uiDivStats uiDivStats - WebUI for Diversion statistics
Hi Jack,
Updated to V2 and rebooted to make the tab show in LAN but to no avail. I went back into amtm and selected the j5 option. i got some Entware install and config activity but something is hanging and i'm not being returned to the menu
Enter option  j5
Downloading http://bin.entware.net/armv7sf-k2.6/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
Package grep (3.4-1) installed in root is up to date.
Package sqlite3-cli (3310100-1) installed in root is up to date.
Installing procps-ng-pkill (3.3.15-4) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/procps-ng-pkill_3.3.15-4_armv7-2.6.ipk
Installing procps-ng (3.3.15-4) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/procps-ng_3.3.15-4_armv7-2.6.ipk
Configuring procps-ng.
Configuring procps-ng-pkill.
uiDivStats: New version of taildns.tar.gz downloaded
were you running v1 previously or did you hop on the beta train?
what do you see for
ls -la /jffs/addons/uiDivStats.d
The update via amtm seemed to go well, but the web GUI shows no stats.
When updating in the uiDivStats> 1, the stats are regenerated with:
awk: cmd. line:1: Division by zero
uiDivStats: Stats updated successfully
Any suggestions?
do you still see this now? i'd expect this to happen if there are no queries logged whatsoever (which i will patch, but you shouldn't see it after things have been running for a few seconds, assuming you have active network clients)
what do you see for
Hello
Some problem of tomsk ..
With your command I see:
ASUSWRT-Merlin RT-AC86U 384.18_alpha1-g5f6b535e1a Fri May 29 04:00:52 UTC 2020
admin@RT-AC86U-81D8:/tmp/home/root# ls -la /jffs/addons/uiDivStats.d
drwxrwxrwx 3 admin root 0 Jun 6 11:00 .
drwxr-xr-x 11 admin root 0 Jun 2 10:13 ..
-rw-rw-rw- 1 admin root 0 Jun 6 10:39 .upgraded
-rw-rw-rw- 1 admin root 0 Jun 6 10:39 .upgraded2
-rw-rw-rw- 1 admin root 728 Jun 6 11:00 SQLData.js
-rw-rw-rw- 1 admin root 24 Jun 6 10:00 psstats.htm
drwxrwxrwx 2 admin root 0 Jun 6 10:39 taildns.d
-rw-rw-rw- 1 admin root 33 Jun 6 10:39 taildns.tar.gz.md5
-rw-rw-rw- 1 admin root 8334 Jun 6 10:00 uidivstats.js
-rw-rw-rw- 1 admin root 11598 Jun 6 10:00 uidivstats.txt
-rw-rw-rw- 1 admin root 28934 Jun 6 10:30 uidivstats_www.asp
-rw-rw-rw- 1 admin root 535 Jun 6 10:00 uidivstatsclients.js
-rw-rw-rw- 1 admin root 814 Jun 6 10:00 uidivstatstext.js
what do you see for
I was previously running V1.... not brave enough to dabble in the beta for that one
tOmsK@RT-AC68U-4690:/tmp/home/root# ls -la /jffs/addons/uiDivStats.d
drwxrwxrwx    3 tOmsK root             0 Jun  6 13:30 .
drwxrwxrwx   10 tOmsK root             0 Jun  6 13:27 ..
-rw-rw-rw-    1 tOmsK root            28 Jun  6 13:30 SQLData.js
-rw-rw-rw-    1 tOmsK root          5060 May 18 17:00 psstats.htm
drwxrwxrwx    2 tOmsK root             0 Jun  6 13:30 taildns.d
-rw-rw-rw-    1 tOmsK root            33 Jun  6 13:30 taildns.tar.gz.md5
-rw-rw-rw-    1 tOmsK root         14169 Jun 23  2019 uiDivStats_cache.tar.gz
-rw-rw-rw-    1 tOmsK root          6249 May 18 17:00 uidivstats.js
-rw-rw-rw-    1 tOmsK root          8715 May 18 17:00 uidivstats.txt
-rw-rw-rw-    1 tOmsK root         28934 Jun  6 13:20 uidivstats_www.asp
-rw-rw-rw-    1 tOmsK root           591 May 18 17:00 uidivstatsclients.js
-rw-rw-rw-    1 tOmsK root           814 May 18 17:00 uidivstatstext.js
if i try the j5 option now i just get
 Enter option  j5
Package procps-ng-pkill (3.3.15-4) installed in root is up to date.
