At a guess, the symlinks don't exist. Next time it happens...
Code:ls - laR /www/user/
/www/user/:
drwxr-xr-x 7 admin root 280 Apr 28 00:26 .
drwxr-xr-x 4 admin root 80 Jan 1 1970 ..
drwxr-xr-x 2 admin root 40 Jan 1 1970 cgi-bin
drwxrwxrwx 2 admin root 100 Apr 29 01:20 connmon
drwxrwxrwx 2 admin root 80 Apr 29 01:20 ntpmerlin
lrwxrwxrwx 1 admin root 22 May 5 2018 shared-jy -> /jffs/addons/shared-jy
drwxrwxrwx 2 admin root 100 Apr 28 23:17 spdmerlin
drwxrwxrwx 2 admin root 300 Apr 28 23:19 uiScribe
-rw-rw-rw- 1 admin root 25185 May 5 2018 user1.asp
-rw-rw-rw- 1 admin root 18 May 5 2018 user1.title
-rw-rw-rw- 1 admin root 19648 Apr 28 00:26 user2.asp
-rw-rw-rw- 1 admin root 11 Apr 28 00:26 user2.title
-rw-rw-rw- 1 admin root 31418 Apr 28 00:11 user3.asp
-rw-rw-rw- 1 admin root 10 Apr 28 00:11 user3.title
/www/user/cgi-bin:
drwxr-xr-x 2 admin root 40 Jan 1 1970 .
drwxr-xr-x 7 admin root 280 Apr 28 00:26 ..
/www/user/connmon:
drwxrwxrwx 2 admin root 100 Apr 29 01:20 .
lrwxrwxrwx 1 admin root 29 Apr 29 01:20 config.htm -> /jffs/addons/connmon.d/config
lrwxrwxrwx 1 admin root 39 Apr 29 01:20 connstatstext.js -> /jffs/addons/connmon.d/connstatstext.js
lrwxrwxrwx 1 admin root 26 Apr 29 01:20 csv -> /jffs/addons/connmon.d/csv
/www/user/ntpmerlin:
drwxrwxrwx 2 admin root 80 Apr 29 01:20 .
lrwxrwxrwx 1 admin root 28 Apr 29 01:20 csv -> /jffs/addons/ntpmerlin.d/csv
lrwxrwxrwx 1 admin root 40 Apr 29 01:20 ntpstatstext.js -> /jffs/addons/ntpmerlin.d/ntpstatstext.js
/www/user/spdmerlin:
drwxrwxrwx 2 admin root 100 Apr 28 23:17 .
lrwxrwxrwx 1 admin root 26 Apr 28 23:17 csv -> /opt/share/spdmerlin.d/csv
lrwxrwxrwx 1 admin root 39 Apr 28 23:17 interfaces.htm -> /opt/share/spdmerlin.d/.interfaces_user
lrwxrwxrwx 1 admin root 31 Apr 28 23:17 spdjs.js -> /opt/share/spdmerlin.d/spdjs.js
/www/user/uiScribe:
drwxrwxrwx 2 admin root 300 Apr 28 23:19 .
lrwxrwxrwx 1 admin root 24 Apr 28 23:19 NextDNS.log.htm -> /opt/var/log/NextDNS.log
lrwxrwxrwx 1 admin root 27 Apr 28 23:19 OwnScripts.log.htm -> /opt/var/log/OwnScripts.log
lrwxrwxrwx 1 admin root 22 Apr 28 23:19 crash.log.htm -> /opt/var/log/crash.log
lrwxrwxrwx 1 admin root 24 Apr 28 23:19 dnsmasq.log.htm -> /opt/var/log/dnsmasq.log
lrwxrwxrwx 1 admin root 25 Apr 28 23:19 firewall.log.htm -> /opt/var/log/firewall.log
lrwxrwxrwx 1 admin root 26 Apr 28 23:19 logrotate.log.htm -> /opt/var/log/logrotate.log
lrwxrwxrwx 1 admin root 34 Apr 28 23:19 logs.htm -> /jffs/addons/uiScribe.d/.logs_user
lrwxrwxrwx 1 admin root 21 Apr 28 23:19 messages.htm -> /opt/var/log/messages
lrwxrwxrwx 1 admin root 20 Apr 28 23:19 ntp.log.htm -> /opt/var/log/ntp.log
lrwxrwxrwx 1 admin root 24 Apr 28 23:19 openvpn.log.htm -> /opt/var/log/openvpn.log
lrwxrwxrwx 1 admin root 26 Apr 28 23:19 spdmerlin.log.htm -> /opt/var/log/spdmerlin.log
lrwxrwxrwx 1 admin root 26 Apr 28 23:19 syslog-ng.log.htm -> /opt/var/log/syslog-ng.log
lrwxrwxrwx 1 admin root 26 Apr 28 23:19 wlceventd.log.htm -> /opt/var/log/wlceventd.log
/www/user/:
drwxrwxrwx 2 admin root 100 Apr 29 01:25 connmon
drwxrwxrwx 2 admin root 100 Apr 29 01:24 spdmerlin
/www/user/cgi-bin:
/www/user/connmon:
drwxrwxrwx 2 admin root 100 Apr 29 01:25 .
