Hawk
Not a typo, Delusion compiled firmware.384.12 beta 2. Typo?
It works fine on RTAX88U, you need to enable data collection first.I have been on the Beta for more than a week and so far encountered no issues (still having AX, 160Mhz and DFS disabled).
Can I ask if the Wireless Site Survey section is working well for everyone? It is showing no measurements at all in my case.
Hmm, I overlooked it.It was a typo. "Asus RT-AC86U-Firmware Version: 384.14_beta2 (Compile date: 24/11)"
384.12 != 384.14
31efcf7a90 Updated documentation
1589bacedf rc: fix _unlock_erase() return value to match with the rest of the code
5780fb5f8b socat: that is one fat cat, put him on a diet by removing unused features
461cbf34a7 rc: ipv6 ns drop checking wrong nvram for dualwan/multiiptv builds
4b799f4217 rc: silence a few modprobe failures (these either do not exist or are built-in)
94c1890814 Bumped revision to beta 2
35c3d046f7 Updated documentation
ed5fe541ee rc: inadyn: always force AsusDDNS updates on LE-enabled build
fcf39c96c3 inadyn: minor logging changes to Asus DDNS pplugin
1d7eee1063 rc: tell inadyn to accept any SSL cert when using Asus DDNS
a73a8eaed0 letsencrypt: backport new LE support from 384_81351 for AX branch
197ea60300 Revert "dnsmasq: update to 2.80-93-g6ebdc95"
41f01b9346 socat: that is one fat cat, put him on a diet by removing unused features
3c81fa4543 rc: silence a few modprobe failures (these either do not exist or are built-in)
1795fcf34b rc: migrate AP hostname from computer_name to lan_hostname
6c41f71cd2 rc: remove obsolete conn_diag.o blob
fbbc20f31f Merged RT-AC68U binary blobs + SDK from 384_81351
bd000fe9b7 Merge with GPL 384_81351 + binary blobs (RT-AC86U)
RMerlin,Thank you. Looks like Asus broke things with 384_6436. If the router is set to erase the JFFS content, it will unlock the JFS partition for writing, however it now incorrectly checks whether this was successful or not. I'll fix it, please give it another try once beta 2 is released.
Where is this new GPL code (384_81351) coming from for the AC88U? I don't see it on Asus's updates page.
GPL from 86U, most likely.- UPDATED: RT-AC88U, RT-AC3100 to GPL 384_81351 and binary blobs from 384_81116
Nov 24 19:38:33 RT-AC86U-4608 inadyn[7016]: Update forced for alias myrouter.asuscomm.com, new IP# xx.xx.xx.xx
Nov 24 19:38:34 RT-AC86U-4608 inadyn[7016]: Certificate verification error:num=10:certificate has expired:depth=0:/CN=ns1.asuscomm.com
Nov 24 19:38:34 RT-AC86U-4608 inadyn[7016]: Updating cache for myrouter.asuscomm.com
AC86U 384.14 beta 2
Is the "Certificate verification error:num=10:certificate has expired:depth=0:/CN=ns1.asuscomm.com" an issue?
NOTE - myrouter.asuscomm.com is not the real DDNS name I use.
Code:Nov 24 19:38:33 RT-AC86U-4608 inadyn[7016]: Update forced for alias myrouter.asuscomm.com, new IP# xx.xx.xx.xx Nov 24 19:38:34 RT-AC86U-4608 inadyn[7016]: Certificate verification error:num=10:certificate has expired:depth=0:/CN=ns1.asuscomm.com Nov 24 19:38:34 RT-AC86U-4608 inadyn[7016]: Updating cache for myrouter.asuscomm.com
RT-AX88U:
Which diet you recommend for this socat?Code:5780fb5f8b socat: that is one fat cat, put him on a diet by removing unused features
- Beta 2 DNS/DHCP stability on RT-AX88U - does dnsmasq still randomly stops answering queries?
I like it you're right on it.
But what is happening if I do all this?
I love to test this procedure but to be all clear of what the problem is:
When running latest stable merlin all is ok.
When running ...14 beta 1 the problem occure with no wan connection and the Wan-Led flickering red and blue -》 allmoust in violet.
Rt ac66u B1
Did I miss some thing?
I'm not a tech-retard but I'm still in the beginning of the learning curve regarding merlin-lingo and so on. Just to explain in whitch level I am.
Regards
Jonas
Ps. Thanks for puting energy on this ds.
Skickat från min SM-G955F via Tapatalk
No issues detected. 30% improvement on Wireless 2.4ghz. Running smooth.Beta 2: Look for any new issues following the merge of newer GPL code on
Nov 25 06:53:52 start_ddns: update WWW.ASUS.COM update@asus.com, wan_unit 0
Nov 25 06:53:52 inadyn[1467]: In-a-dyn version 2.5 -- Dynamic DNS update client.
Nov 25 06:53:52 inadyn[1467]: /etc/inadyn.conf:4: unexpected token '='
Nov 25 06:53:52 inadyn[1467]: Parse error in /etc/inadyn.conf
Nov 25 06:53:52 inadyn[1467]: Error code 74: Missing .conf file
Welcome To SNBForums
