spdMerlin spdMerlin - Automated speedtests with graphs
Updated, and my tab disappeared again.
spdmerlin startup brought it back
(Note, I didn't reboot the router, just updated the script)
updating shouldn't affect the tab at all...the only time it is mounted is during the startup command. something else on your router must be tampering with /tmp/menuTree.js
I assume you mean the whole tab, and not just charts/data on the tab itself?
Yes, the "SpeedTest" tab in the Addons (also the same with the "Uptime Monitoring" tab were missing). But they are back since I ran the startup commands.
Note: There was also an update for nsrum, which I ran (I ran all three updates), not sure if that had anything to do with it.
Hi, I updated spdMerlin to 3.5.2 and changed its store location to usb. I can no longer see its user asp page. What am I missing?
Common works fine after recent upgrade and change of store location to usb.
Post the contents of /tmp/menuTree.js please
Also lost my graphs and stats section today (not the tab). Shouldn't be caused by the latest update since they were still there after the update. After that i updated some entware packages and installed connmon. Connmon graphs are still showing. But i noticed this error in the console when the SpeedTest tab is shown:
ReferenceError: Can't find variable: SetSPDStatsTitle
initial — user1.asp:531
onload — user1.asp:867
When writing this i just reloaded the page and the stats and graphs are back with no errors. Strange.....
Speed Test disappeared, reinstall does not help
menuName: "Addons",
index: "menu_Addons",
tab: [
{url: "user1.asp", tabName: "Diversion Stats"},
{url: "user3.asp", tabName: "Uptime Monitoring"},
{url: "user4.asp", tabName: "NTP Daemon"},
{url: "javascript:window.open('/ext/shared-jy/redirect.htm','_blank')", tabName: "Help & Support"},
{url: "NULL", tabName: "__INHERIT__"}
menuName: "Addons",
tab: [
DO you run anything in particular before it disappears? Anything in syslog?
I think it disappeared either after upgrade of spdMerln and common to latest version or change of logging to usb. I can grep syslog if you tell me where
I tried uploading file to the forum, but did not work - perhaps blocked for new joiners or not compatible with Chrome or does not like *.js files. I checked in www - I guess spd should be user5.asp - it dos not exist in user/ folder
Look for where spdmerlin is updated - that's the only time that /tmp/menuTree.js is touched, if the ASP has a new version
yes whole tab is gone and there's no userX.asp I could simply added. And I was not tinkering with it manually
