uiDivStats uiDivStats - WebUI for Diversion statistics
I’m loving all this. Works like a charm. Thank you.
If I may pass one comment? In the GUI I find the there needs to be more room to display the blocked domain text. It is overwriting other text.
I have the same problem that tomsk had. I've seen the same things and just rebooted the node. Currently; it stucks here.
admin@FaTiii:/tmp/home/root# uiDivStats
Downloading http://bin.entware.net/armv7sf-k2.6/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
Package grep (3.4-1) installed in root is up to date.
Package sqlite3-cli (3310100-1) installed in root is up to date.
Package procps-ng-pkill (3.3.15-4) installed in root is up to date.
There is uiDivStats tab but it has no info.
Additionally I've removed procps-ng-pkill manually and tried again. it seems it's stucked when configuring procps-ng-pkill.
Installing procps-ng-pkill (3.3.15-4) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/procps-ng-pkill_3.3.15-4_armv7-2.6.ipk
Configuring procps-ng-pkill.
You say node...is this a router or AP?
After installing procps-ng-pkill the next stage is to download the taildns tar:
Update_File "taildns.tar.gz"
I've just pushed a hotfix that adds extra verbosity to the upgrade process, so we can see where things are getting stuck. Running the below at the command line should work and get the updated version without getting stuck:
uiDivStats update
I'm not sure chartJS has an option to set a width for labels but I will take a look. I may remove the "Domain" label since its fairly obvious what the axis shows!
uiDivStats update
after this all seems fine, waiting for database to be created. I meant router with node :) thanks :)
admin@FaTiii:/tmp/home/root# uiDivStats update
uiDivStats: Stale lock file found (>600 seconds old) - purging lock
uiDivStats: MD5 hash of uiDivStats does not match - downloading updated v2.0.0
uiDivStats: uiDivStats successfully updated
uiDivStats: Creating database table and enabling write-ahead logging...
uiDivStats: Creating database table indexes...
do you still see this now? i'd expect this to happen if there are no queries logged whatsoever (which i will patch, but you shouldn't see it after things have been running for a few seconds, assuming you have active network clients)
Still no stats :confused:
have 20+ active clients and before update there were a lot of stats.
Any ideas?
The index creation should be near-instant on a new db. It may be easier to
uiDivStats uninstall
rm /opt/share/uiDivStats.d/dnsqueries.db
and start a fresh install
Firstly check taildns is running
/opt/etc/init.d/S90taildns check
ps | grep taildns
Check files exist correctly:
ls -laR /jffs/addons/uiDivStats.d
ls -laR /opt/share/uiDivStats.d
 Checking taildns...              alive.
dana@RT-AC2900-72D8:/tmp/home/root# ps | grep taildns
 2322 dana      3368 S    {taildns} /bin/sh /opt/bin/taildns
 2325 dana      3368 S    {taildnstotal} /bin/sh /jffs/addons/uiDivStats.d/taildns.d/taildnstotal
 2333 dana      3368 S    {dnsmasqtotal.aw} /usr/bin/awk -f /jffs/addons/uiDivStats.d/taildns.d/dnsmasqtotal.awk
 2334 dana      3368 S    {taildnstotal} /bin/sh /jffs/addons/uiDivStats.d/taildns.d/taildnstotal
11768 dana      5432 S    grep taildns
drwxrwxrwx    2 dana     root             0 Jun  6 10:12 .
drwxrwxrwx    3 dana     root             0 Jun  6 15:29 ..
-rwxr-xr-x    1 dana     root           885 May 13 00:45 dnsmasqtotal.awk
-rwxr-xr-x    1 dana     root           886 May 19 14:51 dnsmasqtotalextra.awk
-rwxr-xr-x    1 dana     root           540 Apr 24 11:15 taildns
-rwxr-xr-x    1 dana     root          1131 May 19 10:49 taildnstotal
dana@RT-AC2900-72D8:/tmp/home/root# ls -laR /opt/share/uiDivStats.d
taildns looks good, but the ls output seems to be missing - can you double check it copied out of your terminal app correctly please?
My misstake :oops:
dana@RT-AC2900-72D8:/tmp/home/root# ls -laR /jffs/addons/uiDivStats.d
/jffs/addons/uiDivStats.d:
drwxr-xr-x    8 dana     root             0 Jun  6 15:02 ..
