Good build so far except for the wireless "site survey" is not showing the signal strength.View attachment 11622
RT-AC68P 384.3 Alpha1
It shows up normal on my side, Chrome with cleared cache.This problem has been closed in Alpha 2But now there is a scroll bar on both sides? The Wireless name field is too large. Maybe that can be changed?
Just a note, on alpha 2, 68u, guest network issue is still there, I'm not sure what's changed in the code since it's not stated in the changelog file. @RMerlin if the changes is insignificant, don't mind me.
Give me a moment, I'll test Edge as well laterThank you! I tested it in Firefox. Do you want to do that too?
@Martineau mentions here, there may be changes in 384.x that will require changes to the priority assignments.
Will need to monitor any changes to fwmark reservations Asus uses to avoid conflicts.
ip rule
0: from all lookup local
150: from all fwmark 0x80000000/0xf0000000 lookup TalkTalk
150: from all fwmark 0x90000000/0xf0000000 lookup wan1
200: from wan.xxx.xxx.xxx lookup TalkTalk
200: from 192.168.1.139 lookup wan1
200: from dns0.xxx.xxx.xxx lookup TalkTalk
200: from dns1.xxx.xxx.xxx lookup TalkTalk
200: from 192.168.1.1 lookup wan1
400: from all to wan.gw.xxx.xxx lookup TalkTalk
400: from all to dns0.xxx.xxx.xxx lookup TalkTalk
400: from all to dns1.xxx.xxx.xxx lookup TalkTalk
400: from all to 192.168.1.1 lookup wan1
10101: from 172.16.1.1 lookup NewYork
32766: from all lookup main
32767: from all lookup default
Update: FF57.0.4 and Edge displayed it normally like chrome. Try to clear cache and login again.
Works for me. What browser?
Has this issue been resolved? It is the only problem I have with this firmware. QOS actually works well it seems, just no stats on QOS stats page. Can anyone else verify if another model besides the 86u shows data on the QOS data page please?The problem with the QoS statistics has been fixed in Alpha2 for RT-AC86U
That's good to hear, will try to install Alpha 2 later today.
Just to verify: can dhcp_staticlist still be restored to nvram on a clean install? I think I've read somewhere restoring a full backup with nvram-save.sh might cause trouble...
Yes and AP mode alsoMy RT-AC68U was in Media Bridge early on 384.3_A1 and then stopped working. Flashed A2 and media bridge still not working. Anyone experiencing this?
https://www.snbforums.com/threads/rt-ac68u-version-3-0-0-4-384-10007.43114/page-2#post-373792
https://www.snbforums.com/threads/rt-ac68u-version-3-0-0-4-384-10007.43114/page-2#post-374151
https://www.snbforums.com/threads/rt-ac68u-version-3-0-0-4-384-10007.43114/page-2#post-374154
384.3 is base on 384.10007 (asus)
s possible somehowe change app name in traffic analyzer? i see General streaming but that is kodi addon...
My RT-AC68U was in Media Bridge early on 384.3_A1 and then stopped working. Flashed A2 and media bridge still not working. Anyone experiencing this? I have a tplink repeater and it works fine.
Welcome To SNBForums
