tried making my own thread but got no attention for my issue so i am reposting it here in hopes someone will see it and have an idea.
I am running an ac68u on johns fork 47D7. i try to install and run unbound. everything installs ok but as soon as it tries to startup it goes awol after 1 second. i have tried rebooting uninstalling reinstalling formatting my usb drive formatting the jffs and even reinstalling johns fork via the cfe loader at 192.168.1.1 nothing has helped. ive fought off urges to smash things a few times already. i hope someone can help me.
here is the errors
Starting unbound... failed.
00:52:53 Checking 'unbound.conf' for valid Syntax.....
00:52:54 Requesting unbound (S61unbound) restart.....
00:52:56 Checking status, please wait.....
***ERROR unbound went AWOL after 1 seconds.....
Try option 'debug' and check for unbound.conf or runtime errors!
Manual install unbound Customisation complete 5 minutes and 3 seconds elapsed - Please wait for up to 10 seconds for status.....
***ERROR Unsuccessful installation of unbound detected
Feb 7 00:52:54 (none) user.warn (unbound_manager): 2383 Requesting unbound (/opt/etc/init.d/S61unbound$) restart.....
Feb 7 00:52:54 (none) user.warn S61unbound: restart Unbound DNS server /opt/etc/init.d/S61unbound
Feb 7 00:52:56 (none) user.warn (dnsmasq.postconf): Updating /etc/dnsmasq.conf for unbound.....
Feb 7 00:52:56 (none) user.warn GXXxxXXX: Failed to start unbound from .
Feb 7 00:52:57 (none) user.warn (unbound_manager): 2383 ***ERROR unbound went AWOL after 1 seconds.... Try 'unbound -dv' and check for unbound.conf or runtime errors!
[1612677178] unbound[30751:0] notice: Start of unbound 1.12.0.
Feb 07 00:52:58 unbound[30751:0] debug: increased limit(open files) from 1024 to 2286
Feb 07 00:52:58 unbound[30751:0] debug: creating udp4 socket 127.0.0.1 53535
Feb 07 00:52:58 unbound[30751:0] debug: creating tcp4 socket 127.0.0.1 53535
Feb 07 00:52:58 unbound[30751:0] error: Setting TCP Fast Open as server failed: Protocol not available
Feb 07 00:52:58 unbound[30751:0] debug: creating udp6 socket :: 53535
Feb 07 00:52:58 unbound[30751:0] debug: creating tcp6 socket :: 53535
Feb 07 00:52:58 unbound[30751:0] debug: creating tcp4 socket 127.0.0.1 953
Feb 07 00:52:58 unbound[30751:0] error: error in SSL_CTX verify crypto error:25066067
SO support routines:dlfcn_load:could not load the shared library
Feb 07 00:52:58 unbound[30751:0] error: and additionally crypto error:25070067
SO support routines
SO_load:could not load the shared library
Feb 07 00:52:58 unbound[30751:0] error: and additionally crypto error:0E07506E:configuration file routines:module_load_dso:error loading dso
Feb 07 00:52:58 unbound[30751:0] error: and additionally crypto error:0E076071:configuration file routines:module_run:unknown module name
Feb 07 00:52:58 unbound[30751:0] error: and additionally crypto error:02001002:system library:fopen:No such file or directory
Feb 07 00:52:58 unbound[30751:0] error: and additionally crypto error:2006D080:BIO routines:BIO_new_file:no such file
Feb 07 00:52:58 unbound[30751:0] error: and additionally crypto error:0B084002:x509 certificate routines:X509_load_cert_crl_file:system lib
Feb 07 00:52:58 unbound[30751:0] fatal error: could not set up connect SSL_CTX
Rerun unbound_manager nochk and select the Remove option to backout changes
XXXXX@RT-AC68U-43B8:/tmp/home/root# unbound -dv
[1612677236] unbound[31475:0] notice: Start of unbound 1.12.0.
Feb 07 00:53:56 unbound[31475:0] error: error in SSL_CTX verify crypto error:25066067
Feb 07 00:53:56 unbound[31475:0] error: and additionally crypto error:25070067
SO support routines
Feb 07 00:53:56 unbound[31475:0] error: and additionally crypto error:0E07506E:configuration file routines:module_load_dso:error loading dso
Feb 07 00:53:56 unbound[31475:0] error: and additionally crypto error:0E076071:configuration file routines:module_run:unknown module name
Feb 07 00:53:56 unbound[31475:0] error: and additionally crypto error:02001002:system library:fopen:No such file or directory
Feb 07 00:53:56 unbound[31475:0] error: and additionally crypto error:2006D080:BIO routines:BIO_new_file:no such file
Feb 07 00:53:56 unbound[31475:0] error: and additionally crypto error:0B084002:x509 certificate routines:X509_load_cert_crl_file:system lib
Feb 07 00:53:56 unbound[31475:0] fatal error: could not set up connect SSL_CTX
XXXXXX@RT-AC68U-43B8:/tmp/home/root#
