Clark Griswald
Beta 3 is up
106c8fdc63 inadyn: re-disable cert validation for AsusDDNS - their server is once again using an expired certificate
31b6e0c7be Merge branch 'master' into mainline
e9d5a74edd Bumped revision to beta 3
979171cfeb Updated documentation
0493c9b280 webui: fix malformed Certificate label on DDNS page
935c9e8e29 webui: update popup help for local DNS queries to match the current default behaviour
498663aed4 openvpn: do not run openvpn-event if custom scripts are disabled
6c0ef79e93 kernel: backport 81351 kernel fixes to L2TP to the sdk7.x kernel
b709848521 kernel: backport 81351 kernel fixes to L2TP to the sdk7114 kernel
633622542c rp-l2tp: fix server route can't be added w/o ifname
f5f43d48ac dnsmasq: update to 2.80-95-g1aef66b
672b6b8758 Updated documentation
6ce31ebb13 inadyn: switch Asus DDNS server to ns1.asuscomm.com since their server certificate is missing the nwsrv-ns1.asus.com SAN; re-enable certificate validation when updating an Asus DDNS account
6147885ff9 Restore generic ARM prebuilts from 384_81351, which were accidentally downgraded by the RT-AC5300 81219 component merge in commit 19f730920271bb4c354d4282c3dccd340fbb59d3
6483e2c750 webui: rc: harmonize max ntp server length with upstream, and ensure (legacy) ntp code has a matching buffer size
89ebb9a624 webui: replace broken isPortConflict() with new function; added missing pwrsave code on System page
19f7309202 Merge RT-AC5300 binary blobs from 384_81219
Beta 3 has been uploaded (and should appear on mirrors in the coming minutes). Changes since beta 2:
Code:106c8fdc63 inadyn: re-disable cert validation for AsusDDNS - their server is once again using an expired certificate 31b6e0c7be Merge branch 'master' into mainline e9d5a74edd Bumped revision to beta 3 979171cfeb Updated documentation 0493c9b280 webui: fix malformed Certificate label on DDNS page 935c9e8e29 webui: update popup help for local DNS queries to match the current default behaviour 498663aed4 openvpn: do not run openvpn-event if custom scripts are disabled 6c0ef79e93 kernel: backport 81351 kernel fixes to L2TP to the sdk7.x kernel b709848521 kernel: backport 81351 kernel fixes to L2TP to the sdk7114 kernel 633622542c rp-l2tp: fix server route can't be added w/o ifname f5f43d48ac dnsmasq: update to 2.80-95-g1aef66b 672b6b8758 Updated documentation 6ce31ebb13 inadyn: switch Asus DDNS server to ns1.asuscomm.com since their server certificate is missing the nwsrv-ns1.asus.com SAN; re-enable certificate validation when updating an Asus DDNS account 6147885ff9 Restore generic ARM prebuilts from 384_81351, which were accidentally downgraded by the RT-AC5300 81219 component merge in commit 19f730920271bb4c354d4282c3dccd340fbb59d3 6483e2c750 webui: rc: harmonize max ntp server length with upstream, and ensure (legacy) ntp code has a matching buffer size 89ebb9a624 webui: replace broken isPortConflict() with new function; added missing pwrsave code on System page 19f7309202 Merge RT-AC5300 binary blobs from 384_81219
Things to test:
- DNS/DHCP, especially on the RT-AC86U and RT-AX88U (dnsmasq was re-upgraded, with an additional fix from upstream, hopefully resolving former crashes)
- RT-AC5300 in general
Are you able to compile these changes for RT-AX88U from GPL 7756 for us that doesn't need QOS? If not, no big deal I can wait for the next Alpha release.Beta 3 has been uploaded (and should appear on mirrors in the coming minutes). Changes since beta 2:
UPDATED: RT-AX88U to GPL 384_6436 (with Let's Encrypt fixes
backported from 384_81351)
From Beta 3 changelog-NG:
Code:UPDATED: RT-AX88U to GPL 384_6436 (with Let's Encrypt fixes backported from 384_81351)
Eric for RT-AX88U which GPL it is using 7756 or 6436.
Ah I see, hopefully 384.15 will have it fixed, assuming Asus release new GPL and have it fixed.6436. 7756 is too buggy.
Same here, I am not using QOS and any Trend micro stuff and so far thing are working well. Only message I am getting error adding multicast, but that is to expected since it is disabled when I add IPTV.Keeping my 7756 based AX88 firmware for now unless there is a good reason to change (so far no stability issues as far as I've noticed. Havn't checked logs for errors though)
Found this in the middle of the creation of the /jffs/.le/(user name).asuscomm.comMore problems with Letsencrypt:
Code:Status : Authorizing Issued to : SAN : undefined Issued by : Expires on :
Dec 7 13:11:32 kernel: Cert success.
Dec 7 13:11:32 kernel: cat: write error: Invalid argument
No.Is there any wpa3 or ax support in beta 3
Welcome To SNBForums
