vanaf mijn SM-G935F met Tapatalk
nvram set dns_probe_content=""
nvram commit
AB-Solution 3.1 will have an 'experimental settings' menu.The proper way to disable it is by clearing dns_probe_content. Wanduck will then consider the probe as being disabled.
Welcome To SNBForums
