Diversion Diversion - the Router Ad-Blocker
Sorry I don't understand that question.
I have an actual asus RT-ac68u running latest Merlin firmware.
Diversion I've had a for a while but never played beyond the 'default' pixelserv-tls, saw the mention of updating for IOS13 so thought I'd do it but it fails to update as mentioned.
Can you try downloading the ipk from my Github, transferring to the router and install directly with opkg install package.ipk?
Actually purchased and labeled as an RT-AC68, not a converted TM-AC1900. The latter is not supported and not guaranteed to work.
I can't seem to update the pixelserv-tls software to Jack Yaz's version.
Have Diversion 4.1.4 running on Firmware 384.13 on a AC68U
On the front page of Diversion it reports pixelserv-tls 192.168.1.2 likely v.Kk
Option ep > 6 >3 > 3 > 1
Says downloading, download successful then briefly something else which I guess is installing then back to the Diversion front screen and "Done Failed to update pixelserv-tls"
Any ideas or log to look at?
Try to update and upgrade Entware packages in ep, 6 first.
ok so did this, now when I try I see
i Downloading pixelserv-tls
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 626 0 626 0 0 701 0 --:--:-- --:--:-- --:--:-- 785
100 25422 100 25422 0 0 14330 0 0:00:01 0:00:01 --:--:-- 56619
i Download successful, installing...
Not downgrading package pixelserv-tls on root from V35.HZ12.Ki-1 to 2.3.0-1.
pixelserv-tls: error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory
Hmm when I run diversion now I also see at the top
and it says not running
ep pixelserv-tls 192.168.1.2 (not running)
Try updating entware packages through diversion in that case
If I perform an update installed packages or update and upgrade installed packages I get
downloading http://bin.entware.net/armv7sf-k2.6/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
Starting pixelserv-tls (Diversion)... failed
pixelserv-tls info gives me this
pixelserv-tls info:
Package: pixelserv-tls
Version: 2.2.1-1
Depends: libc, libssp, librt, libpthread, libopenssl, libpthread
Status: unknown ok not-installed
Section: net
Architecture: armv7-2.6
Filename: pixelserv-tls_2.2.1-1_armv7-2.6.ipk
Description: pixelserv-tls is a tiny bespoke webserver for adblock with HTTP/1.1 and HTTPS support
Version: V35.HZ12.Ki-1
Status: install user installed
Architecture: armv7soft
Installed-Time: 1478641985
pixelserv-tls info:
Version: 2.2.1-1
Section: net
Try opkg install openssl
if I run openssl it runs
OpenSSL> version
OpenSSL 1.0.2s 28 May 2019
opkg install libopenssl
Package libopenssl (1.1.1b-5) installed in root is up to date.
Installed Entware packages:
entware-opt - 227000-3
entware-release - 1.0-2
entware-upgrade - 1.0-1
findutils - 4.6.0-3
grep - 3.3-1
ldconfig - 2.23-8
libc - 2.23-8
libgcc - 7.4.0-8
libopenssl - 1.1.1b-5
libpcre - 8.43-1
libpthread - 2.23-8
librt - 2.23-8
libssp - 7.4.0-8
libstdcpp - 7.4.0-8
locales - 2.23-8
opkg - 2019-01-31-d4ba162b-1
pixelserv-tls - V35.HZ12.Ki-1
terminfo - 6.1-4
zlib - 1.2.11-3
zoneinfo-asia - 2019a-1
zoneinfo-europe - 2019a-10
Am I somehow at a higher version?
Openssl is a library file, try
This is what I have installed.
@RT-AC68U-1DA8:/tmp/home/root# opkg update
Downloading http://bin.entware.net/armv7sf-k2.6/Packages.gz
@RT-AC68U-1DA8:/tmp/home/root# opkg upgrade
@RT-AC68U-1DA8:/tmp/home/root# openssl
OpenSSL> version
OpenSSL> exit
@RT-AC68U-1DA8:/tmp/home/root# opkg install libopenssl
@RT-AC68U-1DA8:/tmp/home/root# opkg install openssl
Unknown package 'openssl'.
Collected errors:
* opkg_install_cmd: Cannot install package openssl.
Try this and let us know the result, please.
opkg list-installed | grep openssl
@RT-AC68U-1DA8:/tmp/home/root# opkg list-installed | grep openssl
That is the newest and current, the same one I have with pixelserv-tls - 2.3.0-1
Try this:
opkg install pixelserv-tls --force-reinstall
Then in Diversion ep then "4. Restart pixelserv-tls"
Sorry I'm not having much luck here :(
@RT-AC68U-1DA8:/tmp/home/root# opkg install pixelserv-tls --force-reinstall
No packages removed.
Installing pixelserv-tls (V35.HZ12.Ki-1) to root...
Collected errors:
* opkg_download_pkg: Package pixelserv-tls is not available from any configured src.
* opkg_install_pkg: Failed to download pixelserv-tls. Perhaps you need to run 'opkg update'?
* opkg_install_cmd: Cannot install package pixelserv-tls.
I'm out of ideas, too, sorry. I've searched back in the thread, I remember this happening to others before. Someone will come back with a solution, maybe even the @thelonelycoder himself. ;)
Hang in there, I know this will get solved.
So after this I went back into diversion did a few things trying to install etc.
I now no longer get when running Diversion
If I set pixelserv-tls to be disabled I see in Diversion
ep pixelserv-tls 192.168.1.2 v2.3.0
If I set pixelserv-tls to be enabled I see in Diversion (this is after it fails to start)
I did regenerate the cert
Creating new pixelserv-tls CA certificate
Generating RSA private key, 2048 bit long modulus
e is 65537 (0x10001)
✔ New pixelserv-tls CA certificate generated
i Purging pixelserv-tls domain certificates
If I try the upgrade/updates
vThis upgrades pixelserv-tls to v2.3.0, Jack Yaz version.
____________________________________________________
100 626 0 626 0 0 1079 0 --:--:-- --:--:-- --:--:-- 1140
100 25422 100 25422 0 0 19555 0 0:00:01 0:00:01 --:--:-- 37221
Package pixelserv-tls (2.3.0-1) installed in root is up to date.
This updates installed Entware packages.
Entware version: Entware (armv7)
Installed from: bin.entware.net
Enter selection [1-5 e=Exit] 5
Upgrading pixelserv-tls on root from 2.3.0-1 to V35.HZ12.Ki-1...
Collected errors:
