Jack Yaz
Part of the Furniture
And hopefully no longer broken!uiDivStats v0.5.0 is out.![]()
That bit isn't fully done yetSorry Jack Yaz, but should I wait until just after the top of the hour before saying that the top 10 requested graph isn't being populated?![]()
Trying to make me feel better for pushing broken scribe versions?That bit isn't fully done yet
I should reintroduce a develop branch but atm I'm just shipping commits
Now you may update and try it outApologies! I'll go to the back of the class, put my gum on my nose and stand against the wall for the rest of the day.![]()
Now you may update and try it out![]()
Indeed. You may even find a new option for chart type...Yes! It works, it works!
Can I take the gum off my nose now?![]()
No matter what I try, my graphs are empty.
In uiDivStats, does pressing the 1st option do nothing? I would also test with another browser just in case.No matter what I try, my graphs are empty.![]()
Yes, it has been running for hours, I check for updates often, just when Jack Yaz added the second graph, they stopped displaying.On version v0.5.1 and after '1' is allowed to run for at least 30 seconds (way faster now)?
Yes, it has been running for hours, I check for updates often, just when Jack Yaz added the second graph, they stopped displaying.![]()
Chrome on Linux, no Edge stuff here.No issues with Edge here. Did you log out of the router, close the browser you are using and log back in?
Does a 'u' or 'uf' followed by a '1' in uiDivStats help?
Welcome To SNBForums
