[Fork] Asuswrt-Merlin on Broadcom MIPS RT-N series
try m7a-n53g
please post lsmod & log
also try
wlconf eth2 up
admin@RT-N53-371A:/tmp/home/root# lsmod
Module Size Used by Tainted: P
nf_nat_sip 3808 0
nf_conntrack_sip 7328 1 nf_nat_sip
nf_nat_h323 6240 0
nf_conntrack_h323 38272 1 nf_nat_h323
nf_nat_rtsp 4560 0
nf_conntrack_rtsp 5600 1 nf_nat_rtsp
nf_nat_ftp 2208 0
nf_conntrack_ftp 6816 1 nf_nat_ftp
ip6table_filter 1376 0
ip6table_mangle 1568 0
ohci_hcd 18192 0
jffs2 115136 1
zlib_deflate 19056 1 jffs2
lzo_decompress 2112 1 jffs2
zlib_inflate 13120 1 jffs2
lzo_compress 1984 1 jffs2
nf_nat_pptp 2176 0
nf_conntrack_pptp 4912 1 nf_nat_pptp
nf_nat_proto_gre 1648 1 nf_nat_pptp
nf_conntrack_proto_gre 3360 1 nf_conntrack_pptp
wl_high 1039888 0
ehci_hcd 37504 0
usbcore 125360 4 ohci_hcd,wl_high,ehci_hcd
wl 2771024 0
igs 17648 2 wl_high,wl
emf 21152 3 wl_high,wl,igs
et 45632 0
ctf 21456 0
also tried with wlconf command and nothing happened...
modprobe /lib/modules/2.6.22.19/kernel/drivers/net/usb/usbnet.ko
lsmod
admin@RT-N53-371A:/tmp/home/root# modprobe /lib/modules/2.6.22.19/kernel/drivers
/net/usb/usbnet.ko
usbnet 15600 0
nf_nat_sip 3808 0
nf_nat_h323 6240 0
nf_nat_rtsp 4560 0
nf_nat_ftp 2208 0
ohci_hcd 18192 0
jffs2 115136 1
nf_nat_pptp 2176 0
wl_high 1039888 0
ehci_hcd 37504 0
usbcore 125360 5 usbnet,ohci_hcd,wl_high,ehci_hcd
wl 2771024 0
et 45632 0
ctf 21456 0
and also forgot to show you output of wlconf
admin@RT-N53-371A:/tmp/home/root# wlconf eth2 up
eth2: WLC_GET_VAR(cap): No such device
- mod7a, 15.10.2014
- Based on Merlin 376.48 alpha3 (ASUS 3.0.0.4.376_2769) source
- for all models replace WiFi driver from GPL 376.2671 RT-N14UHP 07.08.2014г.
- fixed incorrect show of language list (non-English)
- for USB models RT-N10U, RT-N15U и RT-N14UHP created external web kit (how-to install attached)
- install by asusware ASUS AiCloud 2.0 for RT-N10U, RT-N15U and RT-N14UHP with management by external web kit (for RT-N16 included in firmware)
- add NFS server (for RT-N10U, RT-N15U and RT-N14UHP by external web kit)
- reworked RT-N14UHP firmware for unification with external web kit
- add WiFi 5G for RT-N53, but still NOT work
how-to install external web kit:
1. enter to admin console (previously activate telnet or/and ssh on Administartion page)
2. goto folder /opt - "cd /opt" (folder /opt exist, if you installed any asusware application from USB Application page)
3. wget ftp://<..>/RT-<*>-ext.tgz (file name according to your router model and firmware version)
4. wget ftp://<..>/prepare_external_kit.sh
5. chmod +x prepare_external_kit.sh (if USB disk ext2/ext3 formated)
6. ./prepare_external_kit.sh
mod7a RT-N15U WiFi bug
mod7a just bring WiFi of RT-N15U down, connection are weak at 1m distance or down past some time. Returned to mod7.
mod7a вырубает WiFi на моём RT-N15U, сигнал слабый, а через некоторое время вообще никакой. Вернулся на mod7, всё ок.
Спасибо за прошивку для RT-N15U!
Официальные обновления не работают с моим провайдером... Даже на форуме ASUS создал пост, отнекиваются, что мол проблема у вас.
http://vip.asus.com/forum/view.aspx...rd_id=11&model=RT-N15U&page=1&SLanguage=en-us
I made some preparation to increase from default 100(80)mw power to more.
are you try make Reset to Factory Default because some trouble may be in settings.
P.S по-русски можем общаться на форуме wl500g.info
try m7a-n53i in dir mod7a/n53_test_5g
sorry for delay, my phone with tapatalk broke so i don`t receive notifications from the forum:)
here is lsmod&log...5g still not working
ohci_hcd 18192 0
jffs2 115136 1
nf_nat_pptp 2176 0
nf_nat_ftp 2208 0
wl_high 1051568 0
ehci_hcd 37504 0
wl 2771024 0
et 45632 0
ctf 21456 0
GNU wget
If I do:
#modify/new ipkg.conf
mkdir /jffs/opt/etc
cd /jffs/opt/etc
#add repository path to new ipkg.conf
vi ipkg.conf
export IPKG_CONF_DIR=/jffs/opt/etc
ipkg update
ipkg install -d root -force-depends wget
When I call wget busybox is going to take priority, right?
Is it possible to remove busybox's wget or do I have to always use an absolute path to invoke it?
example:
WGET=/jffs/usr/bin/wget
$WGET http://www.example.com
Folder rigths are a problem and no USB...
RT-N12D1
I am using Merlin 376.47 now.
What is the difference between Merline Fork Version and the regular Merlin 376.47?
Thanks.
Thanks.
about RT-N16?
I enable OpenVPN, SNMP.
but be carefull - size of nvram may be exceeded and tha's why not activate all features of firmware at same time.
Can´t get a connection on the console:
ASUSWRT-Merlin RT-N12D1_3.0.0.4 Wed Oct 15 18:15:32 UTC 2014
admin@RT-N12D1-2200:/tmp/home/root# cd /
admin@RT-N12D1-2200:/# ping www.google.com
ping: bad address 'www.google.com'
admin@RT-N12D1-2200:/# ip rule
0: from all lookup local
32766: from all lookup main
32767: from all lookup default
admin@RT-N12D1-2200:/# ip route
192.168.1.0/24 dev br0 proto kernel scope link src 192.168.1.2
127.0.0.0/8 dev lo scope link
default via 192.168.1.1 dev br0
admin@RT-N12D1-2200:/# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.1.0 * 255.255.255.0 U 0 0 0 br0
127.0.0.0 * 255.0.0.0 U 0 0 0 lo
default 192.168.1.1 0.0.0.0 UG 0 0 0 br0
Operation Mode:Repeater mode
Primary router IP: 192.168.1.1
This router IP: 192.168.1.2
Can anyone help?
Can anyone help?
I got it, DNS was missing on the router, I used 8.8.8.8
try m7a-n53j
admin@RT-N53:/tmp/home/root# lsmod
nf_nat_sip 3808 0
nf_nat_h323 6240 0
nf_nat_rtsp 4560 0
nf_nat_ftp 2208 0
ohci_hcd 18192 0
jffs2 115136 1
nf_nat_pptp 2176 0
wl_high 1051568 0
ehci_hcd 37504 0
usbcore 125824 4 ohci_hcd,wl_high,ehci_hcd
wl 2771024 0
et 45632 0
ctf 21456 0
still not working...