-rw-rw-rw-    1 dana     root             0 Jun  6 15:11 .upgraded
-rw-rw-rw-    1 dana     root             0 Jun  6 15:12 .upgraded2
-rw-rw-rw-    1 dana     root          3268 Jun  6 15:29 SQLData.js
-rw-rw-rw-    1 dana     root          5059 Jun  6 10:00 psstats.htm
drwxrwxrwx    2 dana     root             0 Jun  6 10:12 taildns.d
-rw-rw-rw-    1 dana     root            33 Jun  6 10:12 taildns.tar.gz.md5
-rw-rw-rw-    1 dana     root         12484 Jun  6 10:00 uidivstats.js
-rw-rw-rw-    1 dana     root         16182 Jun  6 10:00 uidivstats.txt
-rw-rw-rw-    1 dana     root         28934 Jun  6 10:05 uidivstats_www.asp
-rw-rw-rw-    1 dana     root           730 Jun  6 10:00 uidivstatsclients.js
-rw-rw-rw-    1 dana     root           813 Jun  6 10:00 uidivstatstext.js
/jffs/addons/uiDivStats.d/taildns.d:
/opt/share/uiDivStats.d:
drwxrwxrwx    3 dana     root          4096 Jun  6 15:46 .
drwxr-xr-x    8 dana     root          4096 Jun  6 10:12 ..
drwxrwxrwx    2 dana     root          4096 Jun  6 15:29 csv
-rw-r--r--    1 dana     root         20480 Jun  6 15:29 dnsqueries.db
/opt/share/uiDivStats.d/csv:
drwxrwxrwx    2 dana     root          4096 Jun  6 15:29 .
drwxrwxrwx    3 dana     root          4096 Jun  6 15:46 ..
-rw-rw-rw-    1 dana     root             0 Jun  6 15:29 Blockeddaily.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:29 Blockeddailyclients.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:29 Blockeddailytime.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:13 Blockedmonthly.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:13 Blockedmonthlyclients.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:13 Blockedmonthlytime.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:13 Blockedweekly.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:13 Blockedweeklyclients.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:13 Blockedweeklytime.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:46 SQLQueryLog.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:29 TotalBlockeddailytime.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:13 TotalBlockedmonthlytime.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:13 TotalBlockedweeklytime.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:29 Totaldaily.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:29 Totaldailyclients.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:29 Totaldailytime.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:13 Totalmonthly.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:13 Totalmonthlyclients.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:13 Totalmonthlytime.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:12 Totalweekly.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:13 Totalweeklyclients.htm
-rw-rw-rw-    1 dana     root             0 Jun  6 15:12 Totalweeklytime.htm
My misstake :oops:
Hm so the database isn't actually being updated by the looks of it. Can you run the below and check if you get any output when visiting websites etc.?
tail -F /opt/var/log/dnsmasq.log /opt/var/log/dnsmasq.log3
I also don't have any graphs after fresh install for about 30 minutes.
admin@FaTiii:/tmp/home/root# /opt/etc/init.d/S90taildns check
admin@FaTiii:/tmp/home/root# ps | grep taildns
13087 admin     1420 S    {taildns} /bin/sh /opt/bin/taildns
13090 admin     1420 S    {taildnstotal} /bin/sh /jffs/addons/uiDivStats.d/taildns.d/taildnstotal
13094 admin     1432 S    {dnsmasqtotalext} /usr/bin/awk -f /jffs/addons/uiDivStats.d/taildns.d/dnsmasqtotalextra.awk
13095 admin     1420 S    {taildnstotal} /bin/sh /jffs/addons/uiDivStats.d/taildns.d/taildnstotal
20149 admin     4656 S    grep taildns
admin@FaTiii:/tmp/home/root# ls -laR /jffs/addons/uiDivStats.d
drwxrwxrwx    3 admin    root             0 Jun  6 17:03 .
drwxr-xr-x    7 admin    root             0 Jun  6 16:34 ..
-rw-rw-rw-    1 admin    root             0 Jun  6 16:34 .upgraded
-rw-rw-rw-    1 admin    root             0 Jun  6 16:34 .upgraded2
-rw-rw-rw-    1 admin    root           704 Jun  6 17:03 SQLData.js
drwxrwxrwx    2 admin    root             0 Jun  6 16:34 taildns.d
-rw-rw-rw-    1 admin    root            33 Jun  6 16:34 taildns.tar.gz.md5
-rw-rw-rw-    1 admin    root         28934 Jun  6 16:34 uidivstats_www.asp
drwxrwxrwx    2 admin    root             0 Jun  6 16:34 .
drwxrwxrwx    3 admin    root             0 Jun  6 17:03 ..
