AdGuardHome [RELEASE] Asuswrt-Merlin-AdGuardHome-Installer (AMAGHI)
Run this command in terminal
opkg reinstall "$(opkg list zoneinfo* | printf "%s\n" "$(awk '{printf $1" "}')")" && opkg install "$(opkg list zoneinfo* | printf "%s\n" "$(awk '{printf $1" "}')")"
Tell me what the output of running
ls /opt/share/zoneinfo/zone.tab
opkg: unknown sub-command reinstall
ls: /opt/share/zoneinfo/zone.tab: No such file or directory
/tmp/mnt/SanDisk/entware/share/zoneinfo# ls
Asia Europe Hongkong Japan Poland Portugal Singapore
Okay run
Then repeat these two commands in terminal consecutively
And
Okay run
And
Unknown package 'zoneinfo-africa zoneinfo-asia zoneinfo-atlantic zoneinfo-australia-nz zoneinfo-core zoneinfo-europe zoneinfo-india zoneinfo-northamerica zoneinfo-pacific zoneinfo-poles zoneinfo-simple zoneinfo-southamerica '.
Collected errors:
* opkg_install_cmd: Cannot install package zoneinfo-africa zoneinfo-asia zoneinfo-atlantic zoneinfo-australia-nz zoneinfo-core zoneinfo-europe zoneinfo-india zoneinfo-northamerica zoneinfo-pacific zoneinfo-poles zoneinfo-simple zoneinfo-southamerica .
If you are not able to access /opt/share or /opt/share/zoneinfo directory then your entware may have a broken symlink or may in general be broken. That could be indication of a otherwise corrupt entware.
Good idea. I'll format the usb drive and start over. I'll just have AMTM and AdGuardHome installed and see how that goes.
thanks
Fresh Entware install after reformat is only installing these zones:
Installing zoneinfo-asia (2021e-1) to root...
Installing zoneinfo-europe (2021e-1) to root...
What is the output of
opkg list zoneinfo*
zoneinfo-africa - 2021e-1 - Zone Information (Africa)
zoneinfo-asia - 2021e-1 - Zone Information (Asia)
zoneinfo-atlantic - 2021e-1 - Zone Information (Atlantic)
zoneinfo-australia-nz - 2021e-1 - Zone Information (Australia-NZ)
zoneinfo-core - 2021e-1 - Zone Information (core)
zoneinfo-europe - 2021e-1 - Zone Information (Europe)
zoneinfo-india - 2021e-1 - Zone Information (India)
zoneinfo-northamerica - 2021e-1 - Zone Information (NorthAmerica)
zoneinfo-pacific - 2021e-1 - Zone Information (Pacific)
zoneinfo-poles - 2021e-1 - Zone Information (Arctic, Antarctic)
zoneinfo-simple - 2021e-1 - Zone Information (simple)
zoneinfo-southamerica - 2021e-1 - Zone Information (SouthAmerica)
Yea I see over 600 options when I choose mine.
Hi. Well I uninstalled AGH, Skynet and entware. I formatted the usb drive, re-install AGH using the curl command and before the TZ list if displayed I get the text below. Then it shows m 167 TZ's.
Info: Before setting up AdGuardHome, please choose your right timezone!
awk: /opt/share/zoneinfo/zone.tab: No such file or directory
Info: Available timezones/locations:
Sounds like you could possibly have a corrupt USB or entware install . You could try installing each one individually, uninstalling each one first
Looks like the entware package (opkg) no longer has dependencies for zones other than Europe and Asia.
Well I formatted a new USB dive, installed entware and installed AGH from the Amtm menu, not using the manual curl command. I get the same TZ error. I added an ADblock list to AGH and I still cannot get it to block any ads. I do not know what I could have missed. This is a vanilla setup with just Merlin defaults. From the 'just because file' I also deleted the cache on the test pc.
Well you are fine, it could all be tied into the TZ being wrong. If you wait on it till either late tonight or early tomorrow, I will have a working fix out.
My previous replies are showing up now.
I just patched the installer, You are welcome to give it a go. TZdata should be up and going. Now we will control the TZdata. Relatively easy to compile.
