let me question
You can check my System Log to see if there are any errors:
https://pastebin.com/gWWvgYbZ
What router are you using? I have none of the problems you describe with my AC87U. I have a Yamaha YAS-306.I have problem with yamaha MusicCast. It not working with this version. I must change 2.4 wifi to 20mhz mode. On 20/40 it not working. Previous version was ok. And another strange thing: Yamaha R-N803D on this version can't get ip address from dhcp server I must set static IP :/
take 68U and not 86U, many confused about thatHi.
I can't upgrade from 384.4_2 on RT-AC68U, the router says it's not a compatible version.
Already tried to re-download the packages, but the SHA256 sum of trx file is correct (the same that is on merlin website).
Any help?
Thanks, but I already verified that I downloaded the right one.take 68U and not 86U, many confused about that![]()
You have a tmobile ac68u and need to read a few posts back about the same thing?Thanks, but
Thanks, but
Doubt it, unless there's a security release required before I'm ready for the next release.
What about Version 3.0.0.4.384.20942 (2018/05/22) release notes such as:
- Fixed XSS vulnerability. Thanks to Yonghui Han of Fortinet's FortiGuard Labs.
- Fixed CVE-2018-8877, CVE-2018-8878, CVE-2018-8879
- Fixed plain text password vulnerability in lighttpd.
Do these fixes get passed down, tested and then released say in a a_1 update?
Welcome To SNBForums
