The new version is giving me problems (asus rt-ac88u). First, if I go to the flexqos tab the graph isn't displaying correctly. Just 1 flat line (like there were no different classes). The problem isn't graphical. If if go to system log it keeps showing error logs and restart attempts, so it never gets enabled.
This gets even worse because with the new version if I make any kind of change that prompts a qos and firewall restart (i.e. adding a rule to the iptables in the webui; disable upnp (wan restart), etc.), the router kinda reboots (actually I think it says roaming start).
Now it's uninstalled because it was just rebooting all the time and acting funny. I tried the 386 and 384 firmware; uninstalling and installing flexqos.
Later tonight (when no one at home it's actually awake) I'll try it again and see what happens.
Is the new version supposed to prompt this "reboot" after you make any changes?
I've tried with the 386 firmware without flexqos and whatever I do it doesn't roam start.
But looking at the log, I guess it's the new flexqos together with 386.
So, with the 384 version it doesn't work, but it doesn't reboot. After installing-uninstalling, etc. I decided to try the 386 version and then it started rebooting (way more times than it shows in the log, for whatever reason the log didn't record/save everything), but as I've said, as soon as I can do whatever I want with the router without my family complaining, I'll be able to copy the log inmediately, not wait for hours (which shouldn't really matter, but the log right now is acting weird. Actually it's messing dates, I'm getting logs from May2020 and March 2021 all mixed up).
Mar 8 02:10:52 A.QoS: restart A.QoS because set_qos_conf / set_qos_on / setup rule fail
Mar 8 02:10:52 kernel: ioctl_iqos_op_config() fail!
Mar 8 02:10:53 A.QoS: qos_count=2, qos_check=1
Mar 8 02:10:53 kernel: ERR[__parse_app_rule:584] Failed to parse app rule catid value
Mar 8 02:10:53 kernel: ERR[parse_qos_conf:1045] Invalid config syntax at line 21.
Mar 8 02:10:53 kernel: ERR[ioctl_iqos_op_config:3609] parse qos_conf error!!
Mar 8 02:10:53 A.QoS: set_qos_conf fails
Mar 8 02:10:53 A.QoS: restart A.QoS because set_qos_conf / set_qos_on / setup rule fail
Mar 8 02:10:53 kernel: ioctl_iqos_op_config() fail!
Mar 8 02:10:53 custom_script: Running /jffs/scripts/service-event-end (args: restart qos)
Mar 8 02:10:53 nat: apply nat rules (/tmp/nat_rules_0_ppp0_vlan6)
Mar 8 02:10:53 custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Mar 8 02:10:53 custom_script: Running /jffs/scripts/service-event-end (args: restart firewall)
Mar 8 02:11:02 rc_service: httpd 458:notify_rc stop_upgrade
Mar 8 02:11:02 rc_service: httpd 458:notify_rc start_upgrade
Mar 8 02:11:02 rc_service: waitting "stop_upgrade" via httpd ...
Mar 8 02:11:03 usb: USB is ejected
Mar 8 02:11:03 nat: apply nat rules (/tmp/nat_rules_0_ppp0_vlan6)
Mar 8 02:11:05 ntpd: Stopped ntpd
Mar 8 02:11:05 miniupnpd[2362]: shutting down MiniUPnPd
Mar 8 02:13:40 ntpd: Initial clock set
Mar 8 02:13:40 rc_service: ntpd_synced 1563:notify_rc restart_diskmon
Mar 8 02:13:40 disk_monitor: Finish
Mar 8 02:13:40 custom_script: Running /jffs/scripts/service-event-end (args: restart diskmon)
Mar 8 02:13:42 roamast: ROAMING Start...
