No.@Jack Yaz, do you have any plans to move uiDivStats from the Tools tab to the Firewall tab next to Skynet once v. 384.15 is out?
Great script.
Just to be sure: if I install this script, do I need to run it always or it will show me real time stats in UI, once it is installed?
@Skeptical.me, did you use 'u', then 'uf', then reboot the router?
Under ToolsYeah, I did. Where are the stats located in the UI. I haven't used this for a while and I thought they were in the Traffic Analyses section.
Under Tools
The top 15 requested domains were:
306316 dns.msftncsi.com
134261 d29r7idq0wxsiz.cloudfront.net
108585 ssl.gstatic.com
106066 play.google.com
82678 d3p8zr0ffa9t17.cloudfront.net
79700 google.com
67880 www.google.com
65133 mail.google.com
58931 clients4.google.com
54659 chat-pa.clients6.google.com
51702 www.netflix.com
51354 safebrowsing.googleapis.com
48106 device-metrics-us.amazon.com
39591 www.googleapis.com
38045 play.googleapis.com
The top 15 blocked ad domains were:
AFAIK connections to dns.msftncsi.com are initiated by the router itself. The domain dns.msftncsi.com is used as part of its Network Connectivity Status Indicator tests.Also. If dns.msftncsi.com is the #1 requested domain, then why does it not show up anywhere in any of the individual client lists?
Thanks in advance for your thoughts!!
No, I'm sure I'd have been told if my home connection dropped every hour! Does dnsmasq restart?I'm currently running 384.14_2 on an AC3100 router which should be powerful enough to run the uiDivStats; however, whenever this runs I loose my DNS and internet subsequently seems to die. The CPU doesn't seem to spike too high, but right as my resolver died, I checked the logs and saw:
Jan 29 18:00:00 uiDivStats: Starting Diversion statistic generation...
Jan 29 18:02:11 uiDivStats: Diversion statistic generation completed successfully!
Jan 29 19:00:00 uiDivStats: Starting Diversion statistic generation...
Jan 29 19:02:10 uiDivStats: Diversion statistic generation completed successfully!
Shortly after, it came back, although it took a little to stabilize. This knocks me off my work VPN as well which is a little annoying as well. I have removed it for now, but has anyone else noticed this behavior?
@kfahoo what faults did you encounter? You need to provide more information about your setup, including the router model, firmware version and all scripts you have running.
/opt/bin/grep: /tmp/uidivstats/div-hostleases: No such file or directory
awk: cmd. line:1: Division by zero
awkNR: /tmp/uidivstats/div-bwl: No such file or directory
awkNR: /tmp/uidivstats/div-noisy: No such file or directory
awkNR: /tmp/uidivstats/div-toptop: No such file or directory
1 open Diversion v4.1.8
2 open Skynet v7.0.9
5 open scribe v2.4.1
j1 open connmon v2.2.0
j2 open ntpMerlin v2.2.2
j4 open spdMerlin v3.2.0
j5 open uiDivStats v1.3.0
j6 open uiScribe v1.2.0
I know but I just tried everything ;]
tried all of it@kfahoo
Try doing a backup of Diversion and then uninstalling and reinstalling it (it should then ask you to restore the backup you just made).
Is Entware fully up-to-date?
There were many changes yesterday from Entware being updated on its own.![]()
Is your router providing dhcp or another device? What do you have set in tools other settings, using caching resolver for router?rt-ac86u 384.14_2Code:/opt/bin/grep: /tmp/uidivstats/div-hostleases: No such file or directory awk: cmd. line:1: Division by zero awkNR: /tmp/uidivstats/div-bwl: No such file or directory /opt/bin/grep: /tmp/uidivstats/div-hostleases: No such file or directory /opt/bin/grep: /tmp/uidivstats/div-hostleases: No such file or directory /opt/bin/grep: /tmp/uidivstats/div-hostleases: No such file or directory /opt/bin/grep: /tmp/uidivstats/div-hostleases: No such file or directory awkNR: /tmp/uidivstats/div-noisy: No such file or directory /opt/bin/grep: /tmp/uidivstats/div-hostleases: No such file or directory awkNR: /tmp/uidivstats/div-toptop: No such file or directory awkNR: /tmp/uidivstats/div-toptop: No such file or directory /opt/bin/grep: /tmp/uidivstats/div-hostleases: No such file or directory awkNR: /tmp/uidivstats/div-toptop: No such file or directory awkNR: /tmp/uidivstats/div-toptop: No such file or directory /opt/bin/grep: /tmp/uidivstats/div-hostleases: No such file or directory awkNR: /tmp/uidivstats/div-toptop: No such file or directory awkNR: /tmp/uidivstats/div-toptop: No such file or directory /opt/bin/grep: /tmp/uidivstats/div-hostleases: No such file or directory awkNR: /tmp/uidivstats/div-toptop: No such file or directory awkNR: /tmp/uidivstats/div-toptop: No such file or directory awkNR: /tmp/uidivstats/div-bwl: No such file or directory
but I tried leaving only diversion and uidivstats as wellCode:1 open Diversion v4.1.8 2 open Skynet v7.0.9 5 open scribe v2.4.1 j1 open connmon v2.2.0 j2 open ntpMerlin v2.2.2 j4 open spdMerlin v3.2.0 j5 open uiDivStats v1.3.0 j6 open uiScribe v1.2.0
tried all of it
all is up to date
it's not since yesterday
this routerIs your router providing dhcp or another device?
Wan: Use local caching DNS server as system resolver => yesWhat do you have set in tools other settings, using caching resolver for router?
Welcome To SNBForums
