[Beta] RT-AC87U/RT-AC3200 9.0.0.4_378_9481 Beta for checking bug in Traffic Analyzer -> Statistic
But what with LInk Aggregation in model RT-AC87U ? It support this as ASUS write on case. But FW not support this. When ASUS implement this features as implement in RT-AC88U ?
Now i am cheated user by ASUS !
You must have asked nearly a dozen time about Link Aggregation, and have received numerous responses already. So beside the fact that this is completely off-topic to this thread, please stop repeating the same requests over and over. This has reached public harassment levels by now.
Consider this your final warning on this matter.
Hi vanic.
Hi all,
Is there any new bugs or issues? I have done the patches into main trunk of asuswrt. The next normal release will include all bug fixes in my thread. If you find the release number is larger than mine(378_9366), it should be done. The firmware with 380-xxx is only for AC88U/AC3100/AC5300 now and they also include these bug fixes.
Thanks,
Vanic
For me TA now work ok. When i select date i see traffic from this date, no traffic from the future, colors work ok.
Great work vanic THX
One suggestion
First enter in TA, and we see last 24h (until current hour).
Maybe should be lilke when we select again the same date, from 1h to 0h (full day).
It's only my suggestion.
Best regards
VANT
Hi vanic.
One suggestion
Best regards
VANT
Hi VANT,
Thanks for your suggestion, and traffic data seems to correct, I won't do any modification recently.
Thanks,
Vanic
Maybe good option is add to GUI button to clear database ?
I tested you FW on:
Chrome 47.0.2526.73
Firefox 40.0.3
IE 11.0.10240.16384
and on all seems that works OK. Good JOB
I tested you FW on:
Chrome 47.0.2526.73
Firefox 40.0.3
IE 11.0.10240.16384
Hi all,
Thanks for your suggestion about GUI modification, we will consider in the future. And we are proceeding to refine some GUI style now.
Thanks,
Vanic
Suggestion: (2015/12/02)
1. time scale change into 0~23, not 1~0
=> not to modify, but we will consider in future work
Thanks,
Vanic
Hi vanic
for clarity about this "time scale"
In my previous post we see time scale from 0h to 23 when we do first enter in TA, but when we enter in TA now (about 12h) we see time scale from 13h yesterday to 12h today.
I think that also first enter in TA should show fixed time scale for all. I think that time scale from 1h to 0h is ok but should be show always even we enter first time in TA
Hi vanic
I know what you mean about this picture and question, this is GUI design, someone likes and someone don't, we don't change anything now.
Hi all,
Add information here. Please don't ask or feedback RT-AC68U issue and question here. I will ignore. If you want to feedback VP and FTP issue, please send mail to router_feedback@asus.com and add tiltle [AiProtection for Vanic].
Others: (2015/12/04)
Update RT-AC68U beta firmware here, it's only for AiProtection VP and FTP issue, and it includes all bug fixes here. Don't feedback any information here, please mail or have a conversation with me, make this thread clean.
Thanks,
Vanic
Hi all,
Thanks,
Vanic
Hey Vanic, thanks once again for getting a firmware done for my model. Unfortunately when i enable the AiProtection -> Vulnerability Protection, i am still unable to connect to a server via ftpes. Disabling that protection then allows me to connect.
Thanks,
Vanic
Running the 9366 build now, but I'm still seeing an issue with AiProtection | Parental Controls | Time Scheduling, where since build 9177 and up I've not been able to make changes to the schedule or even add/remove clients. Would be really nice to have this working again, it's a big reason why I got this router, plus the extreme range of the 2.4 Ghz. I keep having to roll back to 7410 to manage the settings. I like the new features, especially the Asus router tool on my tablet, which is not compatiable with the older build...
what bug in Time Scheduling ? I use this feature and work for me.
when I go to edit the Hours for a client, when I click ok, the screen immediately goes back to the Logon page and I have to sign back in. I've tested with FF, IE and Chrome, same thing. I believe I did a reset before, but whats your recommended procedure, just hold the reset button down for 5+ seconds, or do I need to do some sort of power thing?
As already mentioned by Vanic, this build is *ONLY* for debugging Traffic Analyzer.
Vanic is the one in a support email requesting that I try this build as there were a number of fixes. However, this wasn't one of them apparently. Bothered that it's not encountered by others, which has me wondering if I did the reset on my 87U incorrectly.
Try accessing your router by its IP instead of by a hostname if you weren't already.
never even knew it had a hostname, I've only ever used the IP. If it helps, when I try and change or set items in Time Management, these show up in the system log when it crashes and kicks me back to the logon page. There are other spots in the website that also will punt me, going to LAN and the DHCP Server tab also kicks me out and throws the same entries in the system log below.
Dec 10 14:19:07 watchdog: restart httpd
Dec 10 14:19:07 rc_service: watchdog 431:notify_rc start_httpd
Dec 10 14:19:07 RT-AC87U: start httpd
Dec 10 14:22:37 watchdog: restart httpd
Dec 10 14:22:37 rc_service: watchdog 431:notify_rc start_httpd
Dec 10 14:22:37 RT-AC87U: start httpd
Dec 10 14:24:37 watchdog: restart httpd
Dec 10 14:24:37 rc_service: watchdog 431:notify_rc start_httpd
Dec 10 14:24:37 RT-AC87U: start httpd
This confirms that something is causing your router's web server to crash. I suspect it's the previously reported issue related to some clients on your network having a long device name, causing the web server to crash. Asus fixed part of it in 9313, but there are a few other scenarios that they haven't fixed yet in that version.
You can give my firmware a try, those issues should be fixed in it.
