[Beta] RT-AC87U/RT-AC3200 9.0.0.4_378_9481 Beta for checking bug in Traffic Analyzer -> Statistic
Next bug.
When slelect DISPLAY FOR APPS and have selected ALL APPS show data usage and top 5 apps used. On screen see that SSL/TLS usage data (screen 1).
Then i select from ALL APPS to SSL/TLS and nothing show ( screen 2)
Hi
7. when "Display for" is app, and change "All apps" to any app type (ex. Dropbox), traffic shows nothing.
=> fixed in beta firmware 9.0.0.4_378_9366 (updated in 2015/11/24)
8. when "Display for" is app, and change "All apps" to any app type (ex. Dropbox), sub-traffic chart has wrong title.
9. when "Display for" is app, and change "All apps" to any app type (ex. Dropbox), and select back "Display for" is router, show nothing.
10. when "Display for" is app, select the fifth app in top 5 chart, and then change "Display for" back to router, if router's client is less than 4 client, will show the old fifth app traffic in top 5 chart.
All probably looks ok :)
I found next bug. I have Samsung Galaxy S6 SM-G920F and when i have display for ROUTER and click on something for this client(example: HTTP Protocol) open window with clank name CLIENT(select on screen in RED color:
For other client example my switch Cisco SG200-08 i click on NTP and show ok name cllient:
With this is still problem
VANIC when you go on source Code 380.721 ? Now i test 9.0.0.4.380.721 and in this beta TA is broken. But This beta has new driver and maybe resolved problem with 5G Radio problem. Maybe go to new code.
Hi all,
GUI merge is incomplete, I will release new beta firmware ASAP.
Thanks,
Vanic
Hi Vanic,
Can you be more clear about when you post new beta firmware. It's unclear from the original link what version we are on, and when we should download again. Perhaps a date note. Also, you indicated you were going to release new code ASAP, but I'm unclear if you have done that already, or the older code is still there. Thanks!
Hi all,
The link is always the same, never changed. When the title changed, the firmware must be updated into this link. Beta firmware is in 378-xxx only, after verifying [Traffic analyzer issue] fixed, we will merge back into 380-xxx. It's the develop flow in software side.
Thanks,
Vanic
When I bring up the initial screen, the data of app by client is correct, however, the final pie slice (around 11pm) is far too big. When I hover over it, it has the correct data.
Also, if I have it set up for daily, the hours on the bottom of the graph are not that intuitive. you may want to add an indicator. Are you using a 24 hour clock?
Hi all,
Is there anyone encountering the browser compatible issue? ex. Safari / IE / firefox / Chrome? Chrome should be fine because of all testing is verified in Chrome. If you encounter issue, please inform me and attach the picture.
Thanks,
Vanic
Hi woppoer,
Could you help to try switch page between Traffic Analyzer and Adaptive QoS? Do you find any problem?
Someone feedback me there is something wrong.
Thanks,
Vanic
I will send you some screenshots by PM, because i don't have time to hide all the names and don't want to post them public. Then you can see it yourself that is seems ok.
Hi woppoer,
It's no problem, thanks for your support!!
Thanks,
Vanic
Hi.
Any changes in WIFI code in this build ? For now my phones not connect automaticly after scheduler on my WIFI 2.4Ghz ?
On 9313 and 9332 i have no problem.
this user can be safely ignored. his problem has nothing to do with traffic analyser..
You too can be safely ignored , because you have nothing to say about TA..
ps.
There is little difference between us. I have tested TA , you are only a spammer .
Hi all,
Is there any new bugs or issues? I have done the patches into main trunk of asuswrt. The next normal release will include all bug fixes in my thread. If you find the release number is larger than mine(378_9366), it should be done. The firmware with 380-xxx is only for AC88U/AC3100/AC5300 now and they also include these bug fixes.
Thanks,
Vanic
But beta 380.xxxx is also now available for AC87U
Wysłane z mojego SM-G920F przy użyciu Tapatalka
Jetzt bin ich betrogen Benutzer von ASUS!
Your comments go to me already on my nerves.
If not satisfied with Asus to sell routers and switch to other manufacturers.
PS: Thanks, that ASUS has stop beta program to puplic. That comes only from your really inappropriate messages.
