uiDivStats uiDivStats - WebUI for Diversion statistics
Choose an option:    2
awk: cmd. line:1: Division by zero
uiDivStats: Stats updated successfully
Press enter to continue...
I've just disabled extra query logging for dnsmasq and here is my current dnsmasq settings if it helps;
Dnsmasq settings:
 See the Dnsmasq man page what these options do:
 http://www.thekelleys.org.uk/dnsmasq/docs/dnsmasq-man.html
 1. Disable Dnsmasq settings
 2. log-async         20
 3. cache-size        2500
 4. bogus-priv        on
 5. domain-needed     on
 6. log-queries=extra
taildns seemed to be using the correct awk script for you. What do you get if you run:
sqlite3 /opt/share/uiDivStats.d/dnsqueries.db
.tables
select * from dnsqueries;
dana@RT-AC2900-72D8:/tmp/home/root# cat /etc/dnsmasq.conf | grep log
log-async
log-queries=extra
log-facility=/opt/var/log/dnsmasq.log
thanks!
Can you try restarting taildns?
/opt/etc/init.d/S90taildns stop
sleep 5
/opt/etc/init.d/S90taildns start
ps | grep taildns
sqlite /opt/share/uiDivStats.d/dnsqueries.db
.tables
I guess I run them in wrong place? :D
admin@FaTiii:/tmp/home/root# sqlite /opt/share/uiDivStats.d/dnsqueries.db
-sh: sqlite: not found
admin@FaTiii:/tmp/home/root# .tables
-sh: .tables: not found
admin@FaTiii:/tmp/home/root# select * from dnsqueries;
-sh: select: not found
sorry, it should be sqlite3
No problem :)
admin@FaTiii:/tmp/home/root# sqlite3 /opt/share/uiDivStats.d/dnsqueries.db
SQLite version 3.31.1 2020-01-27 19:55:54
Enter ".help" for usage hints.
sqlite> .tables
dnsqueries         dnsqueriesmonthly  dnsqueriesweekly
sqlite> select * from dnsqueries;
sqlite>
OK so it looks like you have extra query logging for dnsmasq enabled, but taildns is using the standard awk script. Can you send the output of:
please?
log-async
log-queries=extra
than
sleep 5
ps | grep taildns
dana@RT-AC2900-72D8:/tmp/home/root# /opt/etc/init.d/S90taildns stop
 Checking taildns...              alive.
 Shutting down taildns...              done.
dana@RT-AC2900-72D8:/tmp/home/root# sleep 5
dana@RT-AC2900-72D8:/tmp/home/root# /opt/etc/init.d/S90taildns start
 Starting taildns...              done.
dana@RT-AC2900-72D8:/tmp/home/root# ps | grep taildns
21966 dana      3368 S    {taildns} /bin/sh /opt/bin/taildns
21969 dana      3368 S    {taildnstotal} /bin/sh /jffs/addons/uiDivStats.d/taildns.d/taildnstotal
21974 dana      3368 S    {dnsmasqtotalext} /usr/bin/awk -f /jffs/addons/uiDivStats.d/taildns.d/dnsmasqtotalextra.awk
21975 dana      3368 S    {taildnstotal} /bin/sh /jffs/addons/uiDivStats.d/taildns.d/taildnstotal
22029 dana      5432 S    grep taildns
No problem :)
sqlite> .tables
sqlite>
Well that confirms the data isn't making it into the database for some reason. Please try restarting taildns (using the steps I posted earlier) and then run:
tail -F /opt/var/log/dnsmasq.log /opt/var/log/dnsmasq.log3 | /jffs/addons/uiDivStats.d/taildns.d/dnsmasqtotal.awk
assuming you still have extra query logging turned off
log-async
log-queries=extra
than
OK so taildns is using the right awk script now. Hopefully you'll see your database file growing/modified:
ls -lah /opt/share/uiDivStats.d/dnsqueries.db
here;
admin@FaTiii:/tmp/home/root# /opt/etc/init.d/S90taildns stop
admin@FaTiii:/tmp/home/root# sleep 5
admin@FaTiii:/tmp/home/root# /opt/etc/init.d/S90taildns start
admin@FaTiii:/tmp/home/root# ps | grep taildns
28269 admin     1420 S    {taildns} /bin/sh /opt/bin/taildns
28272 admin     1420 S    {taildnstotal} /bin/sh /jffs/addons/uiDivStats.d/taildns.d/taildnstotal
28278 admin     1444 S    {dnsmasqtotal.aw} /usr/bin/awk -f /jffs/addons/uiDivStats.d/taildns.d/dnsmasqtotal.awk
28279 admin     1424 S    {taildnstotal} /bin/sh /jffs/addons/uiDivStats.d/taildns.d/taildnstotal
28335 admin     4656 S    grep taildns
admin@FaTiii:/tmp/home/root# tail -F /opt/var/log/dnsmasq.log /opt/var/log/dnsmasq.log3 | /jffs/addons/uiDivStats.d/taildns.d/dnsmasqtotal.awk
