Okay, so I should be able to enable friendly names on all of my devices as I have just under 30 at the current time. I'm beginning to think I didn't do a reset after installing 382.1_2, I thought I had but maybe not.I've got more than 50 devices here on my ac86u. Problem with friendly names starts with ~30 devices (it's a matter of the length of their names). DHCP reservation is almost fine (partially limited). It has been splitted into more nvram variables but (as RMerlin wrote earlier) friendly name cannot be served the same way due another services that use it. There is the same situation with 282.2.beta2.
Of course I use Upload button under the Save button in JFFS Partition section. I can export jffs backup file (looks like proper tar archive with extra .sys folder inside). I can extract it manually but not through web interface.
If I trace it in firefox, i can get to the jffsupload.cgi with this content:
Is that closed source part?Code:<html> <head> <title>ASUS Wireless Router Web Manager</title> <meta http-equiv="Content-Type" content="text/html; charset=UTF-8"> <meta HTTP-EQUIV="Pragma" CONTENT="no-cache"> <meta HTTP-EQUIV="Expires" CONTENT="-1"> <link rel="shortcut icon" href="images/favicon.png"> <link rel="icon" href="images/favicon.png"> </head> <body> <script> alert("Setting File upload fail. It may result from incorrect Setting File or error transmission. Please check the validation of Setting File and try again."); </script> </body> </html>
My 86U, only just recently bought and flashed with this new release, reset and then configured.....
I thought that the RAM usage was high, but not sure if that is used or simply "allocated" for some reason and so typical, being new to this router I'm not sure what it would show if using the std firmware...?
Are they connected to a wired AP? That is how my wireless clients show up when connected to an AP.Is there a reason why the Network Map is showing some wireless clients as wired? They are correctly showing as wireless on the wireless log page.
Edit: They show as wireless on the AP, but as wired on the router.
Ah! Glad I saw this. I''m having the same issue, ram usage is high. Anyone knows why?mine is the same. New RT-AC86U and flashed straight to Merlin. My ram figures the same.
I see the very same thing, some wireless clients show as wired clients. This is with an 86U running 382.1_2Is there a reason why the Network Map is showing some wireless clients as wired? They are correctly showing as wireless on the wireless log page.
Yes, returning the 86U has been on my mind for a few weeks now. Maybe it is just a bit too "immature" for reliable daily use just yet.I can confirm this, as I also have around 50 odd devices as well and the “rot sets in” also at the 30-31 mark.
In my case it meant I aborted changing over my main router from my trusty AC68U for my new AC86U (both with Merlin of course as non-negotiable essential firmware).
The AC86U is sitting back in its box awaiting a bit more “maturity” in the 382 firmware, and a GPL release of same that @RMerlin can hopefully work his magic on if he so chooses (and I never assume he will, but hope he does).
Bit disappointing really, 86U has good potential seemingly let down a bit at this point ...
StephenH
I have an RT-AC86U running this firmware connecting to a CenturyLink (Calix) ONT. PPPOE performance is pretty poor WAN-LAN at 420 Mbps versus my 1 Gbps fiber speed. Anyone else seeing bad PPPOE performance?
What did you do to fix this. I am facing same issue on AC88U, firmware 382.1.2.Thanks. When I go back to the 382 tree I will do this!
Running modprobe cifs.ko gives error "modprobe: module cifs.ko not found in modules.dep"
Welcome To SNBForums
