Unbound unbound_manager (Manager/Installer utility for unbound - Recursive DNS Server) - General questions / discussion thread 2
Do you have this in cronjob?
1 0 * * * /opt/bin/find /opt/var/lib/unbound/unbound.log -size +10M -exec rm -f {} \; #unboundLOG#
I just realized I only have these now related to unbound. Other cronjob are loaded properly. I am not sure why this seems the only one missing.
12 4 * * * curl -o \/opt\/var\/lib\/unbound\/root\.hints https://www.internic.net/domain/named.cache #root_servers#
*/15 * * * * /jffs/addons/unbound/unbound_rpz.sh download #Unbound_RPZ.sh#
59 * * * * /jffs/addons/unbound/unbound_stats.sh generate #Unbound_Stats.sh#
57 * * * * /jffs/addons/unbound/unbound_log.sh #Unbound_Log.sh#
Maybe stupid question, but how to add block list content to unbound?
ad is showing that some numbers can be added, but how to?
If Adblock is ENABLED, there are several Advanced menu commands to edit the various AdBlock files...
e.g.
i  = Update unbound and configuration ('/opt/var/lib/unbound/')     l  = Show unbound log entries (lo=Enable FULL Logging [log_level])
z  = Remove unbound/unbound_manager                                 v  = View ('/opt/var/lib/unbound/') unbound Configuration (vx=Edit;vh=help)
x  = Stop unbound                                                   vb = Backup current (/opt/var/lib/unbound/unbound.conf) Configuration [filename]
        rl = Reload Configuration (Doesn't halt unbound) e.g. 'rl test1[.conf]' (Recovery use 'rl reset/user')
?  = About Configuration                                            oq = Query unbound Configuration option e.g 'oq verbosity' (ox=Set) e.g. 'ox log-queries yes'
sd = Show dnsmasq Statistics/Cache Size                             s  = Show unbound Extended statistics (s=Summary Totals; sa=All; http://10.88.8.1:80/user1.asp)
        adblock = Install Ad Block [uninstall | update | track]
DisableFirefoxDoH = Disable Firefox DoH [yes | no]                  youtube = Install YouTube Ad Block [uninstall | update]
Stubby = Enable Stubby Integration                                  DoT = Enable DNS-over-TLS
        firewall = Enable DNS Firewall [disable | ?]
bind = BIND unbound to WAN [debug | disable | debug show]           vpn = BIND unbound to VPN {vpnid [debug]} | [disable | debug show] e.g. vpn 1
scribe = Enable scribe (syslog-ng) unbound logging                  ad = Analyse Diversion White/Block lists ([ file_name [type=adblock] ])
dnsmasq = Disable dnsmasq [disable | interfaces | nointerfaces]     ea = Edit Ad Block Allowlist (eb=Blocklist; eca=Config-AllowSites; ecb=Config-BlockSites; el {Ad Block file})
dumpcache = [bootrest] (or Manually use restorecache after REBOOT)  ca = Cache Size Optimisation [ min | calc ]
        views = [? | uninstall] | {view_name [? | remove]} | {view_name [[type] domain_name[...] | IP_address[...]] [del]} ]
        safesearch = Enable Safe Search [disable | status | ? ] e.g. redirect google.com to forcesafesearch.google.com
        localhost = Add { domain_name {IP_address | del} }
dig = {domain} [time] Show dig info e.g. dig asciiart.com           lookup = {domain} Show the name servers used for domain e.g. lookup asciiart.eu
dnsinfo = {dns} Show DNS Server e.g. dnsinfo                        dnssec = {url} Show DNSSEC Validation Chain e.g. dnssec www.snbforums.com
links = Show list of external URL links
[Enter] Leave Advanced Tools Menu
e  = Exit Script [?] ecb
to apply custom edits to the Blocklist ('/opt/share/unbound/configs/blocksites') file to append additional resource lists to the default StevenBlack hosts file, such as:
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
# User added Custom entries
#TikTok
https://raw.githubusercontent.com/llacb47/mischosts/master/tiktok-hosts
https://raw.githubusercontent.com/mitchellkrogza/The-Big-List-of-Hacked-Malware-Web-Sites/master/hacked-domains.list
https://blocklist.cyberthreatcoalition.org/vetted/domain.txt
#Zones_in_unbound_format
https://gitlab.com/my-privacy-dns/rpz-dns-firewall-tools/unbound/-/raw/master/nxdomain/adaway/mobileadtrackers.zone
https://gitlab.com/my-privacy-dns/rpz-dns-firewall-tools/unbound/-/raw/master/nxdomain/mypdns/mypdns.adware.zone
https://gitlab.com/my-privacy-dns/rpz-dns-firewall-tools/unbound/-/raw/master/nxdomain/mypdns/mypdns.typosquatting.zone
e.g.
