CaptainSTX
Part of the Furniture
running the below is enough to re-mount the tab
Code:spdmerlin startup
Another blade you could add to your Swiss army knife scMerlin.
Thanks for the quick reply.
You need to start your own thread. Posting inside of a spdmerlin thread won't get you help faster. If anything it will limit who actually sees your question/comment.RT-AC86U w/ 384.17, RT-AC68U Aimesh node w/ same, Diversion, UiDivstats, Skynet, AiProtection, Scribe, UiScribe, Conmon, SpdMerlin, ScMerlin, Nsrum, NtpMerlin, OpenVPN selective clients
Can anyone tell me the proper way to replace a usb drive w/swap file etc?
Can I copy the contents of my old one to a new one using a windows 10 computer?
I read that one should dismount wine upgrading firmware, and I never have because I didn't know it. That may be what is wrong with mine.
Should I change the config & stats from usb back to jffs? And conmon also?
Any brand or size work better than the other?
I will appreciate any help with this.
jts
andresmorago@RT-AC3100-0548:/tmp/home/root# ls - laR /www/user/
ls: -: No such file or directory
ls: laR: No such file or directory
/www/user/:
cgi-bin shared-jy uiDivStats user1.title user4.asp user5.title
connmon skynet uiScribe user2.asp user4.title
ntpmerlin spdmerlin user1.asp user3.asp user5.asp
Apr 29 20:58:54 RT-AC3100-0548 ntpMerlin: New version of ntpMerlin available - updating to v2.4.2
Apr 29 20:58:57 RT-AC3100-0548 ntpMerlin: ntpMerlin successfully updated
Apr 29 20:59:31 RT-AC3100-0548 dropbear[15850]: Exit (andresmorago): Exited normally
Apr 29 21:00:00 RT-AC3100-0548 rc_service: httpd 362:notify_rc start_spdmerlincheckupdate
Apr 29 21:00:00 RT-AC3100-0548 custom_script: Running /jffs/scripts/service-event (args: start spdmerlincheckupdate)
Apr 29 21:00:01 RT-AC3100-0548 rc: received unrecognized event: spdmerlincheckupdate
Apr 29 21:00:38 RT-AC3100-0548 dropbear[24858]: Password auth succeeded for 'andresmorago' from 10.0.1.2:62821
Apr 29 21:00:56 RT-AC3100-0548 spdMerlin: Mounting spdMerlin WebUI page as user4.asp
Apr 29 21:02:43 RT-AC3100-0548 spdMerlin: Downloading latest version (v3.5.2) of spdMerlin
Apr 29 21:02:47 RT-AC3100-0548 spdMerlin: spdMerlin successfully updated
hi
i just updated the script to the latest version and im no longer able to see the charts. user4 page is shown
can you please advise?
Code:andresmorago@RT-AC3100-0548:/tmp/home/root# ls - laR /www/user/ ls: -: No such file or directory ls: laR: No such file or directory /www/user/: cgi-bin shared-jy uiDivStats user1.title user4.asp user5.title connmon skynet uiScribe user2.asp user4.title ntpmerlin spdmerlin user1.asp user3.asp user5.asp andresmorago@RT-AC3100-0548:/tmp/home/root#
thanks!Code:Apr 29 20:58:54 RT-AC3100-0548 ntpMerlin: New version of ntpMerlin available - updating to v2.4.2 Apr 29 20:58:57 RT-AC3100-0548 ntpMerlin: ntpMerlin successfully updated Apr 29 20:59:31 RT-AC3100-0548 dropbear[15850]: Exit (andresmorago): Exited normally Apr 29 21:00:00 RT-AC3100-0548 rc_service: httpd 362:notify_rc start_spdmerlincheckupdate Apr 29 21:00:00 RT-AC3100-0548 custom_script: Running /jffs/scripts/service-event (args: start spdmerlincheckupdate) Apr 29 21:00:01 RT-AC3100-0548 rc: received unrecognized event: spdmerlincheckupdate Apr 29 21:00:38 RT-AC3100-0548 dropbear[24858]: Password auth succeeded for 'andresmorago' from 10.0.1.2:62821 Apr 29 21:00:56 RT-AC3100-0548 spdMerlin: Mounting spdMerlin WebUI page as user4.asp Apr 29 21:02:43 RT-AC3100-0548 spdMerlin: Downloading latest version (v3.5.2) of spdMerlin Apr 29 21:02:47 RT-AC3100-0548 spdMerlin: spdMerlin successfully updated
TryMy spdMerlin tab disappeared from the GUI, but when I log into AMTM, it still shows up as a loaded script. Anyway to get the tab back in the GUI?
spdmerlin startup
FYI command shouldn't have a space after the -hi
TryCode:spdmerlin startup
Didn't mean to sound harsh but you should have added this to your initial post then. Nothing you stated in the original post said or led anyone to believe it was related to SpdMerlin.The reason I posted here is because I felt like spdmerlin may have been the cause of it, but didn't know, when I was testing one of the pre-release versions with the usb option. And I felt I should ask here whether or not to take my spdmerlin config & stats out of the usb and put them back into the jffs. Folks get frowned upon for duplicate posts.
but thanks anyway. I will figure it out I reckon.
Hm, the "server" version is meant to be set after an update. Hit update, it does a forced update anyway
thanks. typo was corrected and the outputs showed properly now.FYI command shouldn't have a space after the -
Also please check for errors reported in the browser's console (usually revealed by pressing F12 on the keyboard)
jts
Check here....this may answer your question.Nor did I. I debated and mulled over where to ask at. I had earlier posts about it, but they were not all in a row the way I read and post my own, so I can't expect everybody to read every thread, especially those that I have posted. I imagine it gets old answering seemingly silly questions from Noobs like me over and over, and sometimes they go unanswered. I do try to search and think about it before I ask, but sometimes they are still silly.
I do appreciate any help that I get, including criticism.
thanks,
jts
Thread starter | Title | Forum | Replies | Date |
vnStat Exclude spdMerlin from vnStat reports | Asuswrt-Merlin AddOns | 3 | |
Router Speed Test (spdMerlin) | Asuswrt-Merlin AddOns | 5 |
Welcome To SNBForums
