scMerlin scMerlin - service and script control menu for AsusWRT-Merlin
It’s a childish boredom where I get interested in something and then drop it once I’ve had enough. :rolleyes:
I don't think you will get board if you decide to include android inside your ambitions of ScMerlin domination. Maybe an IFFT app or two as well. I can already imagine you telling Alexa to tell ScMerlin to restart your NTPD or your VPNS1.
AC-RT66U, 380.70.
Why I can see three VPN clients only?
Do you have an IP address defined for the other clients?
Sorry, I don't understand.
I have five clients by default.
Three of them have been set. The running one is first.
Scmerlin shows two inactive clients and one that was never configured. The first client that is running is not shown.
The script checks if the IP Address field for the VPN client has a value. Can you send a screenshot of the address field for each of your 5 clients?
Here we go.
Thanks - I think I have a bug in the way things enumerate. To confirm, can you run:
nvram show 2> /dev/null | grep ^vpn_client._addr
please?
vpn_client5_addr=
vpn_client3_addr=srv8.vpn.zaborona.help
vpn_client1_addr=vpn.zaborona.help
vpn_client4_addr=
vpn_client2_addr=vpn.zaborona.help
On my setup the clients are returned in order. Perhaps it is some other issue.
vpn_client1_addr=us-florida.privateinternetaccess.com
vpn_client2_addr=
vpn_client3_addr=us-atlanta.privateinternetaccess.com
vpn_client4_addr=str-arn302.strongconnectivity.com
vpn_client5_addr=
vpn_client5_addr=
vpn_client4_addr=
Can you run
scmerlin develop
and let me know if this fixes the issue?
Just pushed a change which should fix this, hopefully
First of all, I appreciate your work day by day - it's awsome what you and the other guys here make of that router :cool:
The latest fix seems not to work for me, the menu offers to restart Client 3, but I've configured only Client 1.
nvram show | grep vpn_client._addr
correctly lists Client 1 as the only one with an address. I'm running latest version 1.1.1
Edit - ahh I should have read all posts until the end... I'm not the only one with that issue.
In fact,
scmerlin develop
fixes the issue for me :)
In fact,
scmerlin develop
Cool, having someone verify it resolves the issue means I can merge the PR. I was hesitant to do it without confirmation of it actually fixing the problem!
I'm running Connmon, ntpMerlin, spdMerlin, YazFi, Skynet and uiDivStats. Occasionally after a reboot, the userX.asp pages don't correctly get setup and I won't be able to navigate to one or more of the custom pages. Is there something in scMerlin that would reset this or could be added.
Des your USB get mounted or does it show as unmounted in the initial page?
v1.1.2 is now available!
Changelog:
Fix for VPN Client enumeration when nvram vars are not in ascending numerical order
Jack Yaz
If you want to add another utility to scMerlin it might be helpful if you added the command to stop/remove Skynet in case it get corrupted. Recently my USB drive failed and after I replaced it Skynet kept looking for the old USB meaning that I had to SSH in and stop the firewall/Skynet before I could reinstall Skynet.
Thanks again for all your useful scripts.
Hey @Jack Yaz
As you can see, only my vpn client 3 is on - so that should the the only one to show for reboot.
However, it's also showing the first one (Wich is stopped)