#TikTok
How do you find Unbound's ad block compares to Diversion? Does it have the ability to share whitelists with Skynet too? Or does it not need Skynet as Unbound also has it's own built in firewall too?
I don't use either skynet or diversion, but as per the Q&A, both diversion (and skynet) can successfully coexist with an unbound_manager
Adblock/DNS Firewall configuration, but their respective esoteric block/allow lists cannot be directly shared.
Do you have to manage these firewall lists yourself too in that case, or does it just work? I'm considering using Unbound's solution instead if it has the same functionality and it will probably lower ram usage too.
The unbound block/allow rules are refreshed at least daily by cron schedules
i.e. for the DNSN Firewall (RPZ) and Adblock lists respectively.
0    5 * * * /opt/var/lib/unbound/adblock/gen_adblock.sh #adblock#
NOTE: The contents of the external lists provided by the hosting repository could be stale (or contain false positives) depending on the management/scheduled publication of the files, so whilst set-and-forget should 'just work', it is prudent to manually periodically review the rules to ensure that they meet your current expectations/needs.
Not sure if i understand this unbound correctly but i just broke my internet with playing and this tool.
Luckily i can easy set it up again so no biggie there.
As for the problem, from my understanding i can have the Unbound addblocker active.
With winscp i edited the file for blacklist URL's, these contain 17 URL's now and combine a numer of 1.7.xx.xxx domains.
The update proccess looked ok and all downloaded and seemed to be converted.
It took a long time though and the router interface and internet traffic was a bit of a hit and miss.
Using top i could see the load hovering 5 and 6 wich obviously is way to much for the CPU to handle.
Cant unbound handle such a 'big' list?
Memory was filled and approx 800mb of swap used, keep in mind, there was no other script installed at this time as i factory resetted the device before i started the unbound route.
Edit: redone everything and now it seesm to be working.
Weird thing though, i now have free memory on the RAM itself and SWAP used.
With the same list in Diversion i did not have this.
Is it expected to have SWAP used now with Unbound?
Hi Martineau - do you intend releasing v3.23b9 as a general release?
I will eventually formally release it as v3.23, given I will soon run out of my self-imposed single character Beta version release numbers
i.e. currently on 'bB' with only 'bC-bF' remaining to be used.
Hopefully forum members brave enough (if any?) to have used unbound_manager command uf dev to install v3.23bB would have immediately reported any issues, but currently v3.23b* has been stable for many months on my friends/families routers.
i.e. currently on 'b9' with only 'bA-bF' remaining to be used.
Hopefully forum members brave enough (if any?) to have used unbound_manager command uf dev to install v3.23b9 would have immediately reported any issues, but currently v3.23b* has been stable for many months on my friends/families routers.
I must have missed what is included in this update. Just did it anyway. Hope I get it right.
E:Option ==> uf dev
        unbound_manager.sh downloaded successfully Github 'dev/development' branch
unbound Manager UPDATE Complete! 6b4a500c071bcbb3f4a6e9596a178d43
 Checking haveged...              alive.
