EmeraldDeer
Downloaded updated v1.2.1 and watching the sys_jitter goose eggs go byDone. @EmeraldDeer the raw stats can be found in /tmp/ntp-rrdstats.$$ where $$ is substituted for a process ID
Downloaded updated v1.2.1 and watching the sys_jitter goose eggs go by![]()
Using only us.pool.ntp.org.Can you folks run ntpq -p? jitter is the last column.
remote refid st t when poll reach delay offset jitter
==*linode1.ernest- 198.72.72.10 3 u 63 128 377 91.190 -0.713 1.666
Personally I did not even know the Asus firmware was running an ntp server.
Oops... Stupid mistake from my sideIt doesn't, only a client.
Code:remote refid st t when poll reach delay offset jitter ============================================================================ ==*linode1.ernest- 198.72.72.10 3 u 63 128 377 91.190 -0.713 1.666
The graph is not using "ntpq -p" for data, it is using "ntpq -4 -c rv".Hmmm, shows relatively normal jitter. Not sure why it doesn't show up on your graph. One idea (a stretch), add another server to ntp.conf. Maybe:
server 0.pool.ntp.org iburst
Then restart ntpd. Give it a few hours and see...
# ntpq -4 -c rv | egrep "offset|jitter"
mintc=3, offset=0.019588, frequency=1.186, sys_jitter=0.000000,
clk_jitter=0.071, clk_wander=0.051, tai=37, leapsec=201701010000,
# grep jitter /tmp/ntp-rrdstats*
/tmp/ntp-rrdstats.1313: sys_jitter=0.000000
/tmp/ntp-rrdstats.1313:clk_jitter=0.183
/tmp/ntp-rrdstats.1828: sys_jitter=0.000000
/tmp/ntp-rrdstats.1828:clk_jitter=0.149
/tmp/ntp-rrdstats.2164: sys_jitter=0.000000
/tmp/ntp-rrdstats.2164:clk_jitter=0.121
/tmp/ntp-rrdstats.2487: sys_jitter=0.000000
/tmp/ntp-rrdstats.2487:clk_jitter=0.088
/tmp/ntp-rrdstats.2994: sys_jitter=0.000000
/tmp/ntp-rrdstats.2994:clk_jitter=0.075
/tmp/ntp-rrdstats.3311: sys_jitter=0.000000
/tmp/ntp-rrdstats.3311:clk_jitter=0.065
/tmp/ntp-rrdstats.3642: sys_jitter=0.000000
/tmp/ntp-rrdstats.3642:clk_jitter=0.060
/tmp/ntp-rrdstats.4190: sys_jitter=0.000000
/tmp/ntp-rrdstats.4190:clk_jitter=0.188
/tmp/ntp-rrdstats.4520: sys_jitter=0.000000
/tmp/ntp-rrdstats.4520:clk_jitter=0.152
/tmp/ntp-rrdstats.4857: sys_jitter=0.000000
/tmp/ntp-rrdstats.4857:clk_jitter=0.119
/tmp/ntp-rrdstats.5348: sys_jitter=0.000000
/tmp/ntp-rrdstats.5348:clk_jitter=0.098
/tmp/ntp-rrdstats.5666: sys_jitter=0.000000
/tmp/ntp-rrdstats.5666:clk_jitter=0.085
/tmp/ntp-rrdstats.5988: sys_jitter=0.000000
/tmp/ntp-rrdstats.5988:clk_jitter=0.101
/tmp/ntp-rrdstats.6306: sys_jitter=0.000000
/tmp/ntp-rrdstats.6306:clk_jitter=0.183
/tmp/ntp-rrdstats.6630: sys_jitter=0.000000
/tmp/ntp-rrdstats.6630:clk_jitter=0.135
/tmp/ntp-rrdstats.7116: sys_jitter=0.000000
/tmp/ntp-rrdstats.7116:clk_jitter=0.097
/tmp/ntp-rrdstats.7520: sys_jitter=0.000000
/tmp/ntp-rrdstats.7520:clk_jitter=0.080
/tmp/ntp-rrdstats.7887: sys_jitter=0.000000
/tmp/ntp-rrdstats.7887:clk_jitter=0.073
/tmp/ntp-rrdstats.826: sys_jitter=0.000000
/tmp/ntp-rrdstats.826:clk_jitter=0.232
/tmp/ntp-rrdstats.958: sys_jitter=0.000000
/tmp/ntp-rrdstats.958:clk_jitter=0.218
If your clock gets knocked off every two hours, then the culprit is the ntp client.Oops... Stupid mistake from my side
How long should it take for stuff to settle? Isn't this taking longer than usual?
View attachment 16845 View attachment 16846
I'm not sure that's running:If your clock gets knocked off every two hours, then the culprit is the ntp client.
killall ntp
ps | grep ntp
... ntpd -c /jffs/configs/ntp.conf -g
PRECMD="killall ntp"
S77ntpd does stop the ntp client. But I have noticed when making router configuration changes that it can be started.I'm not sure that's running:
Code:ps | grep ntp ... ntpd -c /jffs/configs/ntp.conf -g
No "ntp". And isn't "killall ntp" executed by /opt/etc/init.d/S77ntpd?
Code:PRECMD="killall ntp"
Oh, should have indeed explained that. 18:20 was actually a reboot of the router (for an unrelated issue with a device).So I take it that your anomaly at about 18:20 UTC was that you restarted the ntp server without the iburst.
I just installed ntpMerlin, rebooted the router and upon selecting "1. Generate updated ntpMerlin graphs now" I'm getting this.
Choose an option: 1
ntpq: error while loading shared libraries: libcrypto.so.1.1: wrong ELF class: E LFCLASS32
Press enter to continue...
Moments before I installed ntpMerlin I did Diversion>pixelsrv-tls>manage Entware and update installed packages.
I see the mention to Run opkg update;opkg upgrade in a search of this thread but I am leery to do this as I remember reading a post not to long ago where someone ran that and it screwed up their Diversion/pixelserv-tls install. Perhaps this is a different scenario?
I just did option 6. update and upgrade installed packages and when choosing option 1 I now get this error. Is there a reboot needed?
Choose an option: 1
ntpq: read: Connection refused
I'm not convinced entware is in a good state after the last repo updateI just installed ntpMerlin, rebooted the router and upon selecting "1. Generate updated ntpMerlin graphs now" I'm getting this.
Choose an option: 1
I agree. After doing an opkg update && opkg upgrade I later tried running adb (Android Debugger). It complained about a missing lib. I use adb every few days...I'm not convinced entware is in a good state after the last repo update
opkg update
opkg upgrade
There's been some reports that didn't help, and some people have had to remove and reinstall for the dependencies to update. I think this is a known issue - opkg isn't smart enough to always update dependenciesHave to upgrade already installed packages, to move to the newer OpenSSL.
Code:opkg update opkg upgrade
Thread starter | Title | Forum | Replies | Date |
ntpMerlin ntpMerlin compatibility with Merlin 3006.102.3 | Asuswrt-Merlin AddOns | 15 | |
W | ntpMerlin ntpMerlin and timeserverd ntp_ready tests | Asuswrt-Merlin AddOns | 1 | |
D | NTPmerlin config log not found | Asuswrt-Merlin AddOns | 2 |
Welcome To SNBForums
