bluzfanmr1
Give it a few runs (2x per hour) I noticed that the last runs were much closer (at least on download).![]()
Ok getting better after a reboot and some patience. Last test shows 121 Mbps.
When I run
spdmerlin 1
spdmerlin 1
They'll get attributed to the closest 30mins, I believe - this feature made more sense for ntpMerlin which accepts data every 5 mins.Ok getting better after a reboot and some patience. Last test shows 121 Mbps.
When I runit says a speedtest is run. Should those test be showing on the graphs individually or will it fold into an average for that hours tests that have/will run? I do not see where these manual test are showing in the graphs.Code:spdmerlin 1
Choose an option: 1
spdMerlin: Starting speedtest now...
ERROR:root:code for hash md5 was not found.
Traceback (most recent call last):
File "/opt/lib/python2.7/hashlib.py", line 147, in <module>
File "/opt/lib/python2.7/hashlib.py", line 97, in __get_builtin_constructor
ValueError: unsupported hash type md5
ERROR:root:code for hash sha1 was not found.
ValueError: unsupported hash type sha1
ERROR:root:code for hash sha224 was not found.
ValueError: unsupported hash type sha224
ERROR:root:code for hash sha256 was not found.
ValueError: unsupported hash type sha256
ERROR:root:code for hash sha384 was not found.
ValueError: unsupported hash type sha384
ERROR:root:code for hash sha512 was not found.
ValueError: unsupported hash type sha512
File "/jffs/scripts/spdcli.py", line 126, in <module>
from md5 import md5
File "/opt/lib/python2.7/md5.py", line 10, in <module>
ImportError: cannot import name md5
spdMerlin: Finished speedtest
spdMerlin: Speedtest results - - -
## _ __ __ _ _ ##
## | || \/ | | |(_) ##
## ___ _ __ __| || \ / | ___ _ __ | | _ _ __ ##
## / __|| '_ \ / _ || |\/| | / _ \| '__|| || || '_ \ ##
## \__ \| |_) || (_| || | | || __/| | | || || | | | ##
## |___/| .__/ \__,_||_| |_| \___||_| |_||_||_| |_| ##
## |_| ##
## v1.0.1 on RT-AX88U ##
## https://github.com/jackyaz/spdMerlin ##
1. Run a speedtest now
u. Check for updates
uf. Update spdMerlin with latest version (force update)
e. Exit spdMerlin
z. Uninstall spdMerlin
Choose an option: 1
spdMerlin: Speedtest results - Download: 124.11 Mbit/s - Upload: 12.18 Mbit/s - Ping: 92.936 ms
The graphs seem to reappear after spdmerlin runs a speed test.It looks like this issue is affecting my sdpMerlin as well :https://www.snbforums.com/threads/ntpmerlin-installer-for-kvic-ntp-daemon.55756/page-14#post-477926
Which firmware version? Looks like a problem with the Python install from EntwareHi
I just installed on my ac68u. when trying to run, i got the following errors
Code:Choose an option: 1 spdMerlin: Starting speedtest now... ERROR:root:code for hash md5 was not found. Traceback (most recent call last): File "/opt/lib/python2.7/hashlib.py", line 147, in <module> File "/opt/lib/python2.7/hashlib.py", line 97, in __get_builtin_constructor ValueError: unsupported hash type md5 ERROR:root:code for hash sha1 was not found. Traceback (most recent call last): File "/opt/lib/python2.7/hashlib.py", line 147, in <module> File "/opt/lib/python2.7/hashlib.py", line 97, in __get_builtin_constructor ValueError: unsupported hash type sha1 ERROR:root:code for hash sha224 was not found. Traceback (most recent call last): File "/opt/lib/python2.7/hashlib.py", line 147, in <module> File "/opt/lib/python2.7/hashlib.py", line 97, in __get_builtin_constructor ValueError: unsupported hash type sha224 ERROR:root:code for hash sha256 was not found. Traceback (most recent call last): File "/opt/lib/python2.7/hashlib.py", line 147, in <module> File "/opt/lib/python2.7/hashlib.py", line 97, in __get_builtin_constructor ValueError: unsupported hash type sha256 ERROR:root:code for hash sha384 was not found. Traceback (most recent call last): File "/opt/lib/python2.7/hashlib.py", line 147, in <module> File "/opt/lib/python2.7/hashlib.py", line 97, in __get_builtin_constructor ValueError: unsupported hash type sha384 ERROR:root:code for hash sha512 was not found. Traceback (most recent call last): File "/opt/lib/python2.7/hashlib.py", line 147, in <module> File "/opt/lib/python2.7/hashlib.py", line 97, in __get_builtin_constructor ValueError: unsupported hash type sha512 Traceback (most recent call last): File "/jffs/scripts/spdcli.py", line 126, in <module> from md5 import md5 File "/opt/lib/python2.7/md5.py", line 10, in <module> ImportError: cannot import name md5 spdMerlin: Finished speedtest spdMerlin: Speedtest results - - -
As per post in ntpMerlin - but this one is a little trickier - i dont really want to fire a speedtest off on boot. I'll have a thinkThe graphs seem to reappear after spdmerlin runs a speed test.
I'm still concerned about the RAM usage and the delays some users have seen when the test is running - I'd prefer to wait until I've made the schedule optional/configurable for the time it runs before submitting for amtm considerationBeen running for almost 24 hours no issues, nice to see bandwidth during those times. Any chance of putting it into AMTM @Jack Yaz ? I assume once it is tested thoroughly??![]()
Likely a memory issue on the router - I'm scouting out for any alternative speedtest toolsView attachment 16887
After running this for almost a day I am getting a max speed test of about 160 Mbps down on my 200 Mbps line. If I do any other speed tests I get the expected speed near 200 Mbps. Now those tests are from a browser and not the router itself. Would that make any difference in the speed? I know speed tests can vary based on the server location so the farther away, the slower the speed normally. Could the geographical distance be affecting my tests or is the scripts choosing a location nearest me?
Not complaining, just trying to figure out the difference.
Another issue is that file based tests will be likely bound by your USB's IO - since we can't write large files directly to the routerView attachment 16887
While the graphs are showing up after reboot, when I press the refresh button after reboot it breaks the graph. Sorry for not being more exact about this.
Thread starter | Title | Forum | Replies | Date |
vnStat Exclude spdMerlin from vnStat reports | Asuswrt-Merlin AddOns | 3 | |
Router Speed Test (spdMerlin) | Asuswrt-Merlin AddOns | 5 |
Welcome To SNBForums
