5stringdeath
This seems to have fixed itself overnight. Not sure if it was because I had cleaned down my stats.
Interesting, mine too
Spoke too soon. Got home from work today and noticed all my Diversion Stats charts were missing again in the webui.Interesting, mine too![]()
Try opening the SSH menu and using option UFSpoke too soon. Got home from work today and noticed all my Diversion Stats charts were missing again in the webui.
awkNR: /tmp/uidivstats/div-toptop: No such file or directory
Def broken.
Edit: Tried a full reboot, still blank and same error message
Already tried that. Also did a complete uninstall and reinstall.Try opening the SSH menu and using option UF
This morning the charts are back. I will see what happens later today.
Edit:
Everything seems to have settled down and is working correctly now.
Love the gui but I now get this error when generating stats after latest update.
I've created a pull request that corrects the above lament and suggestion.Maybe I’ve put my nose where it didn’t really belong, but if my idea broke it, I’ll double-down on potentially bad ideas and be more specific to only capture A or AAAA queries (I saw TXT and PTR queries slipping through in my logs).
Code:/opt/bin/grep -a " query\[A.* from $i$" $dnsmasqLog
thank you kind sir!I've created a pull request that corrects the above lament and suggestion.
Is this after updating uiDivStats following the update earlier this week?Back to this on Xmas morn .....
When generating stats
I haven’t see the same problem since I updated.Is this after updating uiDivStats following the update earlier this week?
Yes. It's been fine until today.Is this after updating uiDivStats following the update earlier this week?
What happens when you update the stats using Diversion itself?So it seems for me on my router (RT-AC3100) that it has something to do with the size of the Diversion list. If I choose the largest one, I get that error and no stats charts. Reverting back down to Standard works fine. Maybe a memory issue on this particular router, although HTOP showed nothing out of the ordinary and the logs show nothing else beyond the error posted above. I have a 1G USB drive for my swap and plenty of space.
Works fine, emails me the report no problem.What happens when you update the stats using Diversion itself?
Options: c,2,2 in Diversion
I'll compare and see why the issue is only affecting uiDivStats. I wonder if I temporarily revert the change that seemed to introduce this as a separate version, would you be able to test?Works fine, emails me the report no problem.
It will have to wait until after the new year as I'm traveling, but I'll be happy to later in the week.I'll compare and see why the issue is only affecting uiDivStats. I wonder if I temporarily revert the change that seemed to introduce this as a separate version, would you be able to test?
Welcome To SNBForums