Hello
OK so yours has completed the upgrade, so should load after finishing the stat generation (which with an empty db should take no time at all). If you Ctrl-C and re-launch, what happens?
 Enter option  j5
It seems like your database hasn't been through the upgrade/creation yet. Can you run the below?
sqlite3 /opt/share/uiDivStats.d/dnsqueries.db
.tables
.index
.exit
With ctrl-C I cannot stop the process. I had to get out of the shell.
After the start generation (point 2 of the menu) seem all ok.
.tables
.index
.exit
Ok Done
Ok Done
What did the . commands show please?
tOmsK@RT-AC68U-4690:/tmp/home/root# sqlite3 /opt/share/uiDivStats.d/dnsqueries.db
SQLite version 3.31.1 2020-01-27 19:55:54
Enter ".help" for usage hints.
sqlite> .tables
dnsqueries         dnsqueriesdaily    dnsqueriesmonthly  dnsqueriesweekly
sqlite> .index
idx_dns_clients  idx_dns_domains  idx_dns_time
sqlite> .exit
sqlite> .tables
sqlite> .index
sqlite> .exit
Weird...it looks like a stat update started since the views exist as does the indexes.
Try running
touch /jffs/addons/uiDivStats.d/.upgraded
touch /jffs/addons/uiDivStats.d/.upgraded2
Then option 2 again. If no dice, try a reboot and then option 2 please
Try running
After creating the files i was able to enter the menu again instead of going straight to the entware process.
On entering option 2 i got
Choose an option:    2
uiDivStats: Stale lock file found (>600 seconds old) - purging lock
Still no Tab so i rebooted...... selected option 2 now and some churning going on somewhere i guess... will give it a few minutes and see if it recovers
Choose an option:    2
I assume you do have dnsmasq enabled? I recall seeing you active in the unbound thread a lot
Yes i made sure dnsmasq is primary DNS before i started the upgrade .. i can't see any unbound manager code that would potentially interfere.. but its hard to tell when you're not entirely sure what you are looking for :oops:
Can you check taildns is running?
/opt/etc/init.d/S90taildns check
ps | grep taildns
ps | grep taildns
tOmsK@RT-AC68U-4690:/tmp/home/root# /opt/etc/init.d/S90taildns check
 Checking taildns...              alive.
tOmsK@RT-AC68U-4690:/tmp/home/root# ps | grep taildns
 3349 tOmsK  1420 S    {taildns} /bin/sh /opt/bin/taildns
 3357 tOmsK  1420 S    {taildnstotal} /bin/sh /jffs/addons/uiDivStats.d/taildns.d/taildnstotal
 3370 tOmsK  1456 S    {dnsmasqtotal.aw} /usr/bin/awk -f /jffs/addons/uiDivStats.d/taildns.d/dnsmasqtotal.awk
 3371 tOmsK  1424 S    {taildnstotal} /bin/sh /jffs/addons/uiDivStats.d/taildns.d/taildnstotal
20234 tOmsK  4656 D    grep taildns
The uiDivStats tab has appeared! (as has the Diversion tab which went missing during the t/shoot)
Everything seems to be hackling now.
What do you think went wrong during the update?
No idea - maybe rebooting too soon after updating?
It shall remain a mystery then... anyway thanks for your help ... and great work....now to update the YazFi;)
I have the same problem that tomsk had. I've seen the same things and just rebooted the node. Currently; it stucks here.
admin@FaTiii:/tmp/home/root# uiDivStats
There is uiDivStats tab but it has no info.
Additionally I've removed procps-ng-pkill manually and tried again. it seems it's stucked when configuring procps-ng-pkill.
