Sanna1967
Until you Factory reset or Initialize.I have a RT-68U working fine in Media Bridge mode - was on 380.69 then updated to the short lived 382.something, then 384.3_A1 and now 384.3_A2
I may be wrong, but I don’t think it will go totally closed source. It appears to be trending in a direction that’s making it more difficult for Merlin to work with the firmware. That’s a real bummer for sure.im starting to worry, with all the close source stuff deos thst mean that there will be a day where it will be completely closed source?
Feb 14 10:00:17 kernel: _ Reboot message ... _______________________________________________________
Feb 14 10:00:18 kernel: Unable to handle kernel NULL pointer dereference at virtual address 00000000pgd = ffffffc006627000[00000000] *pgd=00000000051ec003, *pud=00000000051ec003, *pmd=000000000540b003, *pte=0000000000000000Internal error: Oops: 96000007 [#1] PREEMPT SMPModules linked in: ip_set_list_set init_addr( (null) - (null)), core_addr(ffffffbffc312000 - ffffffbffc313a40) ip_set_hash_ip init_addr( (null) - (null)), core_addr(ffffffbffc309000 - ffffffbffc30c95
Feb 14 10:00:19 kernel: x28: ffffffc0058938d4 x27: ffffffc00abb2308 x26: ffffffc00bb3c400 x25: ffffffc0055367d8 x24: 0000000000000001 x23: 0000000000000140 x22: ffffffc0058938d8 x21: ffffffc00a7b00c0 x20: 000000001f910000 x19: ffffffc0055367e0 x18: 0000000000000000 x17: 0000000000000000 x16: ffffffc00039ff18 x15: 4009000800000000 x14: 00000000f7706660 x13: 0000000000000001 x12: 0000000000000028 x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f x9 : 0000000000000000 x8 : 0000000000000000 x7 : 00000000fffffff
Feb 14 10:00:19 kernel: ____________________________________________________________________________
TBH, my 68u had the same issue, just it's never solved XD It will shows I can upgrade the firmware(When I click it, it actually went and download the same fw and installed it *facepalm*). I went back n forth twice, guess my 68u is more retarded than yours! And there's 2 options to factory reset in stock fw, lol restore/initiate, both did the same thing...I noticed that while running the asus 384.10007 it would offer me both an upgrade and check button when I was already running that firmware. I did a factory reset and then reinstalled it yet this behavior persisted. Only after installing the merlin 384.3_a1 and then going back to the stock firmware did that condition clear up for me. I obviously have the most retarded 88u on the planet.![]()
Check if you have any logs in both 2way ips and mal site blocked, clear them by clicking the trashcan icon.@Merlin. Something in the AiProtection causes my RT-AC68U to go into a CPU meltdown. If there’s moderate load such as two IPTV streams the CPU use rockets and eventually the router grinds to a halt throttling all bandwidth. With AiProtection switched off it is fine.
Is this code something you have access to or is this closed source? The official ASUS release is exactly the same as was 382.
Any ideas please?
Thanks,
HB
<a class="hintstyle" href="javascript:void(0);" onClick="openHint(5,10);">MAC
<a class="hintstyle" href="javascript:void(0);" onClick="openHint(5,10);">MAC</a>
<textarea rows="8" class="textarea_ssh_table"id="edit_vpn_crt_client_extra" name="edit_vpn_crt_client_extra" cols="65" maxlength="3499"></textarea>
<textarea rows="8" class="textarea_ssh_table" id="edit_vpn_crt_client_extra" name="edit_vpn_crt_client_extra" cols="65" maxlength="3499"></textarea>
<input type="button" onclick="edit_Keys();" value="Edit..."</td>
<input type="button" onclick="edit_Keys();" value="Edit...">
<script language-:JavaScript" type="text/javascript" src="/js/jquery.js"></script>
<script language="JavaScript" type="text/javascript" src="/js/jquery.js"></script>
<table width="100%" border="1" align="center" cellpadding="4" cellspacing="0"bordercolor="#6b8fa3" class="FormTable">
<table width="100%" border="1" align="center" cellpadding="4" cellspacing="0" bordercolor="#6b8fa3" class="FormTable">
Thanks for the suggestion. I cleared all logs but it has made no difference unfortunately.Check if you have any logs in both 2way ips and mal site blocked, clear them by clicking the trashcan icon.
Same action on the RT-AC66U_B1. I reported it to Asus via feedback and they actually replied via email acknowledging the problem and that they are working on a fix!I noticed that while running the asus 384.10007 it would offer me both an upgrade and check button when I was already running that firmware. I did a factory reset and then reinstalled it yet this behavior persisted. Only after installing the merlin 384.3_a1 and then going back to the stock firmware did that condition clear up for me. I obviously have the most retarded 88u on the planet.![]()
I hope they fix all of them for the customers sake.Same action on the RT-AC66U_B1. I reported it to Asus via feedback and they actually replied via email acknowledging the problem and that they are working on a fix!
OK thanks; I feared that this would be the case.Everything tied to Trend Micro is closed source.
Welcome To SNBForums
