Jack Yaz
Part of the Furniture
any errors in browser console (f12)?Does anyone have any ideas about this? Thanks.
Click the link to that line, and PM me the contents please (sounds like something is breaking jscript parsing)Yes, there is actually: Uncaught SyntaxError: Unexpected token ) uidivstats.js:34
No idea what it means though I'm afraid, bit above my paygrade.
Yes pleaseCan you explain what you mean like I'm a 10 year old? The only thing I can click on is the uidivstats.js:34 bit, it brings up about 50 lines of code - is that what you want?
Sorry, I'm no coder....lol
Interesting, it doesnt look like any ads have been blocked. Does the stats text load?Done.
that's probably why - can you PM me those please?Yes, I turned ublock off just in case that was causing it - no difference. The starts are loading fine, both pixelserve & diversion, although there are some empty fields in the diversion stats.
Ah - personally i'd prefer diversion over MACE, but to each their own! i'll add a check/fix that if sections are missing/empty in the stats, uiDivStats handles them appropriatelyI also trid reinstalling diversion, but it made no difference either, so yeah, very strange indeed....
Edit: Although, I am using PIA with MACE enabled (their own adblocker) so I don't get too many ads anyway - I use diversion for other lists mainly, not so much for ads.
if your primary browsing devices use mace, there would be relatively few (apparently 0 in your environment) ads for diversion to blockMind you, MACE is not enabled on the router itself of course.....
It isn't easy to downgrade, and the same issue will exist. Probably coincidence you updated and there's no ads blockedThinking about it, only my android devices are using MACE, so I don't think it's relevent tbh. All my linux/windows units go through the router, no dns filter.
Can I reload the previous version & see if it reverts back to normal?
Your ad blocking statsWell, it was definately working fine before the upgrade. Maybe something has gotten corrupted?
Welcome To SNBForums