lrwxrwxrwx 1 admin root 29 Apr 29 01:25 config.htm -> /jffs/addons/connmon.d/config
lrwxrwxrwx 1 admin root 39 Apr 29 01:25 connstatstext.js -> /jffs/addons/connmon.d/connstatstext.js
lrwxrwxrwx 1 admin root 26 Apr 29 01:25 csv -> /jffs/addons/connmon.d/csv
drwxrwxrwx 2 admin root 100 Apr 29 01:24 .
lrwxrwxrwx 1 admin root 26 Apr 29 01:24 csv -> /opt/share/spdmerlin.d/csv
lrwxrwxrwx 1 admin root 39 Apr 29 01:24 interfaces.htm -> /opt/share/spdmerlin.d/.interfaces_user
lrwxrwxrwx 1 admin root 31 Apr 29 01:24 spdjs.js -> /opt/share/spdmerlin.d/spdjs.js
/www/user/uiScribe:
Guys, I lost my SpdMerlin tab again, and it hasn't ran in about 8 hours. I think my router may be crashing randomly. The first instance after I think it did is:
May 5 00:05:16 spdMerlin: Entware not found, sleeping for 10s (attempt 1 of 10)
then:
Apr 28 16:43:34 custom_script: Running /jffs/scripts/service-event (args: updateresolv)
Apr 28 16:43:35 spdMerlin: Stale lock file found (>120 seconds old) - purging lock
Apr 28 16:43:35 spdMerlin: Entware not found, sleeping for 10s (attempt 1 of 10)
Apr 28 16:43:35 Diversion: Starting Entware and Diversion services on /tmp/mnt/sda1
Apr 28 16:43:35 kernel: klogd: exiting
Apr 28 16:43:36 RT-AC86U-8F38 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Apr 28 16:43:36 RT-AC86U-8F38 custom_script: Running /jffs/scripts/nat-start
Apr 28 16:43:36 RT-AC86U-8F38 jtstrickland: Started ntpd from /jffs/scripts/post-mount.
Apr 28 16:43:36 RT-AC86U-8F38 ntpMerlin: Sleeping for 5s to allow firewall/nat startup to be completed...
Apr 28 16:43:36 RT-AC86U-8F38 avahi-daemon[988]: Registering new address record for 192.168.1.2 on br0.IPv4.
Apr 28 16:43:36 RT-AC86U-8F38 pixelserv-tls[3381]: pixelserv-tls 2.3.1 (compiled: Jan 31 2020 13:27:14 flags: tfo tls1_3) options: 192.168.1.2
Apr 28 16:43:36 RT-AC86U-8F38 Entware (aarch64-k3.10): Started pixelserv-tls (Diversion)
Apr 28 16:43:36 RT-AC86U-8F38 rc_service: service 3395:notify_rc restart_dnsmasq
Apr 28 16:43:36 RT-AC86U-8F38 custom_script: Running /jffs/scripts/service-event (args: restart dnsmasq)
Apr 28 16:43:36 RT-AC86U-8F38 dnsmasq[2150]: exiting on receipt of SIGTERM
and so on....
I'm afraid something is going on there. Last time I lost my tab before Jack fixed it, SpdMerlin was still running. I applied the minimum recent update just now and hope that takes care of it.
I wish I knew how to read the logs and what to look for, but I can't find much on it.
thanks,
jts
edit: It is back running now after the update and forcing a speed test earlier, but I don't have the user interface with graphs etc, but I haven't rebooted yet. Maybe that took care of it.