 Shutting down haveged...              done.
|  Welcome to the unbound Manager/Installation script (Asuswrt-Merlin) |
|                      Version 3.23bB by Martineau                     |
All Beta v3.23* commits can be reviewed using unbound_manager command ?, then clicking (if your SSH Clients allows URL Hotspots) on the
Change Log: URL
e.g.
unbound (pid 1704) is running... uptime: 9 days 12:02:21 version: 1.13.2 # Version=v1.13 Martineau update (Date Loaded by unbound_manager Sun Sep 5 22:12:49 DST 2021)
3  = Advanced Tools                                                 rl = Reload Configuration (Doesn't halt unbound) e.g. 'rl test1[.conf]' (Recovery use 'rl reset/user')
rs = Restart (or Start) unbound (use 'rs nocache' to flush cache)   s  = Show unbound Extended statistics (s=Summary Totals; sa=All; http://10.88.8.1:80/user1.asp)
e  = Exit Script [?]
A:Option ==> ?
    Version=3.23bB                              (Change Log: https://github.com/MartineauUK/Unbound-Asuswrt-Merlin/commits/dev/unbound_manager.sh)
    Local                                       md5=c7a29f5806410ca53da61910981ea6a3
    Github                                      md5=6b4a500c071bcbb3f4a6e9596a178d43
    /jffs/addons/unbound/unbound_manager.md5    md5=c7a29f5806410ca53da61910981ea6a3
    Router Configuration recommended pre-reqs status:
    [✔] Swapfile=1048572 kB
    [✔] DNS Filter=ON
    [✔] DNS Filter=ROUTER
    [✖] Warning WAN: Use local caching DNS server as system resolver=YES        see http://10.88.8.1:80/Tools_OtherSettings.asp ->Advanced Tweaks and Hacks
    [✔] Entware NTP server 'S77chronyd' is running
    [✔] Enable DNS Rebind protection=NO
    [✔] Enable DNSSEC support=NO
<snip>
P.S. Not all commits have an accompanying description, e.g. trivial typo/column alignment corrections etc., but bug fixes and esoteric new features for Advanced Users should be documented.
@Martineau
I messed up my already optimized unbound.conf set by you
Can you please share conf file so i can replace and make my mess fixed
It would be great help
Thank you
@Martineau
Thank you
If you have taken backups prior to testing custom config tweaks
e.g.
A:Option ==> vb
Active 'unbound.conf' backed up to '/opt/share/unbound/configs/20211007-071538_unbound.conf'
then restore the appropriate config using rl command
Alternatively, you can quickly reset 'unbound.conf' to the installation defaults using
e  = Exit Script [?]
A:Option ==> i config
Retrieving Custom unbound configuration
    unbound.conf downloaded successfully
07:07:24 Checking 'unbound.conf' etc. for valid Syntax.....
07:07:25 Saving unbound cache to '/opt/share/unbound/configs/cache.txt' msg.cache=745/343 rrset.cache=2561/1761
07:07:25 Requesting unbound (S61unbound) restart.....
Shutting down unbound...              done.
Starting unbound...              done.
07:07:29 Checking status, please wait.....
07:07:33 Restoring unbound cache from '/opt/share/unbound/configs/cache.txt' (2021-10-07 07:07:25) msg.cache=14/343 rrset.cache=125/1761
07:07:33 unbound OK
unbound (pid 12140) is running... uptime: 0 Days, 00:00:07 version: 1.13.2 # Version=v1.13 Martineau update (Date Loaded by unbound_manager Thu Oct 7 07:07:29 DST 2021)
NOTE: If you used unbound_manager's addon files to customise unbound , then you will need to rename those files otherwise they will still be reapplied and may still propagate a bad configuration.
Is this because of unbound @Martineau ? That's my WAN IP appearing in top 10 blocked devices outbound in Skynet Gui
If you wish to force all unbound requests via a VPN Client, then you should be using the appropriate openvpn-event triggers
e.g.
'/jffs/scripts/vpnclientX-up'
unbound_manager.sh vpn=X
'/jffs/scripts/vpnclientX-down'
unbound_manager.sh vpn=disable
to modify 'unbound.conf'
Also, as a failsafe during the boot process i.e. before the VPN Client(s) are connected, it is recommended that you also modify
'/jffs/scripts/post-mount'
logger "Checking unbound VPN bind....."