-rwxr-xr-x    1 admin    root           885 May 13 01:45 dnsmasqtotal.awk
-rwxr-xr-x    1 admin    root           886 May 19 15:51 dnsmasqtotalextra.awk
-rwxr-xr-x    1 admin    root           540 Apr 24 12:15 taildns
-rwxr-xr-x    1 admin    root          1131 May 19 11:49 taildnstotal
admin@FaTiii:/tmp/home/root# ls -laR /opt/share/uiDivStats.d
drwxrwxrwx    3 admin    root          4096 Jun  6 17:04 .
drwxr-xr-x   10 admin    root          4096 Jun  6 14:27 ..
drwxrwxrwx    2 admin    root          4096 Jun  6 17:03 csv
-rw-r--r--    1 admin    root         20480 Jun  6 17:03 dnsqueries.db
drwxrwxrwx    2 admin    root          4096 Jun  6 17:03 .
drwxrwxrwx    3 admin    root          4096 Jun  6 17:04 ..
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Blockeddaily.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Blockeddailyclients.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Blockeddailytime.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Blockedmonthly.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Blockedmonthlyclients.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Blockedmonthlytime.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Blockedweekly.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Blockedweeklyclients.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Blockedweeklytime.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:04 SQLQueryLog.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 TotalBlockeddailytime.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 TotalBlockedmonthlytime.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 TotalBlockedweeklytime.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Totaldaily.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Totaldailyclients.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Totaldailytime.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Totalmonthly.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Totalmonthlyclients.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Totalmonthlytime.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Totalweekly.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Totalweeklyclients.htm
-rw-rw-rw-    1 admin    root             0 Jun  6 17:03 Totalweeklytime.htm
I can see new logs when I tail "tail -F /opt/var/log/dnsmasq.log /opt/var/log/dnsmasq.log3"
Do you get any errors if you use option 2 in uiDivStats?
dana@RT-AC2900-72D8:/tmp/home/root# tail -F /opt/var/log/dnsmasq.log /opt/var/log/dnsmasq.log3
tail: can't open '/opt/var/log/dnsmasq.log3': No such file or directory
==> /opt/var/log/dnsmasq.log <==
Jun  6 16:08:46 dnsmasq[2719]: 867 192.168.123.36/59135 cached connectivitycheck.gstatic.com is 172.217.21.163
Jun  6 16:09:07 dnsmasq[2719]: 868 192.168.123.84/38969 query[A] ps-125.pubnub.com from 192.168.123.84
Jun  6 16:09:07 dnsmasq[2719]: 868 192.168.123.84/38969 forwarded ps-125.pubnub.com to 195.67.199.20
Jun  6 16:09:07 dnsmasq[2719]: 868 192.168.123.84/38969 forwarded ps-125.pubnub.com to 195.67.199.18
Jun  6 16:09:07 dnsmasq[2719]: 868 192.168.123.84/38969 forwarded ps-125.pubnub.com to 195.67.199.19
Jun  6 16:09:07 dnsmasq[2719]: 868 192.168.123.84/38969 reply ps-125.pubnub.com is <CNAME>
Jun  6 16:09:07 dnsmasq[2719]: 868 192.168.123.84/38969 reply pubsub.pubnub.com is 54.93.254.233
Jun  6 16:09:07 dnsmasq[2719]: 868 192.168.123.84/38969 reply pubsub.pubnub.com is 54.93.254.234
Jun  6 16:09:20 dnsmasq[2719]: 869 192.168.123.151/38153 query[A] connectivitycheck.gstatic.com from 192.168.123.151
Jun  6 16:09:20 dnsmasq[2719]: 869 192.168.123.151/38153 cached connectivitycheck.gstatic.com is 172.217.21.163
^C
^C
OK so it looks like you have extra query logging for dnsmasq enabled, but taildns is using the standard awk script. Can you send the output of:
cat /etc/dnsmasq.conf | grep log
please?
Choose an option:    2
awk: cmd. line:1: Division by zero
uiDivStats: Stats updated successfully
Press enter to continue...
I've just disabled extra query logging for dnsmasq and here is my current dnsmasq settings if it helps;
Dnsmasq settings:
 See the Dnsmasq man page what these options do:
 http://www.thekelleys.org.uk/dnsmasq/docs/dnsmasq-man.html
 1. Disable Dnsmasq settings
 2. log-async         20
 3. cache-size        2500
 4. bogus-priv        on
 5. domain-needed     on
 6. log-queries=extra
Can this be the reason?
admin@FaTiii:/tmp/home/root# tail -F /opt/var/log/dnsmasq.log /opt/var/log/dnsmasq.log3
please?
dana@RT-AC2900-72D8:/tmp/home/root# cat /etc/dnsmasq.conf | grep log
log-async
log-queries=extra
log-facility=/opt/var/log/dnsmasq.log
thanks!