RT-AC86U w/ 384.17, RT-AC68U Aimesh node w/ same, Diversion, UiDivstats, Skynet, AiProtection, Scribe, UiScribe, Conmon, SpdMerlin, ScMerlin, Nsrum, NtpMerlin, OpenVPN selective clients
I may need to increase the delay time for entware to be available, or my lock method is outdated since the time jump will clear it. Oddly I've rebooted my router several times over the last 2 days and I'm not seeing any issues.Guys, I lost my SpdMerlin tab again, and it hasn't ran in about 8 hours. I think my router may be crashing randomly. The first instance after I think it did is:
then:
and so on....
thanks,
jts
OK so the symlinks appear to be in place. Do you see any browser console errors?Code:/www/user/: drwxr-xr-x 7 admin root 280 Apr 28 00:26 . drwxr-xr-x 4 admin root 80 Jan 1 1970 .. drwxr-xr-x 2 admin root 40 Jan 1 1970 cgi-bin drwxrwxrwx 2 admin root 100 Apr 29 01:20 connmon drwxrwxrwx 2 admin root 80 Apr 29 01:20 ntpmerlin lrwxrwxrwx 1 admin root 22 May 5 2018 shared-jy -> /jffs/addons/shared-jy drwxrwxrwx 2 admin root 100 Apr 28 23:17 spdmerlin drwxrwxrwx 2 admin root 300 Apr 28 23:19 uiScribe -rw-rw-rw- 1 admin root 25185 May 5 2018 user1.asp -rw-rw-rw- 1 admin root 18 May 5 2018 user1.title -rw-rw-rw- 1 admin root 19648 Apr 28 00:26 user2.asp -rw-rw-rw- 1 admin root 11 Apr 28 00:26 user2.title -rw-rw-rw- 1 admin root 31418 Apr 28 00:11 user3.asp -rw-rw-rw- 1 admin root 10 Apr 28 00:11 user3.title /www/user/cgi-bin: drwxr-xr-x 2 admin root 40 Jan 1 1970 . drwxr-xr-x 7 admin root 280 Apr 28 00:26 .. /www/user/connmon: drwxrwxrwx 2 admin root 100 Apr 29 01:20 . drwxr-xr-x 7 admin root 280 Apr 28 00:26 .. lrwxrwxrwx 1 admin root 29 Apr 29 01:20 config.htm -> /jffs/addons/connmon.d/config lrwxrwxrwx 1 admin root 39 Apr 29 01:20 connstatstext.js -> /jffs/addons/connmon.d/connstatstext.js lrwxrwxrwx 1 admin root 26 Apr 29 01:20 csv -> /jffs/addons/connmon.d/csv /www/user/ntpmerlin: drwxrwxrwx 2 admin root 80 Apr 29 01:20 . drwxr-xr-x 7 admin root 280 Apr 28 00:26 .. lrwxrwxrwx 1 admin root 28 Apr 29 01:20 csv -> /jffs/addons/ntpmerlin.d/csv lrwxrwxrwx 1 admin root 40 Apr 29 01:20 ntpstatstext.js -> /jffs/addons/ntpmerlin.d/ntpstatstext.js /www/user/spdmerlin: drwxrwxrwx 2 admin root 100 Apr 28 23:17 . drwxr-xr-x 7 admin root 280 Apr 28 00:26 .. lrwxrwxrwx 1 admin root 26 Apr 28 23:17 csv -> /opt/share/spdmerlin.d/csv lrwxrwxrwx 1 admin root 39 Apr 28 23:17 interfaces.htm -> /opt/share/spdmerlin.d/.interfaces_user lrwxrwxrwx 1 admin root 31 Apr 28 23:17 spdjs.js -> /opt/share/spdmerlin.d/spdjs.js /www/user/uiScribe: drwxrwxrwx 2 admin root 300 Apr 28 23:19 . drwxr-xr-x 7 admin root 280 Apr 28 00:26 .. lrwxrwxrwx 1 admin root 24 Apr 28 23:19 NextDNS.log.htm -> /opt/var/log/NextDNS.log lrwxrwxrwx 1 admin root 27 Apr 28 23:19 OwnScripts.log.htm -> /opt/var/log/OwnScripts.log lrwxrwxrwx 1 admin root 22 Apr 28 23:19 crash.log.htm -> /opt/var/log/crash.log lrwxrwxrwx 1 admin root 24 Apr 28 23:19 dnsmasq.log.htm -> /opt/var/log/dnsmasq.log lrwxrwxrwx 1 admin root 25 Apr 28 23:19 firewall.log.htm -> /opt/var/log/firewall.log lrwxrwxrwx 1 admin root 26 Apr 28 23:19 logrotate.log.htm -> /opt/var/log/logrotate.log lrwxrwxrwx 