[ -n "$(which unbound_manager)" ] && { sh /jffs/addons/unbound/unbound_manager.sh vpn=disable; logger "unbound VPN routing DISABLED"; } # unbound_manager
Apologies if this has been answered somewhere, search did not turn up any results that would help resolve.
I would like to have all Unbound traffic going through the VPN (VPN2 to VPN5, doesn't matter). I've tried a script from another thread, while that worked well for VPN1, my attempts to modify it to work with other VPN clients did not provide a reliable solution.
1.) I have enabled bind unbound through VPN5.
- The tunnel is active.
2.) In /jffs/scripts/vpnclient5-down, I have added
3.) In /jffs/scripts/vpnclient5-up, I have added
/jffs/addons/unbound/unbound_manager.sh vpn=5
4.) In /jffs/scripts/post-mount, I have added
But I'm still seeing my ISP IP address in DNS leak test. Do I need to do anything else? Do I need to setup something through x3mrouting?
A setp by step walkthrough would be greatly appreciated.
BTW, when I run ip rule, I do not see (I think this may have something to do with it)
9991: from all fwmark 0x3000/0x3000 lookup ovpnc5
Thanks for the help.
Whilst I do not wish to offend @Swinson, in light of his current ongoing forum absence since June 2021, I have created a generic version of his original script that should allow you to designate any VPN client without the need to edit/hack the script.
You can download/test it from
<snip>
Clearly your previous statement [the script] 'did not provide a reliable solution' needs to be made clearer... i.e. are you absolutely sure that the DNS Leak test is always 100% accurate?
IMHO, x3mrouting shouldn't be necessary just for your DNS routing requirement? - see below
If not using x3mrouting then you need to implement the RPDB fwmark rules manually...
see '/jffs/scripts/nat-start'
Policy based Port routing (manual method) · RMerl/asuswrt-merlin.ng Wiki · GitHub
to ensure that the RPDB fwmark rules are always available should the firewall be rebuilt whilst the VPN Client is UP.
(x3mrouting dynamically adds/deletes the RPDB fwmark rules only when the VPN Client is actually started/stopped!)
EDIT:
If you decide to test my generic '/jffs/addons/unbound/unbound_DNS_via_OVPN.sh' script then you should ensure ALL of the 'vpnclientX-route-*' event scripts contain the appropriate call
e.g. VPN Client 5
'/jffs/scripts/vpnclient5-route-up'
VPN_ID=${dev:4:1}
[ -z "$VPN_ID" ] && { SCR=$(basename $0); VPN_ID=${SCR:9:1}; }    # Allow manual debugging from commandline
if [ -n "$(which unbound-control)" ] && [ -n "$(unbound-control status | grep -E "unbound.*running")" ];then
    Say "Unbound DNS requests via VPN Client $VPN_ID requested....."
    /jffs/addons/unbound/unbound_DNS_via_OVPN.sh "$VPN_ID" start &
fi
and
'/jffs/scripts/vpnclient5-route-pre-down'
VPN_ID=${dev:4:1}
    Say "Unbound DNS requests via VPN Client $VPN_ID terminating....."
    /jffs/addons/unbound/unbound_DNS_via_OVPN.sh "$VPN_ID" stop
fi
EDIT:
e.g. VPN Client 5
VPN_ID=${dev:4:1}
fi
and
VPN_ID=${dev:4:1}
fi
Thanks @Martineau, this is very nice and complete. I am using @Swinson script to bind unbound to wireguard. Will definitely use your enhanced version for it.
For line 39, I noticed it will take anything that contains number 1-5. Say 16 is valid. I edit a bit and seems now it will only take 1-5.
[ -z $(echo "$VPN_ID" | grep -E "[1-5]") ] --> ! [ "$VPN_ID" -ge 1 ] || ! [ "$VPN_ID" -le 5 ]
