It's only available on certain models.
So maybe not on the N66U? I'm good either way, just curious. (This may explain why I can't find it!
Correct not on the N66USo maybe not on the N66U? I'm good either way, just curious. (This may explain why I can't find it!)
Probably, or could be that some processes went wrong doing flashing.Not sure what it was. I downloaded from your site and it did not work for the rt-ac87u. So I compiled it from your git, it worked. I must have gotten a "bruised" file?
No, not in N66U. The ones they put AiProtection in all have dual core CPU at 800MHz++ each(the engine probably requires some processing power). I think because N66U has a single 600MHz-core, Asus/TM do not put AiProtection in it.So maybe not on the N66U? I'm good either way, just curious. (This may explain why I can't find it!)
Thank you for the suggestion.
I cross check with the official firmware, it works...
The stock firmware version is 3.0.0.4.380_3941-g27d8adf
Does other devices see hidden network on 380.63_2? Have you tried changing channels? In case the TV only support specific ranges of frequency.RT-AC68U ver 380.63_2
Samsung tv with TIZEN cannot see hidden wireless network in the 5 GHz frequency
The tv network sees 380.59 version so it's not the fault of the tv
I went back to the old version 380.59-hidden network is visible on the tv
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9d41140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9d61140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9d81140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9da1140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9dc1140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9de1140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9e01140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9e21140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9e41140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9e61140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9e81140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9ea1140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9ec1140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9ee1140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9f01140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9f21140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9f41140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9f61140e.
Aug 1 02:00:17 kernel: <4>mm/m ^Cy.c:216: bad pmd 9f81140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9fa1140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9fc1140e.
Aug 1 02:00:17 kernel: <4>mm/memory.c:216: bad pmd 9fe1140e.
Aug 1 02:00:17 kernel: <4>------------[ cut here ]------------
Aug 1 02:00:17 kernel: <4>WARNING: at mm/vmalloc.c:45 vunmap_page_range+0xd4/0x128()
Aug 1 02:00:17 kernel: <4>module: IDP bf773000 529190
Aug 1 02:00:17 kernel: ____________________________________________________________________________
Same here on Traffic Manager for monthly traffic, it also says no data in table. Not sure if we have to wait for a month.Monthly traffic monitor tells 'No data in table.'
Uptime is 4 days after update to 63_2.
AC66U.
Does it show current information, or I have to wait for a month to see montly stats?
If you mean router revision, it is on the back part of the router that also has serial number nearby. Yeap, there shouldn't be a problem.from the readme: * RT-AC66U (HW revision A1/A2 only)
how can I check the router version?
Update without factory reset should be possible, right?
I don't see anything at all. It has been up for 3++days, and the month has not yet shifted to December.On mine, it has only gotten data when the month changed to the 1st and then it only had that month. For example, when it becomes December it will only show December, not November. I store Traffic Data in RAM so I hardly ever see anything here.
Have you checked to make sure you have enabled less secure apps in gmail?Colleagues, I recently wrote about periodic reboots the router. I found the cause.
Disable Notification to the post office on AiProtection page (see. Screenshot) and reboot stopped. The strange thing is that the alerts are configured in the spring and everything worked without problems and suddenly began two months ago that ... I noticed that for 10-15 seconds before the reboot, the record appears in the logs (see. Screenshot) of the sent message (and it normally comes in the mail!), and then reboot.
Of course I can live without notification of malicious IPs and websites, but ... There are some ideas how to fix this?
View attachment 7745 View attachment 7746
Tried resetting the tv or tv network settings?Changing channels nothing helped, the computer sees a hidden network but the tv does not. When you change the software on 380.59 tv also zobczył a hidden network. It certainly software problem router 380.63 _2.
Okay, so I'll wait till December, 1st and see if something changes thereOn mine, it has only gotten data when the month changed to the 1st and then it only had that month. For example, when it becomes December it will only show December, not November. I store Traffic Data in RAM so I hardly ever see anything here.
I have also trouble with hidden network. My daughters Iphone looses connection everyday after updating to 380.63. On 380.62 it works fine.Changing channels nothing helped, the computer sees a hidden network but the tv does not. When you change the software on 380.59 tv also zobczył a hidden network. It certainly software problem router 380.63 _2.
Welcome To SNBForums