1 admin root 34 Apr 28 23:19 logs.htm -> /jffs/addons/uiScribe.d/.logs_user lrwxrwxrwx 1 admin root 21 Apr 28 23:19 messages.htm -> /opt/var/log/messages lrwxrwxrwx 1 admin root 20 Apr 28 23:19 ntp.log.htm -> /opt/var/log/ntp.log lrwxrwxrwx 1 admin root 24 Apr 28 23:19 openvpn.log.htm -> /opt/var/log/openvpn.log lrwxrwxrwx 1 admin root 26 Apr 28 23:19 spdmerlin.log.htm -> /opt/var/log/spdmerlin.log lrwxrwxrwx 1 admin root 26 Apr 28 23:19 syslog-ng.log.htm -> /opt/var/log/syslog-ng.log lrwxrwxrwx 1 admin root 26 Apr 28 23:19 wlceventd.log.htm -> /opt/var/log/wlceventd.log
and after running a speedtest (which causes the graphs to reappear on GUI):
Code:/www/user/: drwxr-xr-x 7 admin root 280 Apr 28 00:26 . drwxr-xr-x 4 admin root 80 Jan 1 1970 .. drwxr-xr-x 2 admin root 40 Jan 1 1970 cgi-bin drwxrwxrwx 2 admin root 100 Apr 29 01:25 connmon drwxrwxrwx 2 admin root 80 Apr 29 01:20 ntpmerlin lrwxrwxrwx 1 admin root 22 May 5 2018 shared-jy -> /jffs/addons/shared-jy drwxrwxrwx 2 admin root 100 Apr 29 01:24 spdmerlin drwxrwxrwx 2 admin root 300 Apr 28 23:19 uiScribe -rw-rw-rw- 1 admin root 25185 May 5 2018 user1.asp -rw-rw-rw- 1 admin root 18 May 5 2018 user1.title -rw-rw-rw- 1 admin root 19648 Apr 28 00:26 user2.asp -rw-rw-rw- 1 admin root 11 Apr 28 00:26 user2.title -rw-rw-rw- 1 admin root 31418 Apr 28 00:11 user3.asp -rw-rw-rw- 1 admin root 10 Apr 28 00:11 user3.title /www/user/cgi-bin: drwxr-xr-x 2 admin root 40 Jan 1 1970 . drwxr-xr-x 7 admin root 280 Apr 28 00:26 .. /www/user/connmon: drwxrwxrwx 2 admin root 100 Apr 29 01:25 . drwxr-xr-x 7 admin root 280 Apr 28 00:26 .. lrwxrwxrwx 1 admin root 29 Apr 29 01:25 config.htm -> /jffs/addons/connmon.d/config lrwxrwxrwx 1 admin root 39 Apr 29 01:25 connstatstext.js -> /jffs/addons/connmon.d/connstatstext.js lrwxrwxrwx 1 admin root 26 Apr 29 01:25 csv -> /jffs/addons/connmon.d/csv /www/user/ntpmerlin: drwxrwxrwx 2 admin root 80 Apr 29 01:20 . drwxr-xr-x 7 admin root 280 Apr 28 00:26 .. lrwxrwxrwx 1 admin root 28 Apr 29 01:20 csv -> /jffs/addons/ntpmerlin.d/csv lrwxrwxrwx 1 admin root 40 Apr 29 01:20 ntpstatstext.js -> /jffs/addons/ntpmerlin.d/ntpstatstext.js /www/user/spdmerlin: drwxrwxrwx 2 admin root 100 Apr 29 01:24 . drwxr-xr-x 7 admin root 280 Apr 28 00:26 .. lrwxrwxrwx 1 admin root 26 Apr 29 01:24 csv -> /opt/share/spdmerlin.d/csv lrwxrwxrwx 1 admin root 39 Apr 29 01:24 interfaces.htm -> /opt/share/spdmerlin.d/.interfaces_user lrwxrwxrwx 1 admin root 31 Apr 29 01:24 spdjs.js -> /opt/share/spdmerlin.d/spdjs.js /www/user/uiScribe: drwxrwxrwx 2 admin root 300 Apr 28 23:19 . drwxr-xr-x 7 admin root 280 Apr 28 00:26 .. lrwxrwxrwx 1 admin root 24 Apr 28 23:19 NextDNS.log.htm -> /opt/var/log/NextDNS.log lrwxrwxrwx 1 admin root 27 Apr 28 23:19 OwnScripts.log.htm -> /opt/var/log/OwnScripts.log lrwxrwxrwx 1 admin root 22 Apr 28 23:19 crash.log.htm -> /opt/var/log/crash.log lrwxrwxrwx 1 admin root 24 Apr 28 23:19 dnsmasq.log.htm -> /opt/var/log/dnsmasq.log lrwxrwxrwx 1 admin root 25 Apr 28 23:19 firewall.log.htm -> /opt/var/log/firewall.log lrwxrwxrwx 1 admin root 26 Apr 28 23:19 logrotate.log.htm -> /opt/var/log/logrotate.log lrwxrwxrwx 1 admin root 34 Apr 28 23:19 