spdMerlin spdMerlin - Automated speedtests with graphs
- Rt-ac 88U 380.70 here.
Installed fine through curl
Populates stats (see attached) fine
Same tab problem : landing on the Administration section.
Nope. The unistall PLUS opkg update PLUS install curl did not update the tabs. I have a feeling that the graphs may not update either. Have not seen a single dot on the graphs. I guess, I will wait and see if they update.
Graphs will be unaffected. The tab issue is a side effect of me hijacking an unused page from the WebUI
380.xx also likely different, please send through custom_menuTree.js from /jffs/scripts
Attached Custom menuTree for AC88 380.50.
Hope it's Ok with forum rules to post it here.
Many thanks for this very interesting and useful script
And apologies for not introducing myself before : I'm Etienne Victoria, living in France, AC87 384.10, AC88 380.70, amtm, Diversion, Skynet and learning a lot from these forums.
Edit : No, the extension is not allowed. Will try to send through private message
ReEdit : attached .txt
Thanks - should be fixed if you run option u and pull down the latest version
@Marin hopefully fixed for you and other AX88U users too
Pulled V.1.0.0 enhanced with uf
Regenerated graphics
Cleared browser (Chrome) cache
Graphics still show fine but land on the Administration Page.
Not a big issue IMHO
And graphics do reflect accurately my throughput: 200 down 20 up.
Pulled V.1.0.0 enhanced with fu
Apologies, you also need to run this (not in the spdMerlin menu!)
spdmerlin startup
spdmerlin startup
No worries.
Fixed !!! Thanks !
Graphs do remain where they belong in the Tools section.
Oddly you have 2 NTP Daemon tabs now...might be worth a reboot to clear things down
The 2 NTP Daemon were there well before Spdmerlin.
Only one of them shows the NTP stats.
Will reboot anyway, thanks.
Thanks @Jack Yaz! Just read your message but getting ready to head to work. I will try it again when I come back tonight and will let you know.
@Jack Yaz I installed this again on my AX88U. Giving it a second shot, the install went perfect. The page is where is should be. Waiting for tests to see if thee is any pipe saturation issue. So far so good! ;):)
Ok it still freaks out the Streaming I do. Any ideas?
The download half of the test isn't categorized at all and the upload is in file transferring.
I can report this installed without issue on my RT-AC66U_B1. Only concern is the first round of speed tests on my 200 Mbps line show only 80 Mbps down The regular speed tests show correctly. I'll see what happens going forward.
Give it a few runs (2x per hour) I noticed that the last runs were much closer (at least on download). :)
