QuikSilver
Well there goes my "Sherlock" skills....didn't even have them for a second it seemed.Small correction: the spdMerlin script I've tried was on an RT-AC68U, not my RT-AC86U (yet).![]()
Will this script limited by external drive I/O speed? I installed similar script previously on my router and I could get ~500mbps download speed at best due to my 5400rpm hard drive I/O constraint.
Sent from my iPhone using Tapatalk Pro
Nope. The unistall PLUS opkg update PLUS install curl did not update the tabs. I have a feeling that the graphs may not update either. Have not seen a single dot on the graphs. I guess, I will wait and see if they update.
Could it possibly be an issue with the model coding since your on a 88 while L&LD and I are on a 86u? (Thinking out loud here, not a programmer by any means but trying to use my "Sherlock" skills.![]()
Yes, it is very possible. I saw that AC86U was the only model supported for the time being but I thought of experimenting with AX88U (due to architecture similarities)....
Supported Models
Models
All modes supported by Asuswrt-Merlin. Models confirmed to work are below:
- RT-AC86U
THIS SHOULD BE TREATED AS A BETA
This script uses a fairly large chunk of RAM/memory when the speedtest is running, and as such a swap file is required
I have only tested this on AC86U, your mileage may vary with older models with less RAM/memory
The speedtest is scheduled to run at 10 past and 40 past the hour, every hour
If you could run it on demand and collect stats to generate the graphs, that would be cool.![]()
Curious to know how the results of the tool compare to the results of speed test web sites.
Same issue here.Script noob here. Not sure what I am doing wrong. I copied and pasted the install line the same way I did with the Diversion/pixelserv-tls and it did not seem to install correctly.
I see the mention to run 'opkg update' in the error messages. I am leery to do this as I remember reading a post not to long ago where someone ran that and it screwed up their Diversion/pixelserv-tls install. Perhaps this is a different scenario?
Fast forward...I went into Diversion>pixelsrv-tls>manage Entware and update installed packages (how often should I be doing this?). That seemed to do the trick as spdMerlin seemed to install correctly and then this.....
spdMerlin: Starting speedtest now...
ERROR:root:code for hash md5 was not found.
Traceback (most recent call last):
File "/opt/lib/python2.7/hashlib.py", line 147, in <module>
File "/opt/lib/python2.7/hashlib.py", line 97, in __get_builtin_constructor
ValueError: unsupported hash type md5
ERROR:root:code for hash sha1 was not found.
ValueError: unsupported hash type sha1
ERROR:root:code for hash sha224 was not found.
ValueError: unsupported hash type sha224
ERROR:root:code for hash sha256 was not found.
ValueError: unsupported hash type sha256
ERROR:root:code for hash sha384 was not found.
ValueError: unsupported hash type sha384
ERROR:root:code for hash sha512 was not found.
ValueError: unsupported hash type sha512
File "/jffs/scripts/spdcli.py", line 126, in <module>
from md5 import md5
File "/opt/lib/python2.7/md5.py", line 10, in <module>
ImportError: cannot import name md5
spdMerlin: Finished speedtest
Send me a copy of custom_menuTree.js from /jffs/scriptsAre your tabs looking ok?
I can make the schedule optional but please note that the graphs only expect data every 30 minutes, so running the test manually may not produce anything usefulIf you could run it on demand and collect stats to generate the graphs, that would be cool.![]()
Thread starter | Title | Forum | Replies | Date |
vnStat Exclude spdMerlin from vnStat reports | Asuswrt-Merlin AddOns | 3 | |
Router Speed Test (spdMerlin) | Asuswrt-Merlin AddOns | 5 |
Welcome To SNBForums
