uiDivStats uiDivStats - WebUI for Diversion statistics
Out of interest, what happens with diversion's stats generation?
Are you talking about the output of
stats.div.log:
 START FILE, --- lines are not part of file
 Wed, 15 May 2019 22:52:49 -0700
 diversion.conf found, compiling stats
 start router stats, updating Ad-Blocking stats
 creating filtering lists
 begin of stats computing
 END FILE
That's what I get when doing a "c,2,2" in the Diversion menu
and then it will give me a bunch of these as well
grep: /tmp/divstats/div-hostleases: No such file or directory
Note that the current Diversion stats.div file does not contain the updated code you have in uiDivStats.
Ah. I probably did break something :oops:
Change both occurances of:
if [ "$foundClients" -eq 1 ]; then
back to what I originally set as test:
if [ "$foundClients" ]; then
Yours throws a "[: bad number" error when no clients are found.
That's what I thought i'd broken, as i was trying to simulate no clients, and promptly forgot to revert it. oops
Just make the test fail by looking for a non-existent file, tmps instead of tmp:
if [ -s /tmp/uidivstats/div-allips.tmps ]; then
I went ahead and updated this morning but I am still getting the error and no graphs
Not sure if this is relevant to your script to pull data. I don't run DHCP or DNS on my router, as I have it running on another machine.
##          _  _____   _          _____  _          _          ##
##         (_)|  __ \ (_)        / ____|| |        | |         ##
##   _   _  _ | |  | | _ __   __| (___  | |_  __ _ | |_  ___   ##
##  | | | || || |  | || |\ \ / / \___ \ | __|/ _  || __|/ __|  ##
##  | |_| || || |__| || | \ V /  ____) || |_| (_| || |_ \__ \  ##
##   \__,_||_||_____/ |_|  \_/  |_____/  \__|\__,_| \__||___/  ##
##                      v1.0.1 on RT-AC5300                    ##
##             https://github.com/jackyaz/uiDivStats           ##
1.    Generate Diversion Statistics now
u.    Check for updates
uf.   Update uiDivStats with latest version (force update)
e.    Exit uiDivStats
z.    Uninstall uiDivStats
Choose an option:    1
uiDivStats: Starting Diversion statistic generation...
/opt/bin/grep: /tmp/uidivstats/div-hostleases: No such file or directory
awkNR: /tmp/uidivstats/div-bwl: No such file or directory
/opt/bin/grep: /tmp/uidivstats/div-iphostleases: No such file or directory
awkNR: /tmp/uidivstats/div-noisy: No such file or directory
awkNR: /tmp/uidivstats/div-toptop: No such file or directory
sed: /tmp/uidivstats/div-iphostleases: No such file or directory
cat: can't open '/tmp/uidivstats/div-iphostleases': No such file or directory
uiDivStats: Diversion statistic generation completed successfully!
Unless I'm misunderstanding, how are you using Diversion if you're not using the router for dns?
Since I have a domain and several subdomains and VLANs, I have a MS DNS & DHCP running. my MS DNS resolve all name lookup for my domain and subdomains, anything else is forwarded to Diversion( that I am assuming running Dnsmasq) then through Stubby and out to Cloudflare.
I am assuming your script is basically pulling from Diversion's compiled status?
Since I run the 'Compile Current Status report' i get the same/similar errors. I have posted on Diversion's thread.
The ASUS router's Network Map -> View List does show all my network devices and their MAC/IP and names. Not knowing much how Diversion pulls the information it needs it can definitely be pulled from that same method
v1.1.0 is now available
Changelog:
Add zoom/pan support to charts
OK, so I couldn't help myself
Run u twice to make sure the required js files (plugins) are downloaded
Works great! Just keeps getting better. :)
Looks good thank you [emoji106]