tail: can't open '/opt/var/log/dnsmasq.log3': No such file or directory
1591453572,172.24.5.2,spclient.wg.spotify.com,A,allowed
1591453618,172.24.5.8,chat.cdn.whatsapp.net,A,allowed
1591453648,172.24.5.15,mapi.speedtest.net,A,allowed
1591453648,127.0.1.1,speedtest.net,dnssec-DS,allowed
1591453649,172.24.5.2,mix.com,A,allowed
1591453649,127.0.1.1,mix.com,dnssec-DS,allowed
1591453649,172.24.5.2,mix.com,AAAA,allowed
1591453649,172.24.5.2,us.hola.com,A,allowed
1591453650,127.0.1.1,hola.com,dnssec-DS,allowed
1591453650,172.24.5.2,e13750.a.akamaiedge.net,A,allowed
1591453650,172.24.5.2,e13750.a.akamaiedge.net,AAAA,allowed
1591453650,172.24.5.2,tagger.opecloud.com,A,blocked (blocking list)
1591453650,172.24.5.2,amplifypixel.outbrain.com,A,blocked (blocking list)
I can see new logs as I browse internet. so I've chosen option 2 and here we have the happy result :) Thank you very much :)
uninstalled existing version, and then installed new version.
install stuck at "Creating database table indexes..."
Still no growing database file and no stats :confused:
Is it easier if I uninstall and reinstall, or are you interested in troubleshooting more?
fresh new install:
cromo@RT-AX88U-8158:/tmp/home/root# /usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/jackyaz/uiDivStats/maste
r/uiDivStats.sh" -o "/jffs/scripts/uiDivStats" && chmod 0755 /jffs/scripts/uiDivStats && /jffs/scripts/uiDivStats instal
l
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 43273 100 43273 0 0 355k 0 --:--:-- --:--:-- --:--:-- 449k
uiDivStats: Welcome to uiDivStats v2.0.0, a script by JackYaz
uiDivStats: Checking your router meets the requirements for uiDivStats
Downloading http://bin.entware.net/aarch64-k3.10/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
Package grep (3.4-1) installed in root is up to date.
Package sqlite3-cli (3310100-1) installed in root is up to date.
Package procps-ng-pkill (3.3.15-4) installed in root is up to date.
uiDivStats: New version of uidivstats_www.asp downloaded
uiDivStats: Mounting uiDivStats WebUI page as user3.asp
uiDivStats: New version of taildns.tar.gz downloaded
uiDivStats: Creating database table and enabling write-ahead logging...
uiDivStats: Creating database table indexes...
Error: near line 1: index idx_dns_domains already exists
Error: near line 1: index idx_dns_time already exists
Error: near line 1: index idx_dns_clients already exists
uiDivStats: Database ready, starting services...
uiDivStats: Starting first run of stat generation...
After this, the UI page is missing. even after a reboot
did an
Thanks for quick and good response with my troubleshooting.
I tested and uninstalled and deleted db from CLI, restarted the router and then reinstalled from CLI.
But still no stats :mad:
I'm also stumped :confused:
at this stage, would you be up for a screensharing session using Teamviewer or VNC or something?
@Jack Yaz Might it be that taildns is starting before Diversion modifies /etc/dnsmasq.conf and therefore misses the log queries extra configuration?
RT-AX88U on RT-AX88U_384.18_alpha1-g6368a955e8 firmware.
I had the previous uiDivStats version running before but uninstalled it for other troubleshooting issues (and waited for v2.00 to become available before I re-installed it again).
Just installed v2.00 with router currently 'up' 8 days and 9 hours. No issues, Tab shows in LAN, and everything running normally with no reboot needed (although I will probably do one in an hour or so, as per my 'normal' after any change in the GUI).
Thank you very much @Jack Yaz! Another solid release.
This is a great upgrade! A lot of complexity behind the scenes to make it look so cool. :cool:
Noticed this today that when dnssec is enabled there are extra lines in the log that probably want to be filtered out. I had dnssec disabled during beta testing. :oops:
Jun  6 12:08:13 dnsmasq[9727]: dnssec-query[DS] asuswrt-merlin.net to 9.9.9.11
Jun  6 12:08:13 dnsmasq[9727]: dnssec-query[DNSKEY] asuswrt-merlin.net to 9.9.9.11
