NXIL
May I ask why you will not consider the Up-there link system? Solar powered, not susceptible to ground based catastrophes, etc.I'll never use XXXXlink. I ask people to kindly quit referencing it.
Also, there aren't people that do this on the regular. This is a very niche-case.
submitted an hour ago by eyeseeitallnow
Seeking off-grid security camera (to monitor from within our Cabin) with POE (ethernet). Do not need or want WiFi but WiFi is OK — as long as there is ALSO Ethernet connectivity!
Tech9, you haven't heard? You're signed up and you'll be collected for processing a day or two before launch.
Order (2) CPE210 + (1) EAP2110 + (1) Camera
EAP2100 facing NE
2x CPE210 + 1x EAP110-Outdoor + Camera
300Mbps Wireless N Outdoor Access Point
www.tp-link.com
Something else you need to know - CPE210 is EoL product like most 2.4GHz bridges today. Unfortunately, this is what you need for your application. There is a EAP510 bridge with 13dBi antennas on 5GHz. You may want to test this one instead?
EAP110-Outdoor is an omnidirectional AP, you just need to install it there for 360-degree coverage around it.
Is it possible that instead of CPE210, I could use a WiFi6 variant (EAP610 - link)?
I can't find the antenna strength for it easily
Based on the responses thus far, the 5GHz solution wouldn't likely work given that it's higher frequency translates to a shorter wavelength.
There is 5GHz N300 equivalent, CPE510:
There is 5GHz AC867 also available, CPE710:
The last one will shoot at miles distance with 23dBi antennas for whoever needs this bridge and speed. You don't because the AP after better be N300 for longer range possible. An AX-class AP won't help much, your clients perhaps won't support AX on 2.4GHz band and it won't increase the range.
I'm out. Trying to help you without going into guessing territory too much. This is all I can assist with remotely in a public forum without even seeing what exactly place we are talking about. Your hand drawn map over satellite image could have helped in the process. Someone else may have other ideas.
This is not an easy project, especially given that you want camera streaming, which can eat up bandwidth. It's also outdoors, which requires equipment that can withstand temperature changes and is water resistant.
Yes, I agree - this might be better handled by a local WLAN Professional because of the scope and scale.
Going DYI - it can be done, but it might actually be more expensive and less suited to OP's needs...
I'm a tinkerer ... and a fan of Amazon's return policy in case I can't get things to work.
Understood - for smaller scale projects, that would be ok...
Well that's one of those things - I could choose to reshingle my roof, but there, I have no experience...
Also consider that I used to do home installs, and there, I did make use of a cable TV installer, as that is what his expertise was - he could pull and install Coax and Ethernet drops a hell of a lot faster than I could...
Beware this might become an issue.... I had an experience with them starting to deduct 10-20% on returns and one instance where they refused to budge on a drive I returned. I ordered 4 and returned 4 but they refunded 3. Went back and forth for a few months and finally got fed up with them and did a CC chargeback instead and then removed all of my payment options when they threatened to charge another method of payment.I'm a tinkerer ... and a fan of Amazon's return policy in case I can't get things to work.
Welcome To SNBForums
