pinkfloyd1173
Yes, I have fiber. 1 gig
Pictures are small on my phone and monitor and when blown up (zoomed in) I can't quite make it out. Is that first picture showing you have a 1gig connection?
Damn, so jealous.....Yes, I have fiber. 1 gig
Damn, so jealous.....At those speeds I don't think you would need QOS. Found this post where someone posted similar speeds and @FreshJR said the same thing. You'd have to throw a hell of a lan party to max those speeds out.
https://www.snbforums.com/threads/help-for-newbie-with-qos-voip.45701/#post-393393
No problem, I may be wrong and if I am i'm sure someone will chime in and correct me. That's a heck of a connection though.I see well wanted to try it out see if it helped?
Thanks again for every ones insight on this, learned alot.
Thanks, Just wanted to see if FreshQOS would improve my game play a bit, ping.
I wonder. I have 300 mbps and buffer bloat was heinous without the script.Damn, so jealous.....At those speeds I don't think you would need QOS. Found this post where someone posted similar speeds and @FreshJR said the same thing. You'd have to throw a hell of a lan party to max those speeds out.
At the moment I am having issues with DSL reports, I can not get any bb grades, sometimes it works and most of the time it does not? I cant figure it out.
I am using your script and I got mixed results.. On the desktop that is hard wired I got like 400 ms, on my cellphone on 5g I had 150 ms on a tablet that was connected to 2.4 ghz I had 100 ms.PSA: DSL Reports speed test is kinda fuxxed up right now, for many people. Some regions have servers which work well. In my region (Toronto, Canada on TekSavvy Cable) none of the servers are working reliably - and I'm getting totally wrong bufferbloat test results.
BTW, DSLReports has had these issues for the past 2-3 months... I feel like many tech-savvy users are moving away from them, and trying other speedtest sites...
As an alternative, try "fast.com" -> Show More Info -> "Loaded Latency".
If you're less than 100ms, your bufferbloat is probably OK. If it's more than 100ms (like 200, 400, 500ms...) then your bufferbloat is probably bad.
fast.com is more reliable because it is run by Netflix.
iptables -D OUTPUT -t mangle -o $wan -d 23.47.79.0/24 -p tcp -m multiport --dports 80 -j MARK --set-mark ${Net_mark_up} &> /dev/null #AIProtection wred queries as NetControl
iptables -A OUTPUT -t mangle -o $wan -d 23.47.79.0/24 -p tcp -m multiport --dports 80 -j MARK --set-mark ${Net_mark_up}
iptables -D OUTPUT -t mangle -o $wan -p tcp -m multiport ! --dports 53,123,853,80 -j MARK --set-mark ${Downloads_mark_up} &> /dev/null #VPN Fix - (Fixes upload traffic not detected when the router is acting as a VPN Client)
Welcome To SNBForums