Mar 8 02:13:42 disk_monitor: be idle
Mar 8 02:13:53 custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Mar 8 02:13:53 zcip_client: configured 169.254.107.70
Mar 8 02:13:57 kernel: SHN Release Version: 2.0.1 f45bb18
Mar 8 02:13:57 kernel: UDB Core Version: 0.2.20
Mar 8 02:13:57 kernel: sizeof forward pkt param = 192
Mar 8 02:13:58 BWDPI: fun bitmap = 83
Mar 8 02:14:00 A.QoS: qos_count=0, qos_check=0
Mar 8 02:14:00 kernel: ERR[__parse_app_rule:584] Failed to parse app rule catid value
Mar 8 02:14:00 kernel: ERR[parse_qos_conf:1045] Invalid config syntax at line 21.
Mar 8 02:14:00 A.QoS: set_qos_conf fails
Mar 8 02:14:00 A.QoS: restart A.QoS because set_qos_conf / set_qos_on / setup rule fail
Mar 8 02:14:00 kernel: ERR[ioctl_iqos_op_config:3608] parse qos_conf error!!
Mar 8 02:14:00 kernel: ioctl_iqos_op_config() fail!
Mar 8 02:14:03 custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Mar 8 02:14:03 rc_service: ip-up 1443:notify_rc stop_samba
Mar 8 02:14:03 rc_service: ip-up 1443:notify_rc start_samba
Mar 8 02:14:03 rc_service: waitting "stop_samba" via ip-up ...
Mar 8 02:14:03 wsdd2[1176]: Terminated received.
Mar 8 02:14:05 Samba_Server: smb daemon is stopped
Mar 8 02:14:05 kernel: gro disabled
Mar 8 02:14:05 custom_script: Running /jffs/scripts/service-event-end (args: stop samba)
Mar 8 02:14:07 kernel: gro enabled with interval 2
Mar 8 02:14:09 Samba_Server: daemon is started
Mar 8 02:14:09 custom_script: Running /jffs/scripts/service-event-end (args: start samba)
Mar 8 02:14:13 crond[499]: time disparity of 1494489 minutes detected
Mar 8 02:15:32 dropbear[2018]: Password auth succeeded for 'Asus' from 192.168.1.100:15000
Mar 8 02:17:06 FlexQoS: File flexqos.asp is already up-to-date
Mar 8 02:17:07 acsd: eth2: NONACSD channel switching to channel spec: 0xe02a (36/80)
Mar 8 02:17:07 syslog: event: wl_chanspec_changed_action
Mar 8 02:17:07 syslog: skip event due no re
Mar 8 02:17:11 rc_service: service 2652:notify_rc restart_qos;restart_firewall
Mar 8 02:17:15 syslog: wlceventd_proc_event(526): eth2: Auth 38:F9
3:1B:21:6B, status: Successful (0), rssi:0
Mar 8 02:17:15 syslog: wlceventd_proc_event(555): eth2: Assoc 38:F9
Mar 8 02:17:29 BWDPI: fun bitmap = 83
Mar 8 02:17:29 A.QoS: qos_count=0, qos_check=0
Mar 8 02:17:29 kernel: ERR[__parse_app_rule:584] Failed to parse app rule catid value
Mar 8 02:17:29 kernel: ERR[parse_qos_conf:1045] Invalid config syntax at line 21.
Mar 8 02:17:29 kernel: ERR[ioctl_iqos_op_config:3608] parse qos_conf error!!
Mar 8 02:17:29 kernel: ioctl_iqos_op_config() fail!
Mar 8 02:17:29 A.QoS: set_qos_conf fails
Mar 8 02:17:29 A.QoS: restart A.QoS because set_qos_conf / set_qos_on / setup rule fail
Mar 8 02:17:29 custom_script: Running /jffs/scripts/service-event-end (args: restart qos)
Mar 8 02:17:30 custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Mar 8 02:17:30 custom_script: Running /jffs/scripts/service-event-end (args: restart firewall)
Mar 8 02:17:30 FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=2783) called in unattended mode with 1 args: -start
Mar 8 02:17:31 FlexQoS: Applying iptables static rules
Mar 8 02:17:32 FlexQoS: Applying iptables custom rules
Mar 8 02:17:32 FlexQoS: Flushing conntrack table
Mar 8 02:17:33 FlexQoS: TC Modification Delayed Start
