Could someone please test if the latest firmware support a USB hub at the USB3 port now?
It doesn't, and it's unlikely to ever do, due to the old kernel used by this platform.
So i had something weird happen last night on my 5ghz, it was doing going slower then 1 Mbit and I have it limited to 15mbit but the hopper 3 actual pull about 17mbit, not sure if this issue was lieing with hopper 3 or vod servers for dish video and few other i was trying to download kept failing or going super slow or if it was router, I turned off the 5ghz/2ghz and turn it back on everything 5ghz was still doing less then 1mbit, finally just rebooted router that same video's where still still randomly fail to start but when it did it was downloading at 15-17mbit
anyone else had similar thing happen? were 5ghz/2ghz drivers changed from 380.65_2? When i flashed the FW i first factory reset, then I flashed FW, then i factory reset again before manually put setting in.
I have a passive usb 2.0 hub connected to my RT-AC68U (usb 3.0) and two usb flash drives attached. Works OK.It doesn't, and it's unlikely to ever do, due to the old kernel used by this platform.
Thank you very much for the feedback. Would have been a great feature and I had hopes since 2014 that Asus would perhaps add it one day or other.
But what do you mean with old kernel and "this platform"? What would be a platform, besides a NAS, with a new kernel? Any other Asus router?
Am I missing something?![]()
380.67_1 (xx-xxx-2017)
- NEW: Merged GPL 380_7743 binary blobs for the RT-N66U.
- FIXED: Duplicate LAN port 1 shown for the RT-AC87U on
the Sysinfo page.
- FIXED: Port forward/UPNP issues with CTF enabled depending on
selected NAT loopback mode.
- FIXED: URL filtering wasn't working over IPv4
Looks like it's only available to whoever wants to build it from the source.Is 380.67_1 still WIP?
I decided to skip it - none of the present issues are critical enough to warrant the extra workload of a parallel release.
Thanks, I assume these fixes are on the 380.68 alpha?
Having the same issue on AC3100- 5GHz drops through the day over and over.I'm going to downgrade to 6_66 5ghz on Ac3200 drops randomly, never had an issue before upgrading. Could you look into this?
I've done factory reset, 30/30/30 and nvram reset nothing has resolved this.
I upgraded my RT-AC3200 from 380.66_6 to 380.67 and it kills my internet, it cannot obtain an IP address from my ISP. If I go back to 380.66_6 it works.
Has anyone else has a similar issue?
Reverted to Asuswrt 380_7743, did the factory reset, but after 4 days of uptime I had a reboot again. Memory usage is just growing bigger and bigger, and then my router reboots. Syslog shows nothing but the reboot.I had a random reboot today. System log shows nothing. I think Asuswrt-Merlin is not for me...
Welcome To SNBForums
