rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
proc on /proc type proc (rw)
tmpfs on /tmp type tmpfs (rw)
devfs on /dev type tmpfs (rw,noatime)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
/dev/mtdblock5 on /jffs type jffs2 (rw,noatime)
usbfs on /proc/bus/usb type usbfs (rw)
/dev/sda1 on /tmp/mnt/Mediadb type ext3 (rw,nodev,noatime,data=ordered)
devfs on /tmp/mnt/Mediadb/debian/dev type tmpfs (rw,noatime)
proc on /tmp/mnt/Mediadb/debian/proc type proc (rw)
sysfs on /tmp/mnt/Mediadb/debian/sys type sysfs (rw)
/dev/sdb1 on /tmp/mnt/MyBook type ufsd (rw,nodev,noatime,nls=utf8,fmask=0,dmask=0,sparse,force)
/opt/etc/init.d/S99debian stop
rm -r /mnt/Mediadb/debian/opt/minidlna
Start minidlna with#!/bin/sh
PATH=/opt/bin:/opt/sbin:/sbin:/bin:/usr/sbin:/usr/bin
# Folder with Debian Squeeze
CHROOT_DIR=/tmp/mnt/Mediadb/debian
# Some folder outside of sandbox, will be mounted to /mnt folder in Debian
# Leave commented if not needed
EXT_DIR=/tmp/mnt/MyBook/Music
CHROOT_SERVICES_LIST=/opt/etc/chroot-services.list
/opt/etc/init.d/S99debian start
Hi!
I never tried Tomato fw - are you happy whith it? Is it stable? I use Merlin's fw and like it for it's stability (and for the scripting capabilites with jffs), but I'd like try out Open VPN (which isn't available on RT-N16); which Tomato's version do you recommend?
It looks interesting..!
So, if I got you right, you're saying that you managed to «accomodate» those 2 apps running on an optware environment while at the same time you have a chrooted debian available on a entware environment (on /tmp/mnt/Seagate/Programs/debian) -- right or wrong?
Thanks for your feedback!
Joao
You can set a time in routers UI so hdd's won't spin 24/7 but instead the go to sleep when not usedA few years ago I used a USB drive with my router but those are not made for 24/7 use (2 or 3 died in the time of maybe 6 months) and if I have a NAS that would probably run a DLNA server aswell. So the only thing I could think of is using hard disks which are made for servers or at least are certified for permanent use for my router then I wouldn't need to use my notebook anymore.
1.1.3 - Released 05-June-2014
- Enhance log level settings.
- Fix Samsung browsing when root_container is set.
- Add Clang compiling support.
- Fix compiling on systems without iconv.
- Add merge_media_dirs option, to revert to the old behavior.
- Add Asus O!Play client support.
- Fix Broken SSDP multicast membership addition.
- Fix crash bug with an emtpy filter argument.
- Accept SMI subtitles in addition to SRT.
- Add BubbleUPnP detection and enable subtitle support.
- Allow the user to specify an arbitrary root container.
- Add libavcodec > 54 / libav 10 compatibility.
- Get embedded cover art from video files with recent libavformat versions.
- Disable Samsung DCM10 capability, as it breaks compatibility with new models.
- Add subtitle support for NetFront™ Living Connect middleware-based clients.
New version of minidlna is out on http://sourceforge.net/projects/minidlna/
TeHashX , could you update topic with tutorial for upgrade old version ( if mipsel version is out too ) ?
Thank you.
TeHashX,
Thank you, i successfully install this version on my N66W.
Don't have to write thank you, pressing thanks button is more than enough.
Witch dlna player do you use? Witch tv?
Samsung TV F6400
Do you have bookmarks with this version, I mean video files will start from the point you leave then last time?
I ask you because I lost bookmarks on my E series tv and I don't want to break other series trying to fix this.
Welcome To SNBForums
