uiDivStats uiDivStats - WebUI for Diversion statistics
ok it worked well for then day,
while uninstall this popped up
sed: /jffs/scripts/custom_menuTree.js: No such file or directory
and again install:
 Continue? [1=Yes e=Exit] 1
uiDivStats: Welcome to uiDivStats v1.3.0, a script by JackYaz
uiDivStats: Checking your router meets the requirements for uiDivStats
Downloading http://bin.entware.net/aarch64-k3.10/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
Package grep (3.3-1) installed in root is up to date.
uiDivStats: Starting Diversion statistic generation...
/opt/bin/grep: /tmp/uidivstats/div-hostleases: No such file or directory
awk: cmd. line:1: Division by zero
awkNR: /tmp/uidivstats/div-bwl: No such file or directory
awk: /tmp/uidivstats/div2: No such file or directory
awkNR: /tmp/uidivstats/div2: No such file or directory
awkNR: /tmp/uidivstats/div-noisy: No such file or directory
awkNR: /tmp/uidivstats/div5: No such file or directory
uiDivStats: Diversion statistic generation completed successfully!
ok I think I found couse of my problems; openvpn connection, when client is connected diversion and uidivstats don't generate proper stats
v1.3.1 is now available
Please run option u a second time after updating, and then reboot if you are seeing multiple/missing tabs
Changelog:
WebUI improvements
Fixes tab duplication when updating in future
I ran the update, then a 2nd time since I now had 2 tabs. Rebooted and now I have no tab at all.
Just me leaving something secret to see if people will enjoy it :D
Nicely done, thank you [emoji4]
Another gem added, thanks @Jack Yaz. Can you make the Support tab open in a new tab?
Good old HTML: <a target="_blank" rel="noopener noreferrer" href="/">Link</a>
That approach would likely require an update to all scripts since they current point to www/user/redirect.htm (the idea being I could amend the redirect without wholesale updates)
Currently considering something like:
setTimeout(function(){
    window.open("https://www.snbforums.com/forums/asuswrt-merlin.42/","_blank");
    window.history.back();
}, 5000);
Will UiDivStats also be moved into the Addon tab?
I have it installed right now but not visible in the Tools tab anymore?
*Update*
Running U a second time fixed this I see it now in the add on tabs.
@SomeWhereOverTheRainBow you will need to reboot the router and then find those tabs in the Addons Tab in the bottom lefthand corner of the GUI. :)
After last update is not working on my ax88u. i do see the new addon tab but it only contains links to the forums. i have reinstalled, rebooted.... you name it and nada......
@Jacob did you do an 'u' on each @Jack Yaz script twice?
Afterward, did you do an 'uf' at least once on a 'Jx' script? Then rebooted the router? :)
