spdMerlin spdMerlin - v4.x - speedtest and bandwidth monitoring
those are just the HTML defaults. if your config file is missing (therefore webui can't load it), it won't load from config
I can try uninstalling and reinstalling if you think it would help.
I'm out of other ideas. your config file doesn't exist so should be created.....but isn't
if you scroll up above the header in the script are there any errors offscreen?
In the webpage or CLI menu?
Noticed this on reinstall....no issues until I went into AutoBW but didn't make any changes. Looks fine at first but when I come back to that screen I get the second screen....top section is bottom of first pic.
So, exiting spdmerlin and then using AMTM (j2), cli menu looks normal. Only when I go into settings does it give me that. Not sure if that helps or not.
FYI, Making changes using webui and clicking save, applying...reverts back to defaults.
by settings do you mean AutoBW?
going into any of the cli menu settings... (a)AutoBW or (c) customize list and back to main.
ok...when you first open spdmerlin, in a second terminal check if config exists in /jffs/addons/spdmerlin.d and if it does, what is the content?
repeat the test after going into a menu and provoking the errors
Like this?
Have you checked to make sure entware depends are all up to date and not corrupted?
Might be on to something there....didn't see any updates but when forced it looks as though it did.
Nope, same thing when I go into menu option a.
Run a speedtest to trigger Conf_Exists() ? Just nosing in here... ;)
Ran speedtest and no spdmerlin.d folder still within share folder.
