versus John's which is based on the quite old 374 branch
Don't pay too much attention to the fact his version shows 374.xx - John backported a lot of fixes from newer releases. His code is much newer than the original 374 code it was initially based on.
I suppose that upgrading from 380.68_4 does not need factory reset? Isn't it?
No needupgrading from 380.68_4 does not need factory reset?
As the 380.70 change-log explains: There will be no further updates on the 380 branch...Hi @RMerlinI would ask if RT-AC66U would be able to upgrade as well as original firmware does from Asus (at least security fixes), because it has been revamped yesterday to: 3.0.0.4.382.50470.
So it's a new GPL with different base, and maybe the stability and security fixes help to our legacy routers with a new life for people without too much money for upgrade the hardware.
Hi @RMerlin
Thank you very much for your support Eric, it is brilliant and appreciated, I would ask if RT-AC66U would be able to upgrade as well as original firmware does from Asus (at least security fixes), because it has been revamped yesterday to: 3.0.0.4.382.50470.
Thanks again and congrats for NG branch too!![]()
See first thread posting by Merlin:The main issue is that the AC66U is a MIPS router, whereas newer models are ARM/HND. So essentially support for a whole architecture has to be added just to support 1 router.
Does that mean that his fork has all the features, that your latest version does?
No. Separate branches, with a few differences in features.
Do you remember what features the other version does not have, that yours does?
Welcome To SNBForums