logs.htm -> /jffs/addons/uiScribe.d/.logs_user lrwxrwxrwx 1 admin root 21 Apr 28 23:19 messages.htm -> /opt/var/log/messages lrwxrwxrwx 1 admin root 20 Apr 28 23:19 ntp.log.htm -> /opt/var/log/ntp.log lrwxrwxrwx 1 admin root 24 Apr 28 23:19 openvpn.log.htm -> /opt/var/log/openvpn.log lrwxrwxrwx 1 admin root 26 Apr 28 23:19 spdmerlin.log.htm -> /opt/var/log/spdmerlin.log lrwxrwxrwx 1 admin root 26 Apr 28 23:19 syslog-ng.log.htm -> /opt/var/log/syslog-ng.log lrwxrwxrwx 1 admin root 26 Apr 28 23:19 wlceventd.log.htm -> /opt/var/log/wlceventd.log
Didn't remember to check if any.OK so the symlinks appear to be in place. Do you see any browser console errors?
I think I've found the bug. thanks for troubleshooting!Edit: just changed from USB to jffs and graphs disappeared! Unfortunately I'm on mobile and I don't have developer option there!
To solve it, either change back to USB or perform a speedtest
Latest develop branch commit should fix this, if you're willing to test? Also added is an NTP sync check to make sure NTP is synced before any script actions can be runDidn't remember to check if any.
I'll check it once it happens again, which I don't know when because I haven't found a pattern!
First I thought it was when changing from master<->develop. But then no, i just changed and graphs are still there.
Then I thought it was when changing USB<->jffs, but also I can't reproduce that way anymore.
Just tested. Seems fine and working wellLatest develop branch commit should fix this, if you're willing to test? Also added is an NTP sync check to make sure NTP is synced before any script actions can be run
If you were affected by missing tabs etc. on reboot, are you able to test this as well please?Just tested. Seems fine and working well
Thank you!!
I wasn't affected by this problem on reboots.If you were affected by missing tabs etc. on reboot, are you able to test this as well please?
No, I am not familiar yet with the disk check utility. I will try to investigate it an turn it on as soon as I learn how.Almost certainly youir USB disk is faulty since Entware is installed on that - I assume you have the disk check script enabled via amtm
running the below is enough to re-mount the tabI lost the tab a couple of days ago. Stopping and restarting several times wasn't enough to restore the tab. Also my connection from my ISP went down which forced a router reboot in my system and still no tab. I had to remove spdMerlin and then reinstall. Was able to save most of the data.
I will update prior to moving to 384.17 and let you know if I have any issues.
spdmerlin startup
spdMerlin: MD5 hash of spdMerlin does not match - downloading updated v3.5.1
spdMerlin: spdMerlin successfully updated
That's when I release a quick hotfix without wanting to increment the version number. I try to avoid it if at all possible.I have spdMerlin 3.5.1 installed. When checking for updates by amtm it says minor update is avaialable to 3.5.1 ??? When going to the script and choose to update it says:
Code:spdMerlin: MD5 hash of spdMerlin does not match - downloading updated v3.5.1 spdMerlin: spdMerlin successfully updated
Welcome To SNBForums
