Diversion Diversion - the Router Ad-Blocker
are you seeing any dns queries to dnsmasq from the device? .... you should be able to see queries in the dnsmasq.log with the IP of your android tablet at the end. You can follow the dnsmasq log in diversion using f option 5 and enter the term googlevideo.com
May 10 06:48:19 dnsmasq[32061]: query[A] r5---sn-4wg7ln76.googlevideo.com from 192.168.1.193
May 10 22:15:46 dnsmasq[5803]: query[A] redirector.googlevideo.com from 192.168.1.193
May 10 22:15:46 dnsmasq[5803]: forwarded redirector.googlevideo.com to 8.8.4.4
May 10 22:15:46 dnsmasq[5803]: forwarded redirector.googlevideo.com to 8.8.8.8
May 10 22:15:46 dnsmasq[5803]: reply redirector.googlevideo.com is 216.58.210.238
RT-AC86U Merlin 384.17
@thelonelycoder thanks for your tremendous efforts, truly appreciated.
I come across a weird problem with Diversion in my device, when updating hosts or processing lists the router reboots.
I'm currently running the latest version with YouTube adblocking enabled.
So it can be seen here that your android device is using dnsmasq for dns queries which are being forwarded onto googles dns servers to resolve. But i don't see any requests for the ad domains.... are you getting ad domain requests from other devices when you view yt videos on them?
You have to forgive me as I don't know what I am exactly looking for but this is what I get from my secondary android tablet.
May 10 23:15:11 dnsmasq[5803]: query[A] r8---sn-cu-auoz.googlevideo.com from 192.168.1.96
May 10 23:15:11 dnsmasq[5803]: forwarded r8---sn-cu-auoz.googlevideo.com to 8.8.4.4
May 10 23:15:11 dnsmasq[5803]: reply r8---sn-cu-auoz.googlevideo.com is <CNAME>
May 10 23:15:11 dnsmasq[5803]: reply r8.sn-cu-auoz.googlevideo.com is 213.123.253.87
So your secondary tablet it making the ad domain requests ok...... i can't help thinking that there is some software on your primary tablet that is blocking these ad domain requests..... are you sure theres no ad blocking app on there already?
H Guys,
I have Diversion installed and enabled on my Asus RT-AC86U Merlin, I have also beta Youtube Adblock enabled. So far I see some addresses being logged against the browser or Youtube app on my iPad but I can still see ads on both browser and Youtube App for iOS. Video ads and right panel static ads within Youtube are visible?
@thelonelycoder just wanted to let you know, that as I've already mentioned before I got no ads so far on my fire tv stick which is great, but I do still get ads on mobile devices on YT. Just wanted to let you know.
Sent from my SM-A505W using Tapatalk
Ah I see, I spend all this time installing and configuring my router to mainly block the iPad Youtube ads :-/ Thanks for your reply
You have made possible that which was always claimed impossible.
I feel the excitement and energy in your post. It is well deserved and hard won.
I call upon fellow Diversion users to visit this link as Diversion has reached this major milestone!
https://diversion.ch/donate.html
Way off topic, but @thelonelycoder mentioned Bitcoin as a payment option...showing my age likely.....any recommendations on service provider (Canadian based say)....
[mention]thelonelycoder [/mention] Okay so a question just popped up in my mind.
Soppose YouTube or our ISP decides to change its YouTube Egde node IP address or the IP goes down for some reason wouldn't it breaks YouTube for us? because we're forcing the videos to playback from that set IP address of our local YouTube edge node. I believe we need another check in Diversion to circumvent such a situation and make it dig against the *.googlevideo.com domains every few hours/days to make sure the IP is still the same and in case we get a different one, edit the already populated YT block list to the newly fetched IP.
I haven't seen any such checks in your code, though it is possible I might've missed it if it's already there.
My kids are reporting that on their iPhones the YT videos are not loading any longer. An error message pops up saying that it can't load that content - press here to try again, which never works. So they went on the cellular network to circumvent the ad blocker. Any one else having this issue?
I'm having no problem with YT videos on my iPhone when connected to my home wireless network.
did you have redirector.googlevideo.com domain in your /opt/share/diversion/list/yt_blacklist file?
I happened to me using the unbound YT blocking script .... i started getting error messages and the videos wouldn't load until i removed the offending domain.
Not saying that's your issue with the diversion script but worth a look
I just wonder if the same method for blocking YT ads, could be used for other services like TuneIn, shoutcast, or even free Spotify. Ah Scheiße, probably not.
