Stubby-Installer-Asuswrt-Merlin
@Xentrk, is there anything wrong here?
@RT-AC86U-99A8:/tmp/home/root# echo | openssl s_client -verify on -CApath /rom/etc/ssl/certs -connect 1.1.1.1:853
verify depth is 0
CONNECTED(00000003)
depth=1 C = US, O = DigiCert Inc, CN = DigiCert ECC Secure Server CA
verify error:num=20:unable to get local issuer certificate
4147033296:error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed:s3_clnt.c:1269:
no peer certificate available
No client certificate CA names sent
SSL handshake has read 2074 bytes and written 7 bytes
verify depth is 0
CONNECTED(00000003)
Early in the development, we were installing the entware package ca-certificates and telling Stubby to use the certificate in stubby.yml:
tls_ca_file: "/opt/etc/ssl/certs/ca-certificates.crt"
One of the testers had a similar error when running the command
echo | openssl s_client -connect '1.1.1.1:853'
It appeared as if the OS was not able to locate the certificate. The fix was to use the command
echo | openssl s_client -verify on -CApath /opt/etc/ssl/certs -connect  1.1.1.1:853
to fix.
However, right before we went live to the community, I found that Asuswrt Merlin stores the certificate in /rom/etc/ssl/certs. This allowed me to eliminate ca-certifcates entware package as a requirement and use the certificate installed by the firmware.
1. Please check the contents of /rom/etc/ssl/certs and make sure there is a ca-certificate.crt file in the location.
2. Check /opt/var/stubby/stubby.yml for the line--> tls_ca_file: "/rom/etc/ssl/certs/ca-certificates.crt"
3. Run the command echo | openssl s_client -connect '1.1.1.1:853'. Do you get the "Verify return code: 20 (unable to get local issuer certificate)" error message with this command?
to fix.
Thank you! I will try it tonight.
Marin
You are saying to try turn it on in Merlin's instead?
Yes. I am currently using Stubby with DNSSEC enabled in Merlin/dnsmasq. Either works and neither is preferred. I have also tested both ways on OpenWRT successfully.
Sent from my SM-T380 using Tapatalk
I have been getting these in under my IPS section of the AiProtection. I'm thinking they are Stubby-related and nothing serious but proof that AiProtection is doing its job. Am I correct or not?
Stubby does use the loop basck address in its function. As a matter of fact if the webui would take the loop back as a dns address that would be the developers preference. So seeing entries like you see with no corresponding syslog entry is likely caused by Stubby. When I first set Stubby up a long time ago I had the same entries.
to fix.
How do I check 1. and 2? Sorry still learning commands
Also on 3. yes, I do get the error message. See below:
 0140 - 38 b3 47 ed 8e 82 6b 06-88 5e b7 2e a1 b3 2e 15   8.G...k..^......
    0150 - 5d 2c 7d a1 37 99 4d 7f-95 50 db 7e a0 4f b0 7e   ],}.7.M..P.~.O.~
    0160 - fc 49 43 5b 31 d4                                 .IC[1.
    Start Time: 1545180252
    Timeout   : 300 (sec)
DONE
Is there a command to download this ca-certificate from Entware? Would this interfere with what is already installed with Stubby?
Why is it even necessary to change the WAN DNS in the GUI? Won’t the no-resolv and server= statements in the Dnsmasq.conf.add prevent Dnsmasq from using /tmp/resolv.conf? Or do you also need a Dnsmasq Postconf script to remove some other entries?
I can't find a way to figure out if this is enabled in Safari. Every link that I see states that SNI is already supported in Safari but I don't see the SSL 2.0 and SSL 3.0 in my "proxies" tab of the network preferences.
    Timeout   : 300 (sec)
DONE
Perhaps the firmware cert is in a different directory location on the AC86U? @Jack Yaz can you confirm?
1. You can do a change directory command e.g. "cd /rom/etc/ssl/certs" to navigate to the directory. Then, issue the Linux command to list out the directory contents. Cloudflare won't let me put in the post. Here is one reference https://www.rapidtables.com/code/linux/ls.html
2. "cd /opt/var/stubby". Then "cat stubby.yml". If you have SFTP server installed, you can use client software like MobaXterm or WinSCP to get a Windows explorer view to the Linux OS. Everyone has their preference. Putty is another option.
The entware package is called ca-certificates. Install: opkg install ca-certificates
You then have to change stubby.yml to use the certificate from entware:
followed by a restart:
/opt/etc/init.d/S61stubby restart
Asuswrt-Merlin has a built in line editor called nano
https://www.howtogeek.com/howto/429...e-to-nano-the-linux-command-line-text-editor/
ok here we go...
062897@RT-AC86U-99A8:/tmp/home/root# opkg install ca-certificates
Package ca-certificates (20180409-3) installed in root is up to date.
do I add
to:
nano /opt/etc/stubby/stubby.yml
and replace this line in nano:
with:
with:
Yes
Oh and restart stubby.
