[Release] Asuswrt-Merlin 384.10 is now available
Chiming in to say that I too am having issues on an 86u with OpenVPN and my network telling me I am disconnected.
Thank for reporting. I noticed that going back to previous release my VPN speed is better. Also no disconnects. It could be related to new SSL lib and VPN.
After 24hrs of no problems, I just reconnected my OpenVPN client. Fingers crossed for now.
I will report back here should anything go down again.
In the meantime, what I did (in case it’s related or can help) is disable the WiFi smart connect. I created 3 separate SSIDs and tweaked all 3 in the professional settings tab.
WiFi performance seems solid (it was also the case with smart connect) but I have to keep testing with the optimal channels. On the 2.4GHz, I switched to the 20Mhz only. For the 5GHz band, I’m still on 20/40/80. Not sure if I should keep it that way or switch to 80.
Yes i can connect from windows and linux in tcp.
That doesn't mean the server address and port you entered on your router supports both protocols, their Windows client probably automatically change that for you. Most providers require you to enter a different server and/or port if you want to switch protocol.
Can you guys provide the exact steps you are taking where you are experiencing problems changing the server's CA? The only scenario I can reproduce here is if you change the CA but do not provide a server certificate and server key, then the router would generate all three of them. This isn't a new issue, and must have been there for a very long time. I just fixed this specific scenario by having the router no longer check the presence of the server key/cert to determine if a CA mus tbe auto-generated. However, I am not experiencing any problem if I change the CA without changing or removing the server key/certs that are currently present (tho a client would fail to connect with that, as the cert must be signed by the same CA).
Can you provide actual numbers?
Since upgrading to 384.10, I'm seeing this sequence of log entries over and over anywhere from 3 - 10 minutes apart. Any ideas what these mean and are they important? The router seems to be running OK and I'm not seeing any specific issues on network devices that use the router. Thanks.
Mar 31 17:21:45 kernel: pgd = ffffffc012b8c000
Mar 31 17:21:45 kernel: [00000000] *pgd=0000000012412003, *pud=0000000012412003, *pmd=00000000150c4003, *pte=0000000000000000
Mar 31 17:21:45 kernel: CPU: 1 PID: 25797 Comm: dcd Tainted: P O 4.1.27 #2
Mar 31 17:21:45 kernel: Hardware name: Broadcom-v8A (DT)
Mar 31 17:21:45 kernel: task: ffffffc01e0854c0 ti: ffffffc012ba4000 task.ti: ffffffc012ba4000
Mar 31 17:21:45 kernel: PC is at 0xf706bf44
Mar 31 17:21:45 kernel: LR is at 0x1dc74
Mar 31 17:21:45 kernel: pc : [<00000000f706bf44>] lr : [<000000000001dc74>] pstate: 600e0010
Mar 31 17:21:45 kernel: sp : 00000000ffa57418
Mar 31 17:21:45 kernel: x12: 000000000009ff10
Mar 31 17:21:45 kernel: x11: 00000000f62ff024 x10: 00000000000a02b4
Mar 31 17:21:45 kernel: x9 : 00000000f62ffa70 x8 : 00000000000a076c
Mar 31 17:21:45 kernel: x7 : 00000000f62ffaa8 x6 : 00000000000a0766
Mar 31 17:21:45 kernel: x5 : 0000000000000000 x4 : 00000000f62ffa54
Mar 31 17:21:45 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Mar 31 17:21:45 kernel: x1 : 000000000007c674 x0 : 0000000000000000​
Open the browser console and look for any Javascript error.
More info from the FireFox console:
SyntaxError: missing } after property list      Main_TrafficMonitor_devrealtime.asp:37:431
note: { opened at line 32, column 8             Main_TrafficMonitor_devrealtime.asp:32:8
ReferenceError: init is not defined             Main_TrafficMonitor_devrealtime.asp:1:1
onload http://192.168.0.1/Main_TrafficMonitor_devrealtime.asp:1:1
Known documented issue waiting for ASUS to fix...
Same issue here with answer....
https://www.snbforums.com/threads/strange-events-in-rt-ac86u-system-log.55851/
I have experienced that issue on prior firmware updates a time or two. When I did the update, the OpenVPN speeds went into the gutter. Reverting to the prior firmware fixed the issue. But I was a noob at the time. The resolution to the issue was to perform a factory reset after the firmware flash was completed followed by a manual reentering of the configuration. Have you tried a factory reset followed by a manual reenter of the configs to see if that helps?
What's on line 37?
