Zastoff
Openvpn Server/Client working fine for meHi, a question. I assume that if using only OpenVPN server I will not be affected by this, right ? ..just to evaluate if I can afford to test this beta...
![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
+1Openvpn Server/Client working fine for me![]()
Using 384.12, I've been testing using the $PARAM with and without the quotes using the vpnrouting.sh script that was modified in Beta 1. The parameters are passed to openvpn-event with no issues. I reverted back to the 384.13 Beta version of vpnrouting.sh and no issues.Okey, I have use mine scripts for years with no problem. Revert to Alpha2 start working again. All script is chmode 0755
I have this in log:
Code:Error: an inet prefix is expected rather than "217.64.xx.xx via 158.174.xxx.x dev eth0". Error: an inet prefix is expected rather than "158.174.xxx.x dev eth0 proto kernel scope link". Error: an inet prefix is expected rather than "192.168.12.0/24 dev br0 proto kernel scope link src 192.168.12.1". Error: an inet prefix is expected rather than "10.8.40.0/24 dev tun22 proto kernel scope link src 10.8.40.1". Error: an inet prefix is expected rather than "158.174.xxx.x/22 dev eth0 proto kernel scope link src 158.174.xxx.x". Error: an inet prefix is expected rather than "10.128.0.0/16 dev tun11 proto kernel scope link src 10.128.xxx.xx". Error: an inet prefix is expected rather than "10.129.0.0/16 dev tun13 proto kernel scope link src 10.129.xxx.xxx". Error: an inet prefix is expected rather than "127.0.0.0/8 dev lo scope link". Error: an inet prefix is expected rather than "0.0.0.0/1 via 10.128.0.1 dev tun11". Error: an inet prefix is expected rather than "128.0.0.0/1 via 10.128.0.1 dev tun11". Error: an inet prefix is expected rather than "default via 158.174.xxx.x dev eth0". RTNETLINK answers: No such process
Code:#!/bin/sh scr_name="$(basename $0)[$$]" wan_gw=$(nvram get wan0_gateway) wan_ip=$(nvram get wan0_ipaddr) wan_if=$(nvram get wan0_ifname) # Determine caller case "$1" in "tun11") vpn_name="client1" ;; "tun12") vpn_name="client2" ;; "tun13") vpn_name="client3" ;; "tun14") vpn_name="client4" ;; "tun15") vpn_name="client5" ;; "tun21") vpn_name="server1" ;; "tun22") vpn_name="server2" ;; *) vpn_name="" ;; esac # Call appropriate script based on script_type vpn_script_name="vpn$vpn_name-$script_type" vpn_script_log="/tmp/vpn${vpn_name}_state" # Check script state # vpn_script_state=$(cat $vpn_script_log) vpn_script_state=$(cat $vpn_script_log 2>/dev/null) if [ "$vpn_script_name" = "$vpn_script_state" ]; then # echo "VPN script" $vpn_script_name "already run" | logger -t "$scr_name" echo " ***VPN script" $vpn_script_name "already run" | logger -t "$scr_name" exit 0 fi # Execute and log script state if [[ -f "/jffs/scripts/$vpn_script_name" ]]; then echo " Script executing.. for VPN event: "$vpn_script_name | logger -t $scr_name echo "$vpn_script_name" > $vpn_script_log /bin/sh /jffs/scripts/$vpn_script_name $* else # echo "Script not defined for event: "$vpn_script_name | logger -t $scr_name echo " Script not defined for VPN event: "$vpn_script_name | logger -t $scr_name exit 0 fi exit 0
echo $@ >> /jffs/scripts/logger
tun13 1500 1584 10.31.0.10 10.31.0.9
tun11 1500 1584 10.24.0.18 10.24.0.17 init
tun11 1500 1584 10.24.0.14 10.24.0.13 init
tun15 1500 1585 10.35.0.6 10.35.0.5 init
tun15 1500 1585 10.35.0.14 10.35.0.13 init
tun15 1500 1585 10.35.0.18 10.35.0.17 init
####################### firmware vpnrouting.sh
tun15 1500 1585 10.35.0.10 10.35.0.9 init
#!/bin/sh
# Script: openvpn-event
# Author: Xentrk
# Last Updated Date: 3-June-2019
# Description:
# Original Script by John9527:
# https://www.snbforums.com/threads/fork-asuswrt-merlin-374-43-lts-releases-v39e3.18914/page-238#post-294825
# Modified by Xentrk for x3mRouting project
# shellcheck disable=SC2154
PROJECT_REPO="/jffs/scripts/x3mRouting"
scr_name="$(basename "$0")[$$]"
case "$1" in
"tun11")
vpn_name="client1"
"tun12")
vpn_name="client2"
"tun13")
vpn_name="client3"
"tun14")
vpn_name="client4"
"tun15")
vpn_name="client5"
"tun21")
vpn_name="server1"
"tun22")
vpn_name="server2"
vpn_name=""
esac
vpn_script_name=vpn"$vpn_name"-"$script_type"
# Check script state/use nvram to save last script run
vpn_script_state=$(nvram get vpn_script_state)
nvram set vpn_script_state="$vpn_script_name"
echo "VPN script" "$vpn_script_name" "already run" | logger -t "$scr_name"
exit 0
fi
if [ -f "$PROJECT_REPO/$vpn_script_name" ]; then
echo "Running $PROJECT_REPO/$vpn_script_name $*" | logger -t "$scr_name"
sh $PROJECT_REPO/"$vpn_script_name" "$*"
else
echo "Script not defined for event: ""$vpn_script_name" | logger -t "$scr_name"
exit 0
fi
exit 0
There is nothing wrong with these results.
Mh okay, I was confused because of the resulsts from merlin here:There is nothing wrong with these results.
I get the exact same results as you.Mh okay, I was confused because of the resulsts from merlin here:
https://www.snbforums.com/threads/e...-13-test-aimesh-dnssec-through-openssl.57489/
I believe that’s his results from his ISP. I get same results with Cloudflare as you and @skeal do.Mh okay, I was confused because of the resulsts from merlin here:
Sincere apologies for the error. Not sure why I haven't experienced the issue. I'll do some more testing this weekend. I have been running the code for nearly a year and haven't had an issue with the quoted $PARAM line. I will revisit and look into more in-depth.
Code:run_custom_script() { if [ -f /jffs/scripts/openvpn-event ]; then /usr/bin/logger -t "custom_script" "Running /jffs/scripts/openvpn-event (args: $PARAM)" /bin/sh /jffs/scripts/openvpn-event "$PARAM" fi }
Installed on AX88U and set as Mesh Router. Using AC68U on stock firmware as node. When searching for updates I get "Unable to connect to the update server."
I will flash to the Beta firmware tomorrow to see if I can spot where the issue is occurring.
Thanks for this, everything seems to be running ok with my setup Primary 86U with node Rog 5300. Just one thing I have a USB hard drive hooked up to the 5300, how can my clients see that now? As it cannot be seen
DNSSEC validation is done as a chain. If your upstream server lacks support for a specific crypto, it might pass a failing result to dnsmasq, which cannot "unfail" it.
USB sharing can only be done from the primary router, since nodes cannot be separately accessed by the clients.
Welcome To SNBForums
