[Fork] Asuswrt-Merlin on Broadcom MIPS RT-N series
Here is lsmod after modprobe on 53d
Just tested it but still not working:(...what do you need from this one? It's still running:)
I don't know why USB driver for 5g want to start
It part wl_high.o is precompiled from asus.
It precompiled for pre-defined Linux kernel parameter. What it need?
I replace mod_devicetable.h that give error during compile
Replace drivers/net/USB
Try replacing whole Linux kernel but only tommorow or on Monday.
ls /lib/modules/2.6.22.19/kernel/drivers/net/usb
usbnet.ko present?
modprobe usbnet.ko
lsmod & syslog
P.S. use putty Copy All To Clipboard
usbnet.ko present?
modprobe usbnet.ko
lsmod & syslog
admin@RT-N53-371A:/tmp/home/root# ls /lib/modules/2.6.22.19/kernel/drivers/net/u
sb/
hso_26-v1.14 ipheth.ko
admin@RT-N53-371A:/tmp/home/root# modprobe usbnet.ko
modprobe: module usbnet.ko not found in modules.dep
admin@RT-N53-371A:/tmp/home/root# lsmod
Module Size Used by Tainted: P
nf_nat_sip 3808 0
nf_conntrack_sip 7328 1 nf_nat_sip
nf_nat_h323 6240 0
nf_conntrack_h323 38272 1 nf_nat_h323
nf_nat_rtsp 4560 0
nf_conntrack_rtsp 5600 1 nf_nat_rtsp
nf_nat_ftp 2208 0
nf_conntrack_ftp 6816 1 nf_nat_ftp
ip6table_filter 1376 0
ip6table_mangle 1568 0
ohci_hcd 18192 0
jffs2 115136 1
zlib_deflate 19056 1 jffs2
zlib_inflate 13120 1 jffs2
lzo_decompress 2112 1 jffs2
lzo_compress 1984 1 jffs2
nf_nat_pptp 2176 0
nf_conntrack_pptp 4912 1 nf_nat_pptp
nf_nat_proto_gre 1648 1 nf_nat_pptp
nf_conntrack_proto_gre 3360 1 nf_conntrack_pptp
wl_high 1039888 0
ehci_hcd 37504 0
usbcore 125824 4 ohci_hcd,wl_high,ehci_hcd
wl 2771024 0
igs 17648 2 wl_high,wl
emf 21152 3 wl_high,wl,igs
et 45632 0
ctf 21456 0
usbnet.ko is absent :(
in stock firmware usbnet configured as part of kernel.
in current source always as module.
why it removed why compiled RT-N53 ?
now try leave usbnet module.